Farscape season 4 pilot
rassion
Post by rassion » Tue Oct 26, 2010 3:22 pm
MakeMKV v1.6.2 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Ryan/MakeMKV_log.txt
Title #0 was added (7 cell(s), 0:46:04)
Title #1 was added (7 cell(s), 0:45:52)
Title #2 was added (7 cell(s), 0:45:53)
Title #3 was added (7 cell(s), 0:45:51)
Title #4 was added (28 cell(s), 3:03:40)
Title #5 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #6 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #7 was added (2 cell(s), 0:03:09)
Title #8 was added (1 cell(s), 0:01:58)
Title #9 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #10 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Saving 1 titles into directory G:/FARSCAPE SEASON 4
DEBUG: Code 15 at j0RfYkSza{E~Pv3kZ3a:121262486
DEBUG: Code 0 at s5bo%KjKY^8llu6e0)<S#:29397449
DEBUG: Code 0 at ]8P!K|/(]\$Wlh]G+Ip:121263751
Failed to save title 0 to file G:/FARSCAPE SEASON 4/title00.mkv
0 titles saved, 1 failed
Debug log started at Tue Oct 26 15:06:05 2010 , written by MakeMKV v1.6.2 win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.6.2 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Ryan/MakeMKV_log.txt
003028:0000 Title #0 was added (7 cell(s), 0:46:04)
003028:0000 Title #1 was added (7 cell(s), 0:45:52)
003028:0000 Title #2 was added (7 cell(s), 0:45:53)
003028:0000 Title #3 was added (7 cell(s), 0:45:51)
003028:0000 Title #4 was added (28 cell(s), 3:03:40)
003025:0000 Title #5 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
003025:0000 Title #6 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
003028:0000 Title #7 was added (2 cell(s), 0:03:09)
003028:0000 Title #8 was added (1 cell(s), 0:01:58)
003025:0000 Title #9 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
003025:0000 Title #10 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory G:/FARSCAPE SEASON 4
001003:0020 DEBUG: Code 15 at j0RfYkSza{E~Pv3kZ3a:121262486
001003:0020 DEBUG: Code 0 at s5bo%KjKY^8llu6e0)<S#:29397449
001003:0020 DEBUG: Code 0 at ]8P!K|/(]\$Wlh]G+Ip:121263751
FS ID=<FAILED> C=0
TI=ZeNpjZKAPAAAA0AAC
005003:0000 Failed to save title 0 to file G:/FARSCAPE SEASON 4/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Oct 26 15:08:46 2010
setarip_old
Re: Farscape season 4 pilot
Post by setarip_old » Tue Oct 26, 2010 7:38 pm
Hi!
Have you tried ripping only "Title 4" (It includes all 4 episodes)?
rassion
Post by rassion » Fri Oct 29, 2010 10:17 am
no i have not, i really do not want to even consider it as an option. but to see if it would work - i tried it and now that one fails aswell.
DEBUG: Code 0 at I,cgtni9qTy8FWWmjSi:213133204
Failed to save title 4 to file G:/FARSCAPE SEASON 4/title04.mkv
i doubt it would be the burner, but i have another one on hand - if it would be worth while to swap it out [currently using DVD +R-DL_NEC DVD_RW ND3550A 1.05] - WINDOWS auto update states drivers are upto date aswell
