#1471
Post
by RESET_9999 » Fri Mar 06, 2020 1:05 pm
yusesope wrote: Fri Mar 06, 2020 12:31 pm
RESET_9999 wrote: Fri Mar 06, 2020 12:17 pm
I used the real untouched download from netflix server for the test.. It looks like a real profile 5 file to me.
I do not doubt it.
Mine was a joke.
If the color output is similar to my files, there are two things:
- Netflix is streamming files with the wrong colors (joke)
I am Italian, it doesn't take me much to laugh
haha ok I'm no English native as well so i don't get all the jokes in english
and yes, I think your files might be right. I wish i could compare them with my x700.
I'll try to compare your samples on my TV internal apps but i cannot forward frame by frame like i can with the x700,so its hard to pause at the same place.
I dont say that i dont believe your test result. It's just that I prefer the screenshot comparison(when done properly) as they are not subjective.
RESET_9999 on Fri Mar 06, 2020 2:01 pm, edited 1 time in total.
hepe9
#1472
Post
by hepe9 » Fri Mar 06, 2020 1:38 pm
codeXRes wrote: Fri Mar 06, 2020 12:07 pm
hepe9 wrote: Thu Mar 05, 2020 7:06 pm
@LucasSimba you tried the clips posted for @yusesope?
To see if you have the same results
I tried with the Sony player and the "dvdfab" works but wrongs colors and the other 2 no DV and play in fast speed
I have tried the clips posted by @yusesope on a Sony XF9005; results below.
Plex:
Joker_dvhe.04.06_BL_EL_RPU_Single_Track_Double_Layer.mp4 - DV Logo but over saturated colors (the light bulbs around the mirror are all red).
Joker_dvhe.05.06_BL_RPU_Single_Track_Single_Layer.mp4 - DV Logo but over saturated colors.
Joker_dvhe.07.06_BL_EL_RPU_Single_Track_Double_Layer.mp4 - DV Logo but over saturated colors.
Joker_dvhe.07.06_Double_Track_Double_Layer.mp4 - No DV Logo; played as HDR.
Video Player:
Joker_dvhe.04.06_BL_EL_RPU_Single_Track_Double_Layer.mp4 - No DV Logo; played as HDR.
Joker_dvhe.07.06_BL_EL_RPU_Single_Track_Double_Layer.mp4 - No DV Logo; played as HDR.
So we can say the owners of this TV we can't do nothing
PD: thanks for the test
hepe9
#1473
Post
by hepe9 » Fri Mar 06, 2020 1:44 pm
built_to_chill wrote: Fri Mar 06, 2020 12:53 pm
hepe9 wrote: Fri Mar 06, 2020 11:29 am
built_to_chill wrote: Fri Mar 06, 2020 9:25 am
That's interesting. FWIW - and that is probably very little since this is very much "hearsay" - my pro calibrator (who is well qualified and does a lot of stuff for commercial Movie/TV productions as well as consult TV manufacturers) was negative about the implementation of DV in the 2019 SHIELD. We didn't discuss in any detail (because I had decided not to buy one) but I wonder if this is what he was referring to.
Maybe I don't understand you because English is not my languague, but you say you know a person who has knowledge in this area, you know what he thinks about DV in Sony TVs? all I have read is that it is more darkness than other manufacturers
It’s off the topic of this thread, and I’d be doing a dis-service to my calibrator to go into details about how he achieves what he does (it’s a professional service) but Dolby Vision on my Sony AF9 was dramatically improved by calibration.
I wasn’t fussed about Dolby Vision vs HDR10 before calibration (I often found DV a bit dark) and this is why I was happy archiving my UHDs in a way that I expected would only ever allow HDR10. But that all changed post calibration. So no - DV is not “broken” on Sony, I know this does get banded about. However, in my experience calibration made a massive difference - much brighter and punchier afterward, and now there is a clear difference between HDR10 and DV. I am now firmly of the opinion that when investing in an OLED, one should budget an extra 10% or so for calibration. These are very expensive TVs - we buy them for accuracy, shadow detail etc, but - again in my experience - calibration takes it to another level.
I mention my TVs model number because it allows 20pt correction (not sure if earlier Sony models do). I also stress the importance of finding a skilled calibrator who knows what they are doing to achieve this. For anyone in the U.K. who’s interested I used “display and sound calibration” (easy to google). I believe the only ISF level 3 certified calibrator in the U.K.
Back to Sony TVs... I’d also briefly add that some well respect calibrators at AVS (DNice and jrref) have compared 2019 Sony OLEDs against other brands (post calibration) side by side and reported Dolby vision is identical.
I don't have an Oled
I have a Led, specifically XF9005
mattmarsden
#1474
Post
by mattmarsden » Fri Mar 06, 2020 2:40 pm
Its definitely the Shield doing something wrong because on my LG C9 the dual layer and Yuescope look identical - I've checked lots of scenes.
baker99
#1475
Post
by baker99 » Fri Mar 06, 2020 3:08 pm
mattmarsden wrote: Fri Mar 06, 2020 2:40 pm
That's good news, kind of.
ATD555
#1476
Post
by ATD555 » Fri Mar 06, 2020 7:30 pm
I know you guys probably don't care but I have a Hisense H8F and it plays all of the test files except for the DV Profile 4.06
The way I play my files is run the .m2ts through TSMuxer and output a TS file that has the Dolby Vision Profile 7 info (EL + RPU) on the second layer. Works great.
ragico
#1477
Post
by ragico » Fri Mar 06, 2020 9:31 pm
ATD555 wrote: Fri Mar 06, 2020 7:30 pm
How you know that the second layer has the Dolby Vision Profile 7 info before you mux the .ts?
ATD555
#1478
Post
by ATD555 » Fri Mar 06, 2020 9:34 pm
ragico wrote: Fri Mar 06, 2020 9:31 pm
Well I can assume it does cause I am using files ripped directly from a 4K Dolby Vision disc. If I obtained a file and am unsure whetehr or not it should have Dolby Vision, I consult Blu-Ray.com to confirm.
#1479
Post
by RESET_9999 » Fri Mar 06, 2020 9:39 pm
If there are two HEVC streams in your original m2ts, then it's in DV.
Arbigator
#1480
Post
by Arbigator » Sat Mar 07, 2020 2:38 am
Are you using any other settings? or just adding the .m2ts and muxing to .ts? What build are you using? So far I haven't been able to get a .ts file to play on my LG B9 unfortunately.
box4m
#1482
Post
by box4m » Sat Mar 07, 2020 9:12 pm
When trying the bl_el_rpu_builder from yusesope (big thanks, awesome job), i get an outputfile that doesnt appear to be dual layer, its the same size as only the BL and when dropping it into txmuxer for example, its just 1 stream.
I dont know if thats why the next problem occurs(?)
when running:
"mp4muxer.exe -i path\BL_EL_RPU.hevc --dv-profile 4or7 -o path\output_dv.mp4"
i finishes instantly and no output is created
Appreciate some pointers, im not really savvy when it comes to your terminology in this thread but i try to pickup what i can, i consider myself "IT savvy"
kazuma
#1483
Post
by kazuma » Sat Mar 07, 2020 11:26 pm
does anyone know what 'web optimizer ' is in dvdfab? is it better to leave it on?
#1484
Post
by RESET_9999 » Sat Mar 07, 2020 11:42 pm
this modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
SL EL+RPU also now works on the x700( LG TV too) and
without the dual-layer TS bug ( play one time, reboot). But this build doesnt work anymore with the dual layer DV remux from uhd-bd
test build:
https://drive.google.com/file/d/10zOr0I ... sp=sharing
SL BL+EL+RPU atmos sample:
https://drive.google.com/file/d/1n95g_b ... sp=sharing ----->atmos + DV works on shield/plex
Complete name : D:\BL_EL_RPU.ts
Format : MPEG-TS
File size : 61.0 MiB
Duration : 30 s 14 ms
Overall bit rate mode : Variable
Overall bit rate : 17.0 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Duration : 29 s 863 ms
Bit rate : 15.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.078
Stream size : 55.4 MiB (91%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1016 cd/m2
Maximum Frame-Average Light Level : 342 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Duration : 30 s 17 ms
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 7 158 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 2.29 MiB (4%)
Service kind : Complete Main
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Angryunibrow
#1485
Post
by Angryunibrow » Sun Mar 08, 2020 1:07 am
RESET_9999 wrote: Sat Mar 07, 2020 11:42 pm
test build:
Format : MPEG-TS
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Audio
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 640 kb/s
Going to test this now on a full movie.
