Debug log started at Sat Oct 23 00:14:22 2010 , written by MakeMKV v1.6.2 darwin(x86-release)
001003:0020 DEBUG: Code 6012928 at %a(hQ[u}Mej6J/Dkv"A#(:":213130007
001005:0000 MakeMKV v1.6.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Jonathan/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZF1E" opened in OS access mode.
003028:0000 Title #0 was added (40 cell(s), 2:19:35)
003025:0000 Title #1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/JONATHAN/All Movie
001003:0020 DEBUG: Code 131072 at 3~m}[v]LRkh{chT.h`d&}P:121262256
001003:0020 DEBUG: Code 0 at ^cx@]Mg&<Tvv+=#VX:29395287
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 0 to file /Volumes/JONATHAN/All Movie/t00_BATMAN_BEGINS.mkv
005004:0080 0 titles saved, 1 failed
Batman Begins usa version failed to save
- Contact:
Re: Batman Begins usa version failed to save
It's a disc write error, you might have ran out of space on target drive.
thats strange, i had it set up so that it would go straight to my external hard drive, which has plenty of space.
i tried it again, this time, setting the target to be my desktop and it worked just fine. what i dont get is, there is PLENTY of space on my external hard drive, so why did it fail when that was the target location? after i successfully ripped the dvd to my desktop, i just moved it to my external drive.
I figured out why I was getting that error. My external harddrive was formatted as FAT32 which only allows file transfers of 4gb. Since The mkv file was bigger than that it wouldn't let me and error out.
