ragico
Post by ragico » Sun Mar 08, 2020 2:07 pm
yusesope wrote: Sun Mar 08, 2020 12:59 pm
ragico wrote: Sun Mar 08, 2020 12:52 pm @yusesope
thank you- If I have correctly understood the -mp4 is no longer necessary and your file can me used directly in tsmuxer?
According to the latest news, it seems so.
(I haven't tried it yet)
At the beginning, I suggest you always compare the result of tsMuxeR with that of mp4muxer. You are still using a nightly build of tsMuxeR.
Thanks again. I tried your latest build 0.0.2 with a full movie (Rocketman) and the job seems finished but the the windows cmd is still open with this screen
BL ANALYSYS: 100% EL ANALYSYS 100% BL_EL_RPU WRITING 100%
In the tool previous version there was an invite to press any key to close the cmd window. Now thet invite is not appearing since 15 minutes. What should I do?
yusesope
Post by yusesope » Sun Mar 08, 2020 2:23 pm
ragico wrote: Sun Mar 08, 2020 2:07 pm BL ANALYSYS: 100% EL ANALYSYS 100% BL_EL_RPU WRITING 100%
If all the counters have reached 100% you can close the window.
It is strange that the invite to press any key to exit does not appear.
As soon as I can, I'll take a look.
ragico
Post by ragico » Sun Mar 08, 2020 2:25 pm
yusesope wrote: Sun Mar 08, 2020 2:23 pm
Thank you for your help.
yusesope
Post by yusesope » Sun Mar 08, 2020 2:41 pm
Hey ragico, when you have time, can you replace the file in the "src" folder with THIS and try again with the Rocketman file?
Thank you.
ragico
Post by ragico » Sun Mar 08, 2020 2:57 pm
yusesope wrote: Sun Mar 08, 2020 2:41 pm
Thank you.
Underway with the new file you posted.
In meantime Rocketman was complete and I muxed in tsmuxer (test build) adding some audio and pgs.
This .ts file do not play in X700. It does not start.
Same with Alita.
I will do the equivalent mp4s to see what happens.
Very strange as @Reset999 reported everything works on X700 and, in fact, his sample works also on my X700.
Why the fullmovie does not work?
baker99
Post by baker99 » Sun Mar 08, 2020 3:35 pm
Just played a complete movie, single layer ts remux, all the way through using plex on the shield, Atmos and DV both working, no glitches or jumps. I used the first version of the BL + EL +RPU tool.
Edit: The file won't play on the X700 or C6 though
ragico
Post by ragico » Sun Mar 08, 2020 3:45 pm
Thank you.
Now the "invite" is back. Good work yusesope
yusesope
Post by yusesope » Sun Mar 08, 2020 4:34 pm
ragico wrote: Sun Mar 08, 2020 3:45 pm Now the "invite" is back. Good work yusesope
The problem was caused by the movie: evidently Rocketman ends with a data pattern that I had not encountered in the movies I have so far examined.
Thanks @ragico for pointing this out.
I invite those who have downloaded version 0.0.2 to download it again (original post HERE)
ragico wrote: Sun Mar 08, 2020 2:57 pm In meantime Rocketman was complete and I muxed in tsmuxer (test build) adding some audio and pgs.
Same with Alita.
RESET_9999 has reffered several times that my files (with a Single Track) didn't work on the X700 (when muxed inside an mp4).
Maybe the problem also occurs with the ts container.
My tool is addressed to owners of the new Shield 2019 (BL + EL + RPU) or Fire Stick TV 4K (BL + RPU).
If you own an X700 you should not use my tool but you should create a Double Track file (as RESET_9999 explained HERE)
Ask him for more information!
baker99 wrote: Sun Mar 08, 2020 3:35 pm Just played a complete movie, single layer ts remux, all the way through using plex on the shield, Atmos and DV both working, no glitches or jumps. I used the first version of the BL + EL +RPU tool.
Thanks for reporting back
ragico
Post by ragico » Sun Mar 08, 2020 6:01 pm
@yusesope
I fully understand that your tool is not suitable for X700. Still I dont understand why the sample posted by @Reset_9999 works flawlessly.
I also own the firestick 4k. How can I make this kind of file (BL + RPU)?
Thanks again, you are unvaluable
powdeau
Post by powdeau » Sun Mar 08, 2020 6:08 pm
I have tried a new build by a5180007 (https://forum.doom9.org/showthread.php? ... ost1903300), but the DL DV is still only triggered on X700 and not on the LG C7.
Also the reboot bug is still present.
I have noticed that unlike in the previous builds, the second layer says only EL instead of EL+RPU.
Could you please someone inform him about that since I cannot post on that forum yet? Thank you!
Post by RESET_9999 » Sun Mar 08, 2020 7:59 pm
ragico wrote: Sun Mar 08, 2020 2:57 pm Very strange as @Reset999 reported everything works on X700 and, in fact, his sample works also on my X700.
baker99 wrote: Sun Mar 08, 2020 3:35 pm Edit: The file won't play on the X700 or C6 though
yusesope wrote: Sun Mar 08, 2020 4:34 pm RESET_9999 has reffered several times that my files (with a Single Track) didn't work on the X700 (when muxed inside an mp4).
ragico wrote: Sun Mar 08, 2020 6:01 pm @yusesope
it seems to only work with MEL DV movies. I just tried a complete movie (Justice League) and it works on the x700 and the c8.
Then I tried with another movie which is FEL DV and it doesn't work.
ragico
Post by ragico » Sun Mar 08, 2020 8:12 pm
@RESET_9999
How you know if a movie is Mel or Fel?
Post by RESET_9999 » Sun Mar 08, 2020 8:16 pm
by looking at the bitrate/size of the DV layer.
FEL:
DISC INFO:
Disc Title: Rocketman
Disc Size: 88,871,774,262 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.3
PLAYLIST REPORT:
Total Bitrate: 95.73 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 62335 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 /
* MPEG-H HEVC Video 7672 kbps 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
MEL:
Disc Title: Justice League
Protection: AACS2
BD-Java: Yes
Extras: Ultra HD
BDInfo: 0.5.8.7
PLAYLIST REPORT:
Total Bitrate: 68.94 Mbps
VIDEO:
MPEG-H HEVC Video 51650 kbps 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 /
* MPEG-H HEVC Video 67 kbps 1080p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
ragico
Post by ragico » Sun Mar 08, 2020 8:22 pm
thank you
Post by RESET_9999 » Sun Mar 08, 2020 8:58 pm
DL MP4 vs SL BL+EL+RPU Sony x700:
https://slow.pics/c/HDpNH5cC
