tested, same thing. came up as hdr10 only. I know it can play a dolby vision.ts file as it play the one from LG's sitemike admin wrote: Wed Mar 11, 2020 6:26 pmThis could be an explicit container check. Can you please try converting MKV file to TS and see if it changes anything at all.thetoad wrote: Wed Mar 11, 2020 5:30 pm the mkv files mike posted when played on my oppo to my sony x940e, they only comes up as hdr10, not dolby vision.
when I play the dolby vision ts files on LG's website (https://4kmedia.org/lg-amaze-dolby-vision-uhd-4k-demo/) they come up as dolby visionCode: Select all
ffmpeg -i Joker_BL_EL_RPU.mkv -c copy Joker_BL_EL_RPU.ts
vlc shows the codec for the one from LG as
Codec: Dolby Vision HEVC (H.265) (dvhe)
while for my ffmpeg copied, it shows
Codec: MPEG-H Part2/HEVC (H.265) (hevc)
