Angryunibrow
Post by Angryunibrow » Fri Mar 13, 2020 7:11 pm
OK so I did Doctor Sleep (Full Movie) using the "Test Build"
Everything processed 100%.
(I used EAC3TO to Extract the BL & EL)
Still recieved the same message in tsMuxeR, and thought this was not going to work.
Mediainfo is showing Dolby Vision now along with HDR10+
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration                                 : 2 h 32 min
Bit rate                                 : 66.9 Mb/s
Bits/(Pixel*Frame)                       : 0.337
Stream size                              : 71.1 GiB (94%)
Maximum Content Light Level              : 745 cd/m2
Maximum Frame-Average Light Level        : 47 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 347 kb/s
Stream size                              : 696 MiB (1%)
Number of dynamic objects                : 15
I'm not home yet to test this on the shield - but looks promising.
justinadams
Post by justinadams » Fri Mar 13, 2020 9:03 pm
yusesope wrote: Fri Mar 13, 2020 5:12 pm
mike admin wrote: Thu Mar 12, 2020 2:51 pm My current MKV samples store no DV metadata in codec private area - once I add the support I'll update the samples and hopefully this would give the start to DV support in MKV container.
Wonderful
shawnc22 wrote: Fri Mar 13, 2020 5:40 am
justinadams wrote: Fri Mar 13, 2020 5:27 am Welp, i'm stumped.
I can't seem to get Joker to process to single layer correctly.
I just did Alita and it worked without issue. Demux with tsmuxer (the one that has the folder name of "tsMuxer test"), yusesope's v2 tool, remux to ts with tsmuxer. I have tried a different copy of joker (just in case), demux with ffmpeg, remux without audio, adjusting the the load_balancing_factor of yuescope's tool (since it was showing either 99.6% or 99.7% of EL once it completed with no error).
only success I have had was with doing a 20 second clip with no audio.
anything suggestions would be much appreciated.
Same issue with Doctor Sleep. Going through the steps with the whole movie resulted in a 99.2% EL analysis in yusecope's tool and then no DV layer once remuxed back into a TS container. Using a 20s clip, the files go through yusecope's at 100% on everything and the resulting TS with no audio contains both DV and HDR 10+:
Video
Duration                                 : 19 s 19 ms
Bit rate                                 : 46.1 Mb/s
Bits/(Pixel*Frame)                       : 0.232
Stream size                              : 104 MiB (95%)
Can you both try THIS temporary version (only source code)?
python-3.7.6.amd64\python \path\to\bl_el_rpu_builder_temp_version.py -bl \path\to\BL.hevc -el \path\to\EL.hevc -of \path\to\output.hevc
I imposed a more rigid alignment between the reading and writing processes (in order to avoid that the two layers, BL and EL, are staggered in the output file).
In the event that the counters reach all 100%, wait for the message "Press a button to exit".
Ding Ding Ding
That has worked. 100% on all. mediainfo shows DV. and the final muxed file plays and triggers DV.
Thank you very much.
Post by shawnc22 » Fri Mar 13, 2020 9:26 pm
Angryunibrow wrote: Fri Mar 13, 2020 7:11 pm OK so I did Doctor Sleep (Full Movie) using the "Test Build"
Video
Audio
Codec ID                                 : 131
Didn't get to test this new build myself yet, but hasn't that pyramid message always shown up when remuxing back to TS? From the couple movies I've tried so far that worked, I believe that message has always been there; although I have no idea what it means and its significance.
Angryunibrow
Post by Angryunibrow » Fri Mar 13, 2020 9:54 pm
shawnc22 wrote: Fri Mar 13, 2020 9:26 pm
Video
Audio
Codec ID                                 : 131
I have only seen this message on this movie, and I also tried Star Wars - Which was not successful in keeping the Dolby Vision in the final file. (This was before this new build of the tool) So I will try Star Wars again
baker99
Post by baker99 » Fri Mar 13, 2020 10:50 pm
Angryunibrow wrote: Fri Mar 13, 2020 9:54 pm
Video
Audio
Codec ID                                 : 131
I regularly get the message, I think it's normal and to do with timestamps, some information here https://bitmovin.com/docs/encoding/faqs ... by-default
Arbigator
Post by Arbigator » Sat Mar 14, 2020 1:24 am
@yusesope
Just tried your temporary build, and it worked for Joker, however I tried it with Spectre, and the EL analysis rockets to 100% fairly quickly, but the BL analysis sits at 0%, and does not progress. I also tried it with First Man, and it just hangs and says "wait.." after hitting enter when adding the EL.
Post by shawnc22 » Sat Mar 14, 2020 2:54 am
Just tested Doctor Sleep and can confirm that new temp build works. But then I just tried A Quiet Place, and it was getting hung up at the "Wait..." message. Went back to the previous version and that went through just fine.
Angryunibrow
Post by Angryunibrow » Sat Mar 14, 2020 2:55 am
First Man:
Temp Build - Hangs on wait...
@yusesope - let me know if I can supply you anything when this hangs on wait... On the temp build.
V.0.0.2 - Processed just fine to 100% first try.
V.0.0.2 Mediainfo:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 20 min
Bit rate                                 : 65.6 Mb/s
Bits/(Pixel*Frame)                       : 0.330
Stream size                              : 64.6 GiB (94%)
Maximum Frame-Average Light Level        : 285 cd/m2
Audio
Codec ID                                 : 131
Maximum bit rate                         : 4 533 kb/s
Stream size                              : 452 MiB (1%)
Remember I use eac3to to extract all my BL & EL files, and have had zero issues.
Everyone who are having issues maybe try eac3to and see what happens.
Its been zero issues on all moves for me so far.
Arbigator
Post by Arbigator » Sat Mar 14, 2020 5:03 pm
Angryunibrow wrote: Sat Mar 14, 2020 2:55 am
Do you mind sharing which version of eac3to you use? and the command to extract the video streams? Sorry, but I haven't been able to figure out how to get the EL out, only the base layer is extracted. Thanks.
yusesope
Post by yusesope » Sat Mar 14, 2020 5:14 pm
shawnc22 wrote: Sat Mar 14, 2020 2:54 am Just tested Doctor Sleep and can confirm that new temp build works. But then I just tried A Quiet Place, and it was getting hung up at the "Wait..." message. Went back to the previous version and that went through just fine.
Angryunibrow wrote: Sat Mar 14, 2020 2:55 am First Man:
Sorry!
I made a stupid mistake! :lol: :lol: :lol: :lol:
I forgot to correctly initialize the Thread which takes care of reading the two layers.
You need to add the following line of code between line 442 and line 443 (follow the instructions in THIS post).
self.event.set()
Respect the tabulation (as in the image), it is fundamental.
Post by shawnc22 » Sat Mar 14, 2020 5:33 pm
yusesope wrote: Sat Mar 14, 2020 5:14 pm Respect the tabulation (as in the image), it is fundamental.
Got it, that worked! (although not as fundamental as spaces :wink: )
Angryunibrow
Post by Angryunibrow » Sat Mar 14, 2020 5:48 pm
I obviously do not know how to edit properly in Notepadd ++, keep getting an error.
Can you post the new file?
yusesope
Post by yusesope » Sat Mar 14, 2020 6:04 pm
Angryunibrow wrote: Sat Mar 14, 2020 5:48 pm Can you post the new file?
HERE it is.
Please guys, also test movies with HDR10+.
If you confirm that everything is ok, I will release version 0.0.3 in the next few days.
Angryunibrow
Post by Angryunibrow » Sat Mar 14, 2020 6:08 pm
yusesope wrote: Sat Mar 14, 2020 6:04 pm
HERE it is.
Thank you!
I'll test this out with some HDR10+ movies as well
Arbigator
Post by Arbigator » Sat Mar 14, 2020 6:16 pm
@yusesope
I'm still getting this with all the Bond movies I've tried, EL analysis shoots up to 100% right away, and BL stays at 0. Any idea what's going on here?
