rosavanwinkle
Post by rosavanwinkle »
hepe9 wrote: Thu Mar 12, 2020 2:06 pm
SamuriHL wrote: Thu Mar 12, 2020 12:36 pm
hepe9 wrote:
Yeah, it's easy, paid media player. But this doesn't happen
Powerdvd is a paid media player and they don't have a license for it. Given that, I doubt we'll see it any time soon. I suspect we'll see TVs that negate the need for it before we see it on the pc.
We need to wait until next month, for powerdvd20
If not come with DV, possibly we "never" have DV in Pc
From what i read. People doubt that it will come too powerdvd20 a lotpeople have given up on that program years ago :/
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Post by shawnc22 »
yusesope wrote: Thu Mar 12, 2020 2:00 pm
I can assure you that the tool works: the batch file (the one with the .bat extension) starts the program expecting to work with huge files (and not with 90MB files). To combine the two example HEVC raw streams you have to launch my tool using the command line:
ah got it, it was definitely the file size issue then. I've tried multiples full files and they've all worked beautifully.
i can get you a snippet of the doctor sleep tracks later today if nobody else has gotten to it yet by then
Post by mike admin »
yusesope wrote: Thu Mar 12, 2020 2:00 pmI have rendered every single frame of a FEL (Terminator) and an MEL (Joker) stream.
Thanks for doing this! This is amazing discovery that sums it up nicely.
yusesope wrote: Thu Mar 12, 2020 2:00 pmHowever, I believe it is appropriate to keep it.
100% Agree, MakeMKV will never do "dvd fab method" - the cost of keeping EL is negligible and benefits are many.
From what I see, the DV decoding process must be triggered externally. In m2ts such trigger is DV PSI descriptor, in mp4 - the presence of DV dsi box.
My current MKV samples store no DV metadata in codec private area - once I add the support I'll update the samples and hopefully this would give the start to DV support in MKV container.
Angryunibrow
Post by Angryunibrow »
RESET_9999 wrote: Tue Mar 10, 2020 11:14 pm
Arbigator wrote: Tue Mar 10, 2020 8:55 pm
shawnc22 wrote: Tue Mar 10, 2020 8:14 pm what movies have you tried? I can maybe give it a try later tonight if I have it in my library
I tried Joker, Doctor Sleep, First Man, and Spectre.
yep, I think Doctor Sleep EL is not processed. It gives me an error with V1 tool and with V2 tool , EL analyzing stays at 0%.
Ok got Doctor Strange to process just fine, I always use EAC3TO to extract my BL.hevc and EL.hevc layers.
V2 of the tool processed the file to 100% just fine.
But when I mux it in TSMuxer this is what I get, and take a look at the Mediainfo output. There is no Dolby Vision (only HDR10+)
Video
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration                                 : 2 h 32 min
Bit rate                                 : 66.9 Mb/s
Bits/(Pixel*Frame)                       : 0.337
Stream size                              : 71.1 GiB (94%)
Maximum Content Light Level              : 745 cd/m2
Maximum Frame-Average Light Level        : 47 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 347 kb/s
Stream size                              : 696 MiB (1%)
Number of dynamic objects                : 15
Post by SamuriHL »
mike admin wrote: Thu Mar 12, 2020 2:51 pm
:shock: :shock: :shock: That would be FANTASTIC! Now I'm getting excited about DV backups. I have a ton of DV UHD's and usually I just use madvr tonemapping with HDR, but, if I can make an MKV that has both....WOA!
jayper
Post by jayper »
DaMacFunkin
Post by DaMacFunkin »
The conversations I have had with Nvidia staff seem to sugest that Dolby Vision will never support MKV container ???
Post by SamuriHL »
Not super relevant. If we can take an MKV output with DV and convert it to TS then we have a viable backup solution. Maybe some day they'll decide MKV is good or maybe they won't. But for now, this would still be a usable solution.
rosavanwinkle
May i ask? why is everyone so focused on MKV? why not mp4 etc.? dumb question possibly
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by SamuriHL »
MP4 doesn't technically support many of the things that MKV supports such as HD Audio and blu-ray type subtitles.
MP4 may be limited, but, for enough money, the spec will "magically" support additional things.
Graphic subtitles like VOBSUB and PGS aren't supported because the people who created them do not WANT them in MP4. That might encourage piracy, don'cha know!
Post by SamuriHL »
Righttttt cause I spent many thousands of dollars building a high end home theater system with 7.1.2 ATMOS sound, 65" OLED, UB820 UHD player, high end HTPC, 20 TB NAS, SHIELD, Firestick 4k....so I could pirate content. SMFH. (And no, I know you were being sarcastic). But yea, these formats can be a pain in the ass. Which is why I don't currently bother backing up the DV part of it and just use my high end HTPC to tone map with madvr.
justinadams
Post by justinadams »
Welp, i'm stumped.
I can't seem to get Joker to process to single layer correctly.
I just did Alita and it worked without issue. Demux with tsmuxer (the one that has the folder name of "tsMuxer test"), yusesope's v2 tool, remux to ts with tsmuxer. I have tried a different copy of joker (just in case), demux with ffmpeg, remux without audio, adjusting the the load_balancing_factor of yuescope's tool (since it was showing either 99.6% or 99.7% of EL once it completed with no error).
only success I have had was with doing a 20 second clip with no audio.
anything suggestions would be much appreciated.
Post by shawnc22 »
justinadams wrote: Fri Mar 13, 2020 5:27 am Welp, i'm stumped.
Same issue with Doctor Sleep. Going through the steps with the whole movie resulted in a 99.2% EL analysis in yusecope's tool and then no DV layer once remuxed back into a TS container. Using a 20s clip, the files go through yusecope's at 100% on everything and the resulting TS with no audio contains both DV and HDR 10+:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration                                 : 19 s 19 ms
Bit rate                                 : 46.1 Mb/s
Bits/(Pixel*Frame)                       : 0.232
Stream size                              : 104 MiB (95%)
yusesope
Post by yusesope »
mike admin wrote: Thu Mar 12, 2020 2:51 pm My current MKV samples store no DV metadata in codec private area - once I add the support I'll update the samples and hopefully this would give the start to DV support in MKV container.
Wonderful
shawnc22 wrote: Fri Mar 13, 2020 5:40 am
Video
Can you both try THIS temporary version (only source code)?
python-3.7.6.amd64\python \path\to\bl_el_rpu_builder_temp_version.py -bl \path\to\BL.hevc -el \path\to\EL.hevc -of \path\to\output.hevc
I imposed a more rigid alignment between the reading and writing processes (in order to avoid that the two layers, BL and EL, are staggered in the output file).
In the event that the counters reach all 100%, wait for the message "Press a button to exit".
