Charlies Angels 2019 Blu-Ray playlist/segment map for RB?
Fade2nada
Post by Fade2nada » Tue Mar 10, 2020 10:27 pm
Does anyone know which playlist/segment map to use for the Charlies Angels 2019 Blu-Ray from redbox?
isuzudave
Re: Charlies Angels 2019 Blu-Ray playlist/segment map for RB?
Post by isuzudave » Tue Mar 10, 2020 11:23 pm
You would have better luck posting this in the Blu-Ray discs section.
JayWalker
Post by JayWalker » Wed Mar 11, 2020 4:03 pm
Fade2nada wrote: Tue Mar 10, 2020 10:27 pm Hello,
On my disc the mpls (segment) options are 356 (357), 369 (1,357), 370 (356,357), 371 (1,357) nd 372 (356,357) where segment 1 is the Sony Intro Logo, segment 356 is the China Films Introp logo and segment 357 is the feature film. So I'm using mpls 369 (Sony logo + Feature Film). This is for the standard purchase disc from Amazon but I suspect the same pattern would be used for Red Box.
walkead
Post by walkead » Wed Mar 11, 2020 4:11 pm
JayWalker wrote: Wed Mar 11, 2020 4:03 pm
Can you share how you are reviewing the content of each of those mpls (segments)? Do you have a tool other than MakeMKV? Thank you!
Grauhaar
Post by Grauhaar » Wed Mar 11, 2020 5:41 pm
walkead wrote: Wed Mar 11, 2020 4:11 pm Can you share how you are reviewing the content of each of those mpls (segments)? Do you have a tool other than MakeMKV? Thank you!
Make a decrypted backup with MakeMKV and you can yiew each stream segment with VLC.
Good Luck :)
tobunk
Post by tobunk » Wed Mar 11, 2020 9:01 pm
Just curious if you have any idea what the difference between 369 and 371 are?
Terasaka
Post by Terasaka » Tue Mar 17, 2020 10:31 pm
Does anyone have correct mpls file for RB version?
hvnphoto
Post by hvnphoto » Wed Mar 18, 2020 2:54 am
Use 371.
Terasaka
Post by Terasaka » Wed Mar 18, 2020 2:57 pm
