New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
john_nikkon
Re: New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
#16 Post by john_nikkon » Fri Oct 22, 2010 1:52 am
Has there been any progress on MOULIN ROUGE or ROMEO + JULIET? I just emailed the SVQ files for both to try and help the cause. The updated files mentioned above definitely do not work for these two titles at present.
Any updates would be appreciated. Very anxious to backup my copies of these two blurays...
Thanks.
John.
#17 Post by mike admin » Fri Oct 22, 2010 8:37 am
You were the first one to submit dumps for these particular editions. SVQ files were just updated.
john_nikkon
#18 Post by john_nikkon » Fri Oct 22, 2010 6:11 pm
Thank you so so much. I tried it for both discs and it work perfectly!!! You guys rock.
John.
JishanF
#19 Post by JishanF » Sat Oct 23, 2010 1:25 pm
The Rocky Horror Picture Show 35th Anniversary Blu-Ray edition will not open either. I already submitted a dump but just wanted to post in case anyone else runs into this problem.
#20 Post by mike admin » Mon Oct 25, 2010 6:15 am
It should work, at least with manual dsall.svq download, see http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612
JishanF
#21 Post by JishanF » Tue Oct 26, 2010 12:20 am
Thanks for the info. I downloaded the svq and lo and behold the disc opened! Thank you.
