Knives Out - US Retail
johng
Re: Knives Out - US Retail
Post by johng »
FYI, I broke out my really old computer that has an internal LG bluray drive and was able to read the disc, so all is good.
makememe
Post by makememe »
The initial post is correct, 0628, for amazon disc; I checked with procmon as well.
Title information
Name: Knives Out (English)
Source file name: 00628.mpls
Duration: 2:10:13
Chapters count: 16
Segment count: 15
Segment map: 510,505,513,512,502,506,504,519,507,518,520,509,508,503,515
File name: Knives Out_t208.mkv
makemkv suggested :
Title information
Comment: FPL_MainFeature
Source file name: 00180.mpls
Duration: 2:10:22
Chapters count: 17
Segment count: 15
Segment map: 510,501,513,512,502,506,504,519,507,518,520,509,508,503,515
File name: Knives Out-FPL_MainFeature_t01.mkv
Not much of a difference, 505 to 501. Close Mike. Thanks.
cwshore
Post by cwshore »
ChrisCaPWN wrote:
Sat Feb 22, 2020 1:11 am
Rental version is 00234.mpls
Source file name: 00234.mpls
Duration: 2:10:13
Chapters count: 16
Segment count: 15
Segment map: 506,511,519,505,513,510,502,514,507,509,504,516,518,508,515
File name: Knives Out_t90.mkv
6:34:19.9765545 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\02797.m2ts	SUCCESS
6:34:25.3467140 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\03340.m2ts	SUCCESS
6:34:42.8799731 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\03340.m2ts	SUCCESS
6:34:42.8802004 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\02797.m2ts	SUCCESS
6:35:06.8384315 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00506.m2ts	SUCCESS
6:35:07.8909582 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00511.m2ts	SUCCESS
6:35:52.3120919 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00519.m2ts	SUCCESS
6:35:54.9246648 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00505.m2ts	SUCCESS
6:36:25.9009886 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00513.m2ts	SUCCESS
6:36:27.0010794 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00510.m2ts	SUCCESS
6:36:45.1229902 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00502.m2ts	SUCCESS
6:36:46.3064175 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00514.m2ts	SUCCESS
6:37:25.7124633 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00507.m2ts	SUCCESS
6:37:27.3484069 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00509.m2ts	SUCCESS
6:38:13.0941563 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00504.m2ts	SUCCESS
6:38:14.6584158 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00516.m2ts	SUCCESS
6:38:34.6663677 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00518.m2ts	SUCCESS
6:38:35.7495252 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00508.m2ts	SUCCESS
6:38:58.4501001 PM	PowerDVDMovie.exe	6624	CloseFile	G:\BDMV\STREAM\00515.m2ts	SUCCESS
I have been backing up my movies for some time now and depending on posts, such as these, to define which title to rip. I have decided that I want to venture out of this habit and learn how to generate this information myself. Would anyone be able to point me toward a good source of information to do this? Thank you in advance for the information.
moviechamp1859
Post by moviechamp1859 »
can confirm 00234.mpls for redbox version. i ripped and watched the entire movie to confirm as well.
ChrisCaPWN
Post by ChrisCaPWN »
cwshore wrote:
Sun Mar 08, 2020 2:41 pm
Duration: 2:10:13
Chapters count: 16
Segment count: 15
Check out this post by unab0mb. It's a very detail step by step on the process. Hope it helps!
https://www.makemkv.com/forum/viewtopic.php?t=16251
tenjuna
Post by tenjuna »
To add to the long list of replies for Redbox version, I watched the "main feature" 225 after ripping it and it's definitely wrong. 234 seems to be the right call.
therapy80301
Post by therapy80301 »
Title information
Duration: 2:10:13
Chapters count: 16
Segment count: 15
File name: Knives Out_t111.mkv
Though it looks like a retail copy from DVD.com, only rental 00234.mpls/Knives Out_t111.mkv correlates and it does not work for me. It goes out of sequence at 32:24. This disc does not have 628 nor any segment maps starting with 510. They're all 506 for the first segment. New segment map perhaps for DVD.com?
My computer is not capable of playing blu-rays or doing logging with powerdvd.
Any ideas?
ChrisCaPWN
Any ideas?
Check the segment map to see if all of the segments are the same. If they are not, there is going to be issues with proper playback. If it is the same, it's definitely correct.
If it is different, and you have no playback options on your computer, your only option is to go line by line checking the segment maps to find the one that is correct as listed.
ChrisCaPWN wrote:
Thu Apr 02, 2020 2:02 am
Any ideas?
For curiosity, can you run your decrypted folder through GetMPLS and see what playlist is recommended? If the wrong one is recommended (and will probably be), any different m2ts files will be highlighted blue in the playlist/segment window.
therapy80301
Any ideas?
Well, the segment map from my 234.mpls matches those from other 234.mpls segment maps whether they be the same title (111) as mine or different (90). Weird.
therapy80301
Well, the segment map from my 234.mpls matches those from other members' 234.mpls segment maps whether they be the same title (111) as mine or different (90). Weird.
therapy80301
MartyMcNuts wrote:
Thu Apr 02, 2020 3:08 am
Norton doesn't like GetMPLS. Do you, the creator, promise it's safe?
therapy80301 wrote:
Thu Apr 02, 2020 8:43 am
Does Norton like anything these days!! :D
Yes it is safe.
therapy80301
kennova wrote:
Tue Feb 25, 2020 5:50 pm
Yeah I went through it after it ripped. Looks right to me.
Are you sure this map doesn't have an out of order segment at 32:06? Where it cuts to a short segment of Captain America being interrogated by James Bond?
kennova
Post by kennova »
therapy80301 wrote:
Fri Apr 03, 2020 9:08 pm
Yeah I watched the whole movie, and just now I checked again. No issue like that.
