Knives Out - Redbox DVD
hom-theatr
#1 Post by hom-theatr » Wed Mar 04, 2020 4:46 pm
Using MakeMKV there were 5 files made successfully. When I watched them they all seemed fine, but after turning them into .mp4 files the audio was associated with the wrong scenes on 4 of the files. The only correct one was title_t02.mkv.
fourstar77
Re: Knives Out - Redbox DVD
#2 Post by fourstar77 » Fri Mar 06, 2020 12:00 am
There were 6 files that were of similar length, but the one that most resembled the runtime on IMDB wouldn't work - just errored out. Trying another one and it is working, but might not be in the right order...
jbond56
#3 Post by jbond56 » Fri Mar 13, 2020 7:53 pm
Any luck determining which one is correct?
MartynT
#4 Post by MartynT » Sat May 16, 2020 3:36 pm
For Knives Out DVD UK use manual mode and title 82
