kws53
Post by kws53 »
With Plex client on HTPC, should I use the TS dual layer or single layer method? Dual layer being easiest...
yusesope
Post by yusesope »
I agree on everything except on these statements:
mike admin wrote: Tue Mar 10, 2020 8:16 pm DV streams may have different profiles and configurations.
Single layer: Video + RPU stream
Double layer: Video (base) layer + Video (extension) layer (difference between 12bit and 10bit picture) + RPU stream.
Profile 7 is always double-layer and may be authored in FEL (full EL) or MEL configuration (minimal EL). In MEL configuration the video extension layer contains all zero pictures (no 12-bit data) and could be safely discarded.
I believe that it is not possible to discard anything.
Regardless of the type of EL (fEL or mEL), in the case of a dvhe.04 or dvhe.07 profile, the Dolby Vision Composer accepts synchronized decoded BL and EL video frames and metadata information and uses metadata to reconstruct 12bit Dolby Vision video.
In support of this hypothesis, I took a look at the data in the header of a NAL RPU:
############### MEL RPU ###############
forbidden_zero_bit: 0
nal_unit_type: 62
nuh_layer_id: 0
nuh_temporal_id_plus1: 1
rpu_type: 2
rpu_format: 18
vdr_rpu_profile: 1
vdr_rpu_level: 0
vdr_seq_info_present_flag: 1
chroma_resampling_explicit_filter_flag: 0
coefficient_data_type: 0
coefficient_log2_denom: 23
vdr_rpu_normalized_idc: 1
BL_video_full_range_flag: 0
BL_bit_depth_minus8: 2
EL_bit_depth_minus8: 2
vdr_bit_depth_minus_8: 4
spatial_resampling_filter_flag: 0
reserved_zero_3bits: 0
el_spatial_resampling_filter_flag: 1
disable_residual_flag: 0
vdr_dm_metadata_present_flag: 1
use_prev_vdr_rpu_flag: 0
vdr_rpu_id: 0
mapping_color_space: 0
mapping_chroma_format_idc: 0
num_pivots_minus_2: [0, 0, 0]
pred_pivot_value: [[0, 1023], [0, 1023], [0, 1023]]
nlq_method_idc: 0
num_x_partitions_minus1: 2046
num_y_partitions_minus1: 0
############### FEL RPU ###############
nal_unit_type: 62
nuh_layer_id: 0
rpu_type: 2
rpu_format: 18
vdr_rpu_profile: 1
vdr_rpu_level: 0
vdr_rpu_id: 0
num_pivots_minus_2: [7, 0, 0]
pred_pivot_value: [[0, 128, 128, 128, 128, 128, 128, 128, 127], [0, 1023], [0, 1023]]
nlq_method_idc: 0
The vdr_bit_depth parameter specifies the bit depth of the reconstructed Dolby Vision video signal.
This is derived by vdr_bit_depth = vdr_bit_depth_minus8 + 8
vdr_bit_depth_minus8 is equal to 4 in both fEL and mEL stream (so vdr_bit_depth = 12)
I leave you the code to analyze the header of an RPU (HERE)
mike admin wrote: Tue Mar 10, 2020 8:16 pm Also, can anyone find a good sample for FEL stream of roughly the same duration - 23 seconds, about 100 MB? Please PM/email me if you have M2TS and I'll produce MKV out of it.
I made two Terminator clips (fEL). I had difficulty cutting the movie so, for safety, I made two clips one of 20sec and one of 40 sec. Find everything HERE
I have not converted the raw HEVC stream to m2ts because I have not followed the events related to tsMuxeR (I have not yet understood why a BL + EL + RPU stream is flagged as dvhe.08).
If someone wants to take care of it, find everything you need at the previous link.
mike admin wrote: Tue Mar 10, 2020 8:16 pm Please try both samples and post the results...
At the moment I can't test anything because I don't have any device that supports Dolby Vision.
My Dolby Vision are a series of hexadecimal codes that scroll across the screen :lol:
Post by shawnc22 »
yusesope wrote: Wed Mar 11, 2020 3:33 pm I have not converted the raw HEVC stream to m2ts because I have not followed the events related to tsMuxeR (I have not yet understood why a BL + EL + RPU stream is flagged as dvhe.08).
Is it possible that because it's being flagged as dvhe.08, the EL is being ignored on playback even though the DV flag is triggered? This could explain why somebody previously reported that the credit scene in power rangers did not look like it was in DV even though DV was on. Unfortunately can't do any eye comparison tests on my own as I don't have a DV-capable UHD player either
yusesope
Post by yusesope »
shawnc22 wrote: Wed Mar 11, 2020 3:55 pm Is it possible that because it's being flagged as dvhe.08, the EL is being ignored on playback even though the DV flag is triggered? This could explain why somebody previously reported that the credit scene in power rangers did not look like it was in DV even though DV was on.
Could be.
The only profiles that support BL + EL + RPU are 4 and 7 (6 is no longer in use).
mp4muxer should be used for testing purposes.
jkatchy2
Post by jkatchy2 »
yusesope wrote: Wed Mar 11, 2020 4:08 pm Could be.
I am trying to use your tool to create BL + EL + RPU, i have extracted BL & EL hevc streams from my mkv using ffmpeg but the tool always exists out at
BL ANALYSYS: 100.0% EL ANALYSYS 0.0% BL_EL_RPU WRITING 89.8%
i tried demuxing with tsMuxer same result .With eac3to it worked , but the playback after muxing with mp4muxer is very dark and colors are washed out .
Using HDD via USB on B9
mattmarsden
Post by mattmarsden »
Arbigator wrote: Wed Mar 11, 2020 12:07 am
shawnc22 wrote: Tue Mar 10, 2020 11:40 pm
RESET_9999 wrote: Tue Mar 10, 2020 11:14 pm
yep, I think Doctor Sleep EL is not processed. It gives me an error with V1 tool and with V2 tool , EL analyzing stays at 0%.
I was going to give that a try, too, when I got home, but I can try First Man also. I'm wondering if it might be because the Doctor Sleep disc is also in HDR10+. The EL might be a little different in that case?
That's interesting, I didn't realize it's in HDR10+, though that explains the descriptor in mediainfo. The file did not give any errors in the tool, and it did finish to 100%.
Same with Power Rangers
thetoad
Post by thetoad »
the mkv files mike posted when played on my oppo to my sony x940e, they only comes up as hdr10, not dolby vision.
when I play the dolby vision ts files on LG's website (https://4kmedia.org/lg-amaze-dolby-vision-uhd-4k-demo/) they come up as dolby vision
Post by mike admin »
yusesope wrote: Wed Mar 11, 2020 3:33 pm I believe that it is not possible to discard anything.
Ok, I'm reading the Dolby "profiles and levels" spec:
2.1.1 Notes to profiles
For profile 4:
A new Dolby Vision certified device is able to decode a profile 4 MEL bitstream without instantiating a secondary HEVC decoder for the enhancement layer.
For profile 7:
The MEL can be used for profile 7 to minimize the processing requirements for the enhancement layer and therefore ensure broader use among UltraHD Blu-ray SoCs.
6.2 Annex II: Differentiating MEL and non-MEL bitstreams
Pictures contained in a Dolby Vision bitstream can be encoded as either MEL or non-MEL, not both.
If a Dolby Vision playback device supports Dolby Vision profile 4 and chooses not to instantiate a second HEVC decoder, then it must check for these values in the
reference processing unit of a Dolby Vision bitstream.
If a Dolby Vision playback device supports Dolby Vision profile 7, it can check for these values in the reference processing unit of a Dolby Vision bitstream.
So the rules are indeed different for profile 4 and profile 7.
Profile 4 - the doc explicitly states that the whole secondary decoder may be not instantiated at all (EL data discarded).
Profile 7 - the vague note that knowing about MEL can "minimize the processing requirements for the enhancement layer". I assume the same - no need to instantiate a second HEVC decoder, just generate same gray pictures as in profile 4.
And the fact that "dvdfab method" (BL+MEL RPU only, EL discarded) works, kind of proves that. Am I wrong?
yusesope wrote: Wed Mar 11, 2020 3:33 pm vdr_bit_depth_minus8 is equal to 4 in both fEL and mEL stream (so vdr_bit_depth = 12)
Of course, EL is always 12 bit on blu-ray. The question is what exactly is in these 2 extra bits. My hypothesis - in MEL stream all pictures in EL are filled with the same value (zeroes). This is easy to verify though - one just has to decode entire EL from any MEL disc (Joker) and confirm that ALL frames in EL are indeed dark zero pictures. From the sizes of slice NALU it looks that way.
thetoad wrote: Wed Mar 11, 2020 5:30 pm the mkv files mike posted when played on my oppo to my sony x940e, they only comes up as hdr10, not dolby vision.
This could be an explicit container check. Can you please try converting MKV file to TS and see if it changes anything at all.
ffmpeg -i Joker_BL_EL_RPU.mkv -c copy Joker_BL_EL_RPU.ts
Arbigator
Post by Arbigator »
mike admin wrote: Wed Mar 11, 2020 6:26 pm
I converted the mkv files you posted to ts with tsMuxer, and they both playback correctly triggering Dolby Vision on the 2019 Shield.
ragico
Post by ragico »
I too converted your files with tsmuxer. In firestick 4k both files trigger Dolby Vision via Plex app (beta)
In emby app they trigger hdr
Arbigator wrote: Wed Mar 11, 2020 9:41 pm I converted the mkv files you posted to ts with tsMuxer, and they both playback correctly triggering Dolby Vision on the 2019 Shield.
So this IS just a container check, and hardware can use this encoding method. We're good!
ragico wrote: Wed Mar 11, 2020 10:50 pm I too converted your files with tsmuxer. In firestick 4k both files trigger Dolby Vision via Plex app (beta). In emby app they trigger hdr
Guys, please make sure to use the very latest tsmuxer from doom9 (the one that supports EL NALUs) or any version of ffmpeg with "-c copy", in order to preserve all data during container conversion.
Angryunibrow
Post by Angryunibrow »
mike admin wrote: Wed Mar 11, 2020 11:11 pm
So what does all this mean exactly :lol:
Are we going to be able to make DV files in Makemkv and convert them to .TS?
Angryunibrow wrote: Wed Mar 11, 2020 11:19 pm So what does all this mean exactly :lol:
Yes, in the next version.
But, hopefully, even with current MKV samples we will be able to bug and poke firmware and playback software authors, so they add support for MKV container when they check for the possible DV data. Plex looks like a first candidate to me...
Angryunibrow
mike admin wrote: Wed Mar 11, 2020 11:30 pm
Keeping HD Audio (Atmos) in tact I presume?
