Yeah that seems likely to be the issue. The only file I've tried is listed as Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible, same as the one in the post I linked. Are you also using the same tsmuxer version linked in that post?Arbigator wrote: ↑Tue Mar 10, 2020 7:20 pmThanks for that link, that file plays back correctly. Oddly enough, I hadn't looked at the mediainfo. Doing so now, the files I created show this for the video: SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatibleshawnc22 wrote: ↑Tue Mar 10, 2020 6:49 pm
The sample posted here: viewtopic.php?f=12&t=18602&start=1485#p85786 activates DV and Atmos on the Shield. Have you tried opening your files in mediainfo to see what's listed?
None of them show Dolby Vision in mediainfo, not even the HEVC file output by yusesope's tool... I guess something is going wrong there then?
Yes, I am using that version. I've tried others as well. Hmm... This is weird that it's working for everyone else.shawnc22 wrote: ↑Tue Mar 10, 2020 7:24 pmYeah that seems likely to be the issue. The only file I've tried is listed as Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible, same as the one in the post I linked. Are you also using the same tsmuxer version linked in that post?Arbigator wrote: ↑Tue Mar 10, 2020 7:20 pmThanks for that link, that file plays back correctly. Oddly enough, I hadn't looked at the mediainfo. Doing so now, the files I created show this for the video: SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatibleshawnc22 wrote: ↑Tue Mar 10, 2020 6:49 pm
what movies have you tried? I can maybe give it a try later tonight if I have it in my library
- Contact:
First of all , thanks a lot for doing this! You did write the history.
Now, to avoid some confusion, let me sum it up and please correct me if I'm wrong on any account.
DV streams may have different profiles and configurations.
Single layer: Video + RPU stream
Double layer: Video (base) layer + Video (extension) layer (difference between 12bit and 10bit picture) + RPU stream.
Profile 7 is always double-layer and may be authored in FEL (full EL) or MEL configuration (minimal EL). In MEL configuration the video extension layer contains all zero pictures (no 12-bit data) and could be safely discarded.
Old devices with old DV profile 7 implementation don't know about MEL and require EL stream.
Some new "slow and crappy" devices can only decode profile 7 MEL configuration and choke on non-empty EL stream.
Double layer configuration may be encoded as single-PID or dual-PID in M2TS file. Note: "Double layer" is not equal to "dual-PID", and in fact these are orthogonal.
Conversion from dual-PID encoding to single-PID encoding is publicly documented in freely-available Dolby encoding spec, and implemented in dolby mp4muxer.
UHD Blu-ray always use DV profile 7 double-layer in M2TS container, in FEL or MEL configuration, encoded as dual-PID.
The "Joker" sample is dvhe.07 double-layer MEL stream.
Joker_BL_EL_RPU ("my program - first version") is a full double-layer transcode from dual-PID to single-PID encoding: BL + EL + RPU.
Joker_BL_RPU ("second version - identical to that of DVDFab") is MEL-optimized transcoding from dual-PID to single-PID encoding: BL + RPU. The (empty) EL is dropped.
Both samples can be easily encoded as MKV, and available at http://www.makemkv.com/download/dv/
(a) Most devices should be able to play both MKV samples.
(b) Devices with old implementation could choke on Joker_BL_EL_RPU
(c) Low-power devices may only handle Joker_BL_RPU. These devices won't be able to play FEL streams.
Please try both samples and post the results. Also, as mentioned before, please point out if you see anything wrong. If everything looks good, then probably we should start a "compatibility" thread with a summary sticky post like:
device - compatibility status.
Also, can anyone find a good sample for FEL stream of roughly the same duration - 23 seconds, about 100 MB? Please PM/email me if you have M2TS and I'll produce MKV out of it.
are you saying those 2 mkv samples should trigger DV ? just looking at the mediainfo, there isnt any EL or RPU information
- Contact:
Yes. Guess not so much software could handle DV in MKV yet...RESET_9999 wrote: ↑Tue Mar 10, 2020 8:32 pmare you saying those 2 mkv samples should trigger DV ? just looking at the mediainfo, there isnt any EL or RPU information
Tried both MKV files on a 2019 Shield via Plex, and a LG B9 via the plex app with no Dolby Vision. HDR playback only.
That's been the case and I don't see it changing any time soon.mike admin wrote: ↑Tue Mar 10, 2020 8:56 pmYes. Guess not so much software could handle DV in MKV yet...RESET_9999 wrote: ↑Tue Mar 10, 2020 8:32 pmare you saying those 2 mkv samples should trigger DV ? just looking at the mediainfo, there isnt any EL or RPU information
built_to_chill
@mike_admin as regards the Sony X700 I’m afraid DV in mkv won’t work. If I gather correctly your asking for feedback for different devices.
As you may be aware the X700 has a strange DV implementation that does not auto-engage. It is either on for all UHDs (forced DV where there is no DV) or off for all UHDs.
This behaviour is the same for .ts files. But, by contrast, DV is effectively forced off for mkvs.
yep, I think Doctor Sleep EL is not processed. It gives me an error with V1 tool and with V2 tool , EL analyzing stays at 0%.
I was going to give that a try, too, when I got home, but I can try First Man also. I'm wondering if it might be because the Doctor Sleep disc is also in HDR10+. The EL might be a little different in that case?RESET_9999 wrote: ↑Tue Mar 10, 2020 11:14 pmyep, I think Doctor Sleep EL is not processed. It gives me an error with V1 tool and with V2 tool , EL analyzing stays at 0%.
That's interesting, I didn't realize it's in HDR10+, though that explains the descriptor in mediainfo. The file did not give any errors in the tool, and it did finish to 100%.shawnc22 wrote: ↑Tue Mar 10, 2020 11:40 pmI was going to give that a try, too, when I got home, but I can try First Man also. I'm wondering if it might be because the Doctor Sleep disc is also in HDR10+. The EL might be a little different in that case?RESET_9999 wrote: ↑Tue Mar 10, 2020 11:14 pmyep, I think Doctor Sleep EL is not processed. It gives me an error with V1 tool and with V2 tool , EL analyzing stays at 0%.
hey has anyone who uses MX Player on the Shield Pro tried just starting a video-track only dv mp4, and then pausing, going to menu - audio - open, then choosing your audio.thd atmos file from its folder? curious if this worked the whole time and we didn't have to figure out how to mux it in. I can do this on the firestick 4k fine, but only with dd+ or pcm 7.1 since it doesn't do hd-audio.
deadchip12
I followed your instruction but .ts file does not play on my c9's internal media player.ATD555 wrote: ↑Tue Mar 10, 2020 2:37 pmYou should try using TSMuxer and just throw the original video file in it and remux to a .ts using this build of TSMuxer: https://drive.google.com/open?id=1Gq5TA ... B1io4OwHW9deadchip12 wrote: ↑Tue Mar 10, 2020 9:40 amLG Oled C9 via external hdd.
One question though: Gemini man dolby vision does not play at the correct 60 fps using the original method (remux two HEVCs layers into an MP4 container using mp4muxer). Will it play correctly using the new method (remux two HEVCs layers into an .ts container using yusesope's tool)?
