box4m
#1486 Post by box4m » Sat Mar 07, 2020 9:12 pm
When trying the bl_el_rpu_builder from yusesope (big thanks, awesome job), i get an outputfile that doesnt appear to be dual layer, its the same size as only the BL and when dropping it into txmuxer for example, its just 1 stream.
I dont know if thats why the next problem occurs(?)
when running:
"mp4muxer.exe -i path\BL_EL_RPU.hevc --dv-profile 4or7 -o path\output_dv.mp4"
i finishes instantly and no output is created
Appreciate some pointers, im not really savvy when it comes to your terminology in this thread but i try to pickup what i can, i consider myself "IT savvy"
kazuma
#1487 Post by kazuma » Sat Mar 07, 2020 11:26 pm
does anyone know what 'web optimizer ' is in dvdfab? is it better to leave it on?
#1488 Post by RESET_9999 » Sat Mar 07, 2020 11:42 pm
this modified version of tsMuxer(thanks a5180007) now retains the EL when using yusesope tool.
SL EL+RPU also now works on the x700( LG TV too) and without the dual-layer TS bug ( play one time, reboot). But this build doesnt work anymore with the dual layer DV remux from uhd-bd
test build:https://drive.google.com/file/d/10zOr0I ... sp=sharing
SL BL+EL+RPU atmos sample: https://drive.google.com/file/d/1n95g_b ... sp=sharing ----->atmos + DV works on shield/plex
Complete name                            : D:\BL_EL_RPU.ts
File size                                : 61.0 MiB
Duration                                 : 30 s 14 ms
Overall bit rate                         : 17.0 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 29 s 863 ms
Bit rate                                 : 15.6 Mb/s
Bits/(Pixel*Frame)                       : 0.078
Stream size                              : 55.4 MiB (91%)
Maximum Content Light Level              : 1016 cd/m2
Maximum Frame-Average Light Level        : 342 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 30 s 17 ms
Maximum bit rate                         : 7 158 kb/s
Stream size                              : 2.29 MiB (4%)
Number of dynamic objects                : 15
Angryunibrow
#1489 Post by Angryunibrow » Sun Mar 08, 2020 1:07 am
Video
Audio
Codec ID                                 : 131
Going to test this now on a full movie.
powdeau
#1490 Post by powdeau » Sun Mar 08, 2020 1:39 am
Video
Audio
Codec ID                                 : 131
I have tried DL DV and unfortunately it shows DV on X700 but not on LG C7 and the colors are washed out. Also the reboot bug remains :(
#1491 Post by RESET_9999 » Sun Mar 08, 2020 1:44 am
yes, as i said DL is broken on this build
did you try the SL sample ?
powdeau
#1492 Post by powdeau » Sun Mar 08, 2020 2:31 am
Yes, that works flawlessly.
Angryunibrow
#1493 Post by Angryunibrow » Sun Mar 08, 2020 3:32 am
Video
Audio
Codec ID                                 : 131
Fully working movie tested (Hobbs and Shaw) on the Shield with Plex.
FF worked and Atmos triggered.
I only had an issue with Plex telling me connection to the server was not fast enough and the movie stopped after about 10 minutes.
I'm streaming from a remote server, and this usually doesn't happen. Not sure if it's related to the movie or not. I'll have to keep an eye on it. Haven't had that issue come up yet.
All in all it worked, and to my eyes looked great.
If you are not comparing screenshots all day you would never know if any colors were off to the normal DL Disc.
All in all I think a success, and I'm happy so far.
More watching and testing to be done.
Grencola
#1494 Post by Grencola » Sun Mar 08, 2020 3:47 am
Well, we know it looks the same as Netflix's DV colors on the Shield at least. I haven't seen a seen a huge uproar of Shield users complaining that Netflix wasn't matching disc quality (for colors I mean, obviously netflix is compressed) so it mustn't be that bad. Though it's possible that people who watch Netflix have perhaps never watched its real disc counterpart and don't know any better ;)
Angryunibrow
#1495 Post by Angryunibrow » Sun Mar 08, 2020 3:57 am
Well, we know it looks the same as Netflix's DV colors on the Shield at least. I haven't seen a seen a huge uproar of Shield users complaining that Netflix wasn't matching disc quality (for colors I mean, obviously netflix is compressed) so it mustn't be that bad. Though its possible that people who watch Netflix have perhaps never watched the real disc counterpart and don't know any better ;)
Agreed, and honestly everyone "sees" colors differently, if you told me it was playing from the actual disc in DL I would not know the difference in a real life watching situation.
Even the troublesome Joker movie in a real life watching situation you would never even know the colors are off slightly unless you followed this thread and knew about it.
Grencola
#1496 Post by Grencola » Sun Mar 08, 2020 6:05 am
yusesope wrote:
Thu Mar 05, 2020 5:47 pm
I can confirm that this mp4 plays properly on the Amazon Fire TV Stick 4k and looks great (to my eyes) with no color issues. MX Player was the only app that worked. This is actually the first file that has ever worked, other than Dolby's test samples. Usually just a DV flag with a black screen.
No dice on the fire stick, just a green screen with the dv flag active. then flickers and reverts back to hdr10 which looks ok.
baker99
#1497 Post by baker99 » Sun Mar 08, 2020 9:11 am
A lot of users probably like the over saturated look, but Nvidia replied to my post and are looking at the issue which is something, I'm sure a lot more pureists would buy the shield if it had perfect reproduction.
baker99
#1498 Post by baker99 » Sun Mar 08, 2020 9:13 am
I haven't noticed a difference with it on or off, it does seem to take longer to process files when it's on though.
baker99
#1499 Post by baker99 » Sun Mar 08, 2020 9:29 am
Video
Audio
Codec ID                                 : 131
Great news, hopefully soon they can combine all the working code into one build to rule them all ;)
ragico
#1500 Post by ragico » Sun Mar 08, 2020 10:38 am
@RESET_9999
which version of yusesope tool you use? the one with the .old extension or the one without the .old extension?
After that is it necessary to make the .mp4 file with dolby mp4muxer? Or we can mux the bl_el_rpu.hevc file directly in tsmuxer adding audio etc?
Thank you
