ragico
Post by ragico » Sun Mar 08, 2020 6:01 pm
@yusesope
I fully understand that your tool is not suitable for X700. Still I dont understand why the sample posted by @Reset_9999 works flawlessly.
I also own the firestick 4k. How can I make this kind of file (BL + RPU)?
Thanks again, you are unvaluable
powdeau
Post by powdeau » Sun Mar 08, 2020 6:08 pm
I have tried a new build by a5180007 (https://forum.doom9.org/showthread.php? ... ost1903300), but the DL DV is still only triggered on X700 and not on the LG C7.
Also the reboot bug is still present.
I have noticed that unlike in the previous builds, the second layer says only EL instead of EL+RPU.
Could you please someone inform him about that since I cannot post on that forum yet? Thank you!
Post by RESET_9999 » Sun Mar 08, 2020 7:59 pm
ragico wrote:
Sun Mar 08, 2020 2:57 pm
Very strange as @Reset999 reported everything works on X700 and, in fact, his sample works also on my X700.
Why the fullmovie does not work?
baker99 wrote:
Sun Mar 08, 2020 3:35 pm
Edit: The file won't play on the X700 or C6 though
yusesope wrote:
Sun Mar 08, 2020 4:34 pm
RESET_9999 has reffered several times that my files (with a Single Track) didn't work on the X700 (when muxed inside an mp4).
Maybe the problem also occurs with the ts container.
My tool is addressed to owners of the new Shield 2019 (BL + EL + RPU) or Fire Stick TV 4K (BL + RPU).
@yusesope
it seems to only work with MEL DV movies. I just tried a complete movie (Justice League) and it works on the x700 and the c8.
Then I tried with another movie which is FEL DV and it doesn't work.
ragico
Post by ragico » Sun Mar 08, 2020 8:12 pm
@RESET_9999
How you know if a movie is Mel or Fel?
Post by RESET_9999 » Sun Mar 08, 2020 8:16 pm
by looking at the bitrate/size of the DV layer.
FEL:
DISC INFO:
Disc Title: Rocketman
Disc Size: 88,871,774,262 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.3
PLAYLIST REPORT:
Total Bitrate: 95.73 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 62335 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 /
* MPEG-H HEVC Video 7672 kbps 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
MEL:
Disc Title: Justice League
Protection: AACS2
BD-Java: Yes
Extras: Ultra HD
BDInfo: 0.5.8.7
PLAYLIST REPORT:
Total Bitrate: 68.94 Mbps
VIDEO:
MPEG-H HEVC Video 51650 kbps 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 /
* MPEG-H HEVC Video 67 kbps 1080p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
ragico
Post by ragico » Sun Mar 08, 2020 8:22 pm
thank you
Post by RESET_9999 » Sun Mar 08, 2020 8:58 pm
DL MP4 vs SL BL+EL+RPU Sony x700:
https://slow.pics/c/HDpNH5cC
Angryunibrow
Post by Angryunibrow » Sun Mar 08, 2020 9:52 pm
Besides the focus :) (kidding) looks pretty identical to me
ragico
Post by ragico » Sun Mar 08, 2020 10:06 pm
Any help from somebody?
baker99
Post by baker99 » Sun Mar 08, 2020 10:12 pm
Impressive
Post by RESET_9999 » Sun Mar 08, 2020 10:17 pm
yeah, I think yusesope did it.
this is great work yusesope. DVDFAB is now useless :D
Arbigator
Post by Arbigator » Sun Mar 08, 2020 10:28 pm
Which version of tsMuxer should be used for yusesope's tool? Also, can tsMuxer be used to demux the individual streams and the audio? or do we have to use ffmpeg for that?
Post by RESET_9999 » Sun Mar 08, 2020 10:29 pm
I've been using tsmuxer for demuxing. It works great.
not sure if the newest one works but the one from this post work:
https://www.makemkv.com/forum/viewtopic ... 485#p85786
Arbigator
Post by Arbigator » Sun Mar 08, 2020 10:30 pm
yusesope
Post by yusesope » Sun Mar 08, 2020 10:39 pm
They are identical :D
Right click on the "start_bl_el_rpu_builder.bat" file.
Left click on the "Edit" item.
In the newly opened text file there is this string:
python-3.7.6.amd64\python src\bl_el_rpu_builder.py
Modify it as follows
python-3.7.6.amd64\python src\bl_el_rpu_builder.py -mode 2
Save your changes and try again by double clicking on the "start_bl_el_rpu_builder.bat" file.
The file that will be created will always have the name "BL_EL_RPU.hevc" but in reality it will be a single track single layer file (BL + RPU)
