Nez Ha 2019?
jwk94
Nez Ha 2019?
Post by jwk94 » Sat Mar 07, 2020 2:07 am
Has anyone successfully ripped Nez Ha's 4K disc? For some reason, I get the following error when trying:
"The volume key is unknown for this disc - video can't be decrypted
Failed to open disc"
I tried ripping the regular blu-ray and that worked without a hitch. Any solutions?
Re: Nez Ha 2019?
Post by Woodstock » Sat Mar 07, 2020 3:07 pm
MakeMKV created an MKB2 file in your MakeMKV data directory. You need to send that to svq@makemkv.com so that it can be analyzed and the key added to the known key list.
After you've sent it in, try the rip again in a couple of days. Probably will work then, but it might take longer.
apophis906
Re: Nez Ha 2019?
Post by apophis906 » Sat Mar 07, 2020 4:01 pm
I sent my dump file on Thursday afternoon. So hopefully it should be supported soon.
