rosavanwinkle
Post by rosavanwinkle »
May i ask? why is everyone so focused on MKV? why not mp4 etc.? dumb question possibly
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Post by SamuriHL »
MP4 doesn't technically support many of the things that MKV supports such as HD Audio and blu-ray type subtitles.
MP4 may be limited, but, for enough money, the spec will "magically" support additional things.
Graphic subtitles like VOBSUB and PGS aren't supported because the people who created them do not WANT them in MP4. That might encourage piracy, don'cha know!
Post by SamuriHL »
Righttttt cause I spent many thousands of dollars building a high end home theater system with 7.1.2 ATMOS sound, 65" OLED, UB820 UHD player, high end HTPC, 20 TB NAS, SHIELD, Firestick 4k....so I could pirate content. SMFH. (And no, I know you were being sarcastic). But yea, these formats can be a pain in the ass. Which is why I don't currently bother backing up the DV part of it and just use my high end HTPC to tone map with madvr.
justinadams
Post by justinadams »
Welp, i'm stumped.
I can't seem to get Joker to process to single layer correctly.
I just did Alita and it worked without issue. Demux with tsmuxer (the one that has the folder name of "tsMuxer test"), yusesope's v2 tool, remux to ts with tsmuxer. I have tried a different copy of joker (just in case), demux with ffmpeg, remux without audio, adjusting the the load_balancing_factor of yuescope's tool (since it was showing either 99.6% or 99.7% of EL once it completed with no error).
only success I have had was with doing a 20 second clip with no audio.
anything suggestions would be much appreciated.
Post by shawnc22 »
justinadams wrote:
Fri Mar 13, 2020 5:27 am
Welp, i'm stumped.
Same issue with Doctor Sleep. Going through the steps with the whole movie resulted in a 99.2% EL analysis in yusecope's tool and then no DV layer once remuxed back into a TS container. Using a 20s clip, the files go through yusecope's at 100% on everything and the resulting TS with no audio contains both DV and HDR 10+:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration                                 : 19 s 19 ms
Bit rate                                 : 46.1 Mb/s
Bits/(Pixel*Frame)                       : 0.232
Stream size                              : 104 MiB (95%)
Maximum Content Light Level              : 745 cd/m2
Maximum Frame-Average Light Level        : 47 cd/m2
yusesope
Post by yusesope »
mike admin wrote:
Thu Mar 12, 2020 2:51 pm
My current MKV samples store no DV metadata in codec private area - once I add the support I'll update the samples and hopefully this would give the start to DV support in MKV container.
Wonderful
shawnc22 wrote:
Fri Mar 13, 2020 5:40 am
Welp, i'm stumped.
Video
Can you both try THIS temporary version (only source code)?
python-3.7.6.amd64\python \path\to\bl_el_rpu_builder_temp_version.py -bl \path\to\BL.hevc -el \path\to\EL.hevc -of \path\to\output.hevc
I imposed a more rigid alignment between the reading and writing processes (in order to avoid that the two layers, BL and EL, are staggered in the output file).
In the event that the counters reach all 100%, wait for the message "Press a button to exit".
Angryunibrow
Post by Angryunibrow »
OK so I did Doctor Sleep (Full Movie) using the "Test Build"
Everything processed 100%.
(I used EAC3TO to Extract the BL & EL)
Still recieved the same message in tsMuxeR, and thought this was not going to work.
Mediainfo is showing Dolby Vision now along with HDR10+
Video
Duration                                 : 2 h 32 min
Bit rate                                 : 66.9 Mb/s
Bits/(Pixel*Frame)                       : 0.337
Stream size                              : 71.1 GiB (94%)
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 347 kb/s
Stream size                              : 696 MiB (1%)
Number of dynamic objects                : 15
I'm not home yet to test this on the shield - but looks promising.
justinadams
yusesope wrote:
Fri Mar 13, 2020 5:12 pm
Wonderful
Welp, i'm stumped.
Video
Ding Ding Ding
That has worked. 100% on all. mediainfo shows DV. and the final muxed file plays and triggers DV.
Thank you very much.
Post by shawnc22 »
Angryunibrow wrote:
Fri Mar 13, 2020 7:11 pm
Video
Audio
Codec ID                                 : 131
Didn't get to test this new build myself yet, but hasn't that pyramid message always shown up when remuxing back to TS? From the couple movies I've tried so far that worked, I believe that message has always been there; although I have no idea what it means and its significance.
Angryunibrow
shawnc22 wrote:
Fri Mar 13, 2020 9:26 pm
Video
Audio
Codec ID                                 : 131
I have only seen this message on this movie, and I also tried Star Wars - Which was not successful in keeping the Dolby Vision in the final file. (This was before this new build of the tool) So I will try Star Wars again
baker99
Post by baker99 »
Angryunibrow wrote:
Fri Mar 13, 2020 9:54 pm
Video
Audio
Codec ID                                 : 131
I regularly get the message, I think it's normal and to do with timestamps, some information here https://bitmovin.com/docs/encoding/faqs ... by-default
Arbigator
Post by Arbigator »
@yusesope
Just tried your temporary build, and it worked for Joker, however I tried it with Spectre, and the EL analysis rockets to 100% fairly quickly, but the BL analysis sits at 0%, and does not progress. I also tried it with First Man, and it just hangs and says "wait.." after hitting enter when adding the EL.
Post by shawnc22 »
Just tested Doctor Sleep and can confirm that new temp build works. But then I just tried A Quiet Place, and it was getting hung up at the "Wait..." message. Went back to the previous version and that went through just fine.
Angryunibrow
First Man:
Temp Build - Hangs on wait...
@yusesope - let me know if I can supply you anything when this hangs on wait... On the temp build.
V.0.0.2 - Processed just fine to 100% first try.
V.0.0.2 Mediainfo:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 20 min
Bit rate                                 : 65.6 Mb/s
Bits/(Pixel*Frame)                       : 0.330
Stream size                              : 64.6 GiB (94%)
Maximum Frame-Average Light Level        : 285 cd/m2
Audio
Codec ID                                 : 131
Maximum bit rate                         : 4 533 kb/s
Stream size                              : 452 MiB (1%)
Remember I use eac3to to extract all my BL & EL files, and have had zero issues.
Everyone who are having issues maybe try eac3to and see what happens.
Its been zero issues on all moves for me so far.
