Pioneer BDR S11J BK Support Sofewere copy 4k UHD
godzillaearth
Post by godzillaearth »
I'm looking for software that supports pioneer bdr s11j bk to copy 4k uhd
Do not know if it has it, if there is, please tell me
Re: Pioneer BDR S11J BK Support Sofewere copy 4k UHD
Pioneer drives are not currently supported for ripping.
Pioneer drives not currently supported for ripping 4k UHD by any software.
godzillaearth
oh so thanks
Now I can't feel it at all.
I tried to return the purchased item but was unable to return it with different terms. This is really bad I have only one item left and I bought it. I am afraid the seller does not want me to return the item because there is only one item left.
The drive will work just fine for DVD and regular bluray, but not for UHD.
