mattmarsden
Post by mattmarsden » Fri Mar 06, 2020 2:40 pm
Its definitely the Shield doing something wrong because on my LG C9 the dual layer and Yuescope look identical - I've checked lots of scenes.
baker99
Post by baker99 » Fri Mar 06, 2020 3:08 pm
mattmarsden wrote: Fri Mar 06, 2020 2:40 pm Its definitely the Shield doing something wrong because on my LG C9 the dual layer and Yuescope look identical - I've checked lots of scenes.
That's good news, kind of.
ATD555
Post by ATD555 » Fri Mar 06, 2020 7:30 pm
I know you guys probably don't care but I have a Hisense H8F and it plays all of the test files except for the DV Profile 4.06
The way I play my files is run the .m2ts through TSMuxer and output a TS file that has the Dolby Vision Profile 7 info (EL + RPU) on the second layer. Works great.
ragico
Post by ragico » Fri Mar 06, 2020 9:31 pm
ATD555 wrote: Fri Mar 06, 2020 7:30 pm I know you guys probably don't care but I have a Hisense H8F and it plays all of the test files except for the DV Profile 4.06
How you know that the second layer has the Dolby Vision Profile 7 info before you mux the .ts?
ATD555
Post by ATD555 » Fri Mar 06, 2020 9:34 pm
ragico wrote: Fri Mar 06, 2020 9:31 pm
Well I can assume it does cause I am using files ripped directly from a 4K Dolby Vision disc. If I obtained a file and am unsure whetehr or not it should have Dolby Vision, I consult Blu-Ray.com to confirm.
Post by RESET_9999 » Fri Mar 06, 2020 9:39 pm
If there are two HEVC streams in your original m2ts, then it's in DV.
Arbigator
Post by Arbigator » Sat Mar 07, 2020 2:38 am
Are you using any other settings? or just adding the .m2ts and muxing to .ts? What build are you using? So far I haven't been able to get a .ts file to play on my LG B9 unfortunately.
baker99
Post by baker99 » Sat Mar 07, 2020 11:15 am
I've just posted a support request regarding the colour issues on the Shield forum, if anyone else wants to add comments they would be welcome https://www.nvidia.com/en-us/geforce/fo ... by-vision/
box4m
Post by box4m » Sat Mar 07, 2020 9:12 pm
When trying the bl_el_rpu_builder from yusesope (big thanks, awesome job), i get an outputfile that doesnt appear to be dual layer, its the same size as only the BL and when dropping it into txmuxer for example, its just 1 stream.
I dont know if thats why the next problem occurs(?)
when running:
"mp4muxer.exe -i path\BL_EL_RPU.hevc --dv-profile 4or7 -o path\output_dv.mp4"
i finishes instantly and no output is created
Appreciate some pointers, im not really savvy when it comes to your terminology in this thread but i try to pickup what i can, i consider myself "IT savvy"
kazuma
Post by kazuma » Sat Mar 07, 2020 11:26 pm
does anyone know what 'web optimizer ' is in dvdfab? is it better to leave it on?
Post by RESET_9999 » Sat Mar 07, 2020 11:42 pm
this modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
SL EL+RPU also now works on the x700( LG TV too) and without the dual-layer TS bug ( play one time, reboot). But this build doesnt work anymore with the dual layer DV remux from uhd-bd
test build:https://drive.google.com/file/d/10zOr0I ... sp=sharing
SL BL+EL+RPU atmos sample: https://drive.google.com/file/d/1n95g_b ... sp=sharing ----->atmos + DV works on shield/plex
Complete name                            : D:\BL_EL_RPU.ts
File size                                : 61.0 MiB
Duration                                 : 30 s 14 ms
Overall bit rate                         : 17.0 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 29 s 863 ms
Bit rate                                 : 15.6 Mb/s
Bits/(Pixel*Frame)                       : 0.078
Stream size                              : 55.4 MiB (91%)
Maximum Content Light Level              : 1016 cd/m2
Maximum Frame-Average Light Level        : 342 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 30 s 17 ms
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 2.29 MiB (4%)
Number of dynamic objects                : 15
Angryunibrow
Post by Angryunibrow » Sun Mar 08, 2020 1:07 am
RESET_9999 wrote: Sat Mar 07, 2020 11:42 pm this modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
Video
Audio
Codec ID                                 : 131
Going to test this now on a full movie.
powdeau
Post by powdeau » Sun Mar 08, 2020 1:39 am
Video
Audio
Codec ID                                 : 131
I have tried DL DV and unfortunately it shows DV on X700 but not on LG C7 and the colors are washed out. Also the reboot bug remains :(
Post by RESET_9999 » Sun Mar 08, 2020 1:44 am
powdeau wrote: Sun Mar 08, 2020 1:39 am
yes, as i said DL is broken on this build
did you try the SL sample ?
powdeau
Post by powdeau » Sun Mar 08, 2020 2:31 am
RESET_9999 wrote: Sun Mar 08, 2020 1:44 am yes, as i said DL is broken on this build
Yes, that works flawlessly.
