Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Locked
Re: Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Post by Billycar11 » Tue Mar 03, 2020 9:57 pm
SamuriHL wrote: Tue Mar 03, 2020 9:48 pm
Meh, not if they keep it in the family. :) NS55 firmware, as an example.
that's why i said and or have slower speeds with lg non NS60 firmware or the possibility of not burning discs with asus firmware both have sleep bug.
captainbdsc
Post by captainbdsc » Tue Mar 10, 2020 2:41 pm
I have a 11year old Lite-On iHOS104-08 Blu-ray drive. Is there a firmware that would make it a LibreDrive?
Post by Woodstock » Tue Mar 10, 2020 3:03 pm
Probably not, but not impossible. MakeMKV will recognize it and display a "LibreDrive status" if it is possible.
Getting it to read UHD disks, however, is not possible. The hardware doesn't support it.
bramezan06
Post by bramezan06 » Fri Mar 13, 2020 6:51 pm
I just purchased a LG WH16NS60 drive and when I open makemkv it doesnt't detect the drive. I came across this post and decided to give it a try. When I open the firmware flash utility and select the firmware I want it goes to 100% then says update failed. I've tried it many times with no luck. Can someone provide some assistance?
Post by Billycar11 » Fri Mar 13, 2020 8:40 pm
bramezan06 wrote: Fri Mar 13, 2020 6:51 pm I just purchased a LG WH16NS60 drive and when I open makemkv it doesnt't detect the drive. I came across this post and decided to give it a try. When I open the firmware flash utility and select the firmware I want it goes to 100% then says update failed. I've tried it many times with no luck. Can someone provide some assistance?
You have an amd system correct? This causes the false flash fail it is flashed it just says it failed.
Now for the not showing up in makemkv that is not caused by firmware it should show up without flashing I believe this problem is related to ransomware protection in windows defender disable it or make an exception for makemkv
bramezan06
Post by bramezan06 » Fri Mar 13, 2020 9:42 pm
Billycar11 wrote: Fri Mar 13, 2020 8:40 pm
I do have an amd system. When I open makemkv it gives the following message....
"The program can't find any usable optical drives"
bramezan06
Post by bramezan06 » Fri Mar 13, 2020 11:18 pm
I finally got it to see the drive but I am now experiencing another problem. I get this message after reading the disc...
"The volume key is unknown for this disc - video can't be decrypted
Failed to open disc"
The movie is a 4k UHD disc
Post by Billycar11 » Sat Mar 14, 2020 12:01 am
bramezan06 wrote: Fri Mar 13, 2020 9:42 pm
Yes I am aware like I said change the windows defender settings
pippinainteasy
Post by pippinainteasy » Wed Apr 15, 2020 12:47 am
I just purchased a new drive, went ahead and flashed it and now it keeps dropping the drive. I will start to rip and then will error out and drop the drive requiring a restart. I have also turned off the windows defender as previously stated with no luck.
MakeMKV v1.15.0 win(x64-release) started
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '33364506624'
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '32768'
here are the errors I am receiving along with a picture of the drive information.
edit: this is an AMD system if that makes a difference
icarus
Post by icarus » Sun Apr 19, 2020 6:24 pm
If I bought this drive and it came with firmware 1.3, I take it I'm out of luck?
Post by Billycar11 » Sun Apr 19, 2020 10:12 pm
icarus wrote: Sun Apr 19, 2020 6:24 pm If I bought this drive and it came with firmware 1.3, I take it I'm out of luck?
Makemkv drive info screenshot please or copy paste
icarus
Post by icarus » Mon Apr 20, 2020 9:07 pm
Billycar11 wrote: Sun Apr 19, 2020 10:12 pm
So, it would appear I need to get my eyes checked. It's ROM Ver. 1.02
Sorry for the dumb post
StormMeows
Post by StormMeows » Sat May 02, 2020 2:35 am
Is this guide still relevant in 2020? I just got this drive and I'm going to be flashing it soon. I have 1.02 firmware on this new drive.
pippinainteasy
Post by pippinainteasy » Sun May 03, 2020 12:14 am
StormMeows wrote: Sat May 02, 2020 2:35 am Is this guide still relevant in 2020? I just got this drive and I'm going to be flashing it soon. I have 1.02 firmware on this new drive.
I'm not entirely sure, I followed the guide to flashing the drive and am still not able to rip UHD discs. Blu Rays work fine, though.
Post by Billycar11 » Sun May 03, 2020 2:02 am
pippinainteasy wrote: Sun May 03, 2020 12:14 am
what happens on your UHD discs?
Locked
