I have tried DL DV and unfortunately it shows DV on X700 but not on LG C7 and the colors are washed out. Also the reboot bug remainsRESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmthis modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
SL EL+RPU also now works on the x700( LG TV too) and without the dual-layer TS bug ( play one time, reboot). But this build doesnt work anymore with the dual layer DV remux from uhd-bd
test build:https://drive.google.com/file/d/10zOr0I ... sp=sharing
SL BL+EL+RPU atmos sample: https://drive.google.com/file/d/1n95g_b ... sp=sharing ----->atmos + DV works on shield/plex
Complete name : D:\BL_EL_RPU.ts Format : MPEG-TS File size : 61.0 MiB Duration : 30 s 14 ms Overall bit rate mode : Variable Overall bit rate : 17.0 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 29 s 863 ms Bit rate : 15.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.078 Stream size : 55.4 MiB (91%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 1016 cd/m2 Maximum Frame-Average Light Level : 342 cd/m2 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 MLP FBA 16-ch Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 30 s 17 ms Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 7 158 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 2.29 MiB (4%) Service kind : Complete Main Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE
powdeau wrote: ↑Sun Mar 08, 2020 1:39 amyes, as i said DL is broken on this buildRESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmthis modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
I have tried DL DV and unfortunately it shows DV on X700 but not on LG C7 and the colors are washed out. Also the reboot bug remains![]()
did you try the SL sample ?
Yes, that works flawlessly.RESET_9999 wrote: ↑Sun Mar 08, 2020 1:44 amyes, as i said DL is broken on this build
Angryunibrow
Fully working movie tested (Hobbs and Shaw) on the Shield with Plex.RESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmthis modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
FF worked and Atmos triggered.
I only had an issue with Plex telling me connection to the server was not fast enough and the movie stopped after about 10 minutes.
I'm streaming from a remote server, and this usually doesn't happen. Not sure if it's related to the movie or not. I'll have to keep an eye on it. Haven't had that issue come up yet.
All in all it worked, and to my eyes looked great.
If you are not comparing screenshots all day you would never know if any colors were off to the normal DL Disc.
All in all I think a success, and I'm happy so far.
More watching and testing to be done.
Well, we know it looks the same as Netflix's DV colors on the Shield at least. I haven't seen a seen a huge uproar of Shield users complaining that Netflix wasn't matching disc quality (for colors I mean, obviously netflix is compressed) so it mustn't be that bad. Though it's possible that people who watch Netflix have perhaps never watched its real disc counterpart and don't know any betterAngryunibrow wrote: ↑Sun Mar 08, 2020 3:32 amAll in all it worked, and to my eyes looked great.
Angryunibrow
Agreed, and honestly everyone "sees" colors differently, if you told me it was playing from the actual disc in DL I would not know the difference in a real life watching situation.Grencola wrote: ↑Sun Mar 08, 2020 3:47 amWell, we know it looks the same as Netflix's DV colors on the Shield at least. I haven't seen a seen a huge uproar of Shield users complaining that Netflix wasn't matching disc quality (for colors I mean, obviously netflix is compressed) so it mustn't be that bad. Though its possible that people who watch Netflix have perhaps never watched the real disc counterpart and don't know any betterAngryunibrow wrote: ↑Sun Mar 08, 2020 3:32 amAll in all it worked, and to my eyes looked great.
More watching and testing to be done.![]()
Even the troublesome Joker movie in a real life watching situation you would never even know the colors are off slightly unless you followed this thread and knew about it.
I can confirm that this mp4 plays properly on the Amazon Fire TV Stick 4k and looks great (to my eyes) with no color issues. MX Player was the only app that worked. This is actually the first file that has ever worked, other than Dolby's test samples. Usually just a DV flag with a black screen.yusesope wrote: ↑Thu Mar 05, 2020 5:47 pm
- Joker BL_RPU raw HEVC (my program - second version - identical to that of DVDFab)
No dice on the fire stick, just a green screen with the dv flag active. then flickers and reverts back to hdr10 which looks ok.RESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmSL BL+EL+RPU atmos sample: https://drive.google.com/file/d/1n95g_b ... sp=sharing ----->atmos + DV works on shield/plex
A lot of users probably like the over saturated look, but Nvidia replied to my post and are looking at the issue which is something, I'm sure a lot more pureists would buy the shield if it had perfect reproduction.Grencola wrote: ↑Sun Mar 08, 2020 3:47 amWell, we know it looks the same as Netflix's DV colors on the Shield at least. I haven't seen a seen a huge uproar of Shield users complaining that Netflix wasn't matching disc quality (for colors I mean, obviously netflix is compressed) so it mustn't be that bad. Though it's possible that people who watch Netflix have perhaps never watched its real disc counterpart and don't know any betterAngryunibrow wrote: ↑Sun Mar 08, 2020 3:32 amAll in all it worked, and to my eyes looked great.
Great news, hopefully soon they can combine all the working code into one build to rule them allRESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmthis modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
@RESET_9999
which version of yusesope tool you use? the one with the .old extension or the one without the .old extension?
After that is it necessary to make the .mp4 file with dolby mp4muxer? Or we can mux the bl_el_rpu.hevc file directly in tsmuxer adding audio etc?
Thank you
Thank you
there is a difference. the movie 'midway' has not worked with ''off'.
Great news. To verify the correct implementation, however, make comparisons with the versions obtained through mp4muxer.RESET_9999 wrote: ↑Sat Mar 07, 2020 11:42 pmthis modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
In the meantime, I release version 0.0.2 of my tool (refer to the original post HERE).
For more information take a look at the changelog.
I will not invest much energy in updating the tool (unless a serious error is discovered) because, if my idea proves valid, it will certainly be implemented in "more professional" tools (my code is open and the idea has been explained in detail).
Do all counters reach 100%?
What movie are you trying to mux?
Try also with the new version of my tool.
@yusesope
thank you- If I have correctly understood the -mp4 is no longer necessary and your file can me used directly in tsmuxer?
