Zombieland 4K UHD AACS 2.1
tacocat
Re: Zombieland 4K UHD AACS 2.1
Post by tacocat »
SSutherland1002 wrote:
Sun Jan 26, 2020 12:15 am
djj82 wrote:
Sat Jan 25, 2020 10:58 pm
Same problem here still too :'-(
Downloading latest HK to D:/MakeMKV ...
Saved AACS dump file as D:/MakeMKV/MKB21_v70_Zombieland_1C8D.tgz
Yours has the same last 4 characters as mine! Wonder if that means ours came from the same original source and they're having a problem decrypting that one
Mine is having the same issue. I sent the dump in this morning. Same dump file name as above. Running 1.14.7 x64. I sent it to support, didn't realize there was another email address. My tgz file was ~1.6MB.
djj82
Post by djj82 »
Any update or progress on Zombineland 4K AACS2.1?
Bluntman
Post by Bluntman »
djj82 wrote:Any update or progress on Zombineland 4K AACS2.1?
Must be a unique variant as I’m able to rip my North American copy no problems. I’m sure mike is on the case.
olevelo
Post by olevelo »
Still not working for me either. I just updated to 1.15 and also still doesn't work. Mine was also a Best Buy Black Friday special. And by special, I mean useless. :(
jeremybrice
Post by jeremybrice »
mike admin wrote:
Mon Jan 13, 2020 12:45 pm
djj82 wrote:
Sat Jan 11, 2020 1:52 am
olevelo wrote:
Tue Dec 24, 2019 7:16 pm
Does anyone else have a version of Zombieland that won't decrypt? I have the latest version of MakeMKV but it gives me a dump and says "The volume key is unknown for this disc - video can't be decrypted". I sent the dump in 10 days ago but haven't heard anything...in the past the discs were usually added within a couple days with no response. Just curious if anyone else has seen this issue.
Had the same issue again today 1/10. I thought AACS2.1 was supported in the latest MakeMKV and Zombieland was already a supported title. Sent in the dump, lets see what happens!
Apparently there are some "different" Zombieland discs out there. What kind of disc do you have? Anything special about it? Where did you get it from?
Hello. I'm having the same issue. I bought mine from Walmart a few weeks ago. 4K disc is the one that is giving the error. I'm emailing the dump file now.
olevelo
Post by olevelo »
Any updates from anyone on this? I just sent another dump in, as I never got a reply from the one I sent months ago. Is there any other program that can rip this disc? I'd really like to watch it. :/
olevelo
Post by olevelo »
Just updated to 1.15.1, but still no dice. :(
jeremybrice
olevelo wrote:
Thu Apr 16, 2020 12:39 am
Same here.
jeremybrice wrote:
Fri May 01, 2020 4:54 pm
Same here.
Does MakeMKV say it is downloading the latest HK?
jeremybrice
MartyMcNuts wrote:
Sat May 02, 2020 1:59 am
Same here.
Yeah, and I know it's updated because I submitted a dump file for Midway a couple days ago and tried again today and Midway worked but Zombieland still doesn't.
olevelo
Post by olevelo »
Still nothing. And I can't get a reply from anyone via email either.
LGans316
Post by LGans316 »
Am I right to say that this issue is limited to the International UHD and not the one released in the Americas?
I ripped Zombieland Double Tap yesterday and was thinking of ripping the first part today.
Sent from my Moto G (5S) Plus using Tapatalk
LGans316 wrote:
Mon May 11, 2020 7:07 am
I ripped both Zombieland & Zombieland: Double Tap (Australian UHD versions) months ago. Had zero issues with either.
LGans316
Post by LGans316 »
Ok mate. Going to give Zombieland 1 (UK) a go soon.
LGans316
Post by LGans316 »
Zombieland UK ripping in progress. So working fine.
Using LibreDrive mode (v05 id=4FBA32AEC678)
File 00001.mpls was added as title #0
File 00102.mpls was added as title #1
Title 00244.mpls is equal to title 00001.mpls and was skipped
Title 00245.mpls is equal to title 00001.mpls and was skipped
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00337.m2ts was added as title #2
File 00338.m2ts was added as title #3
File 00339.m2ts was added as title #4
File 00340.m2ts was added as title #5
Saving 1 titles into directory D:/MakeMKV/Zombieland1
