hepe9
Post by hepe9 » Thu Mar 05, 2020 7:06 pm
@LucasSimba you tried the clips posted for @yusesope?
To see if you have the same results
I tried with the Sony player and the "dvdfab" works but wrongs colors and the other 2 no DV and play in fast speed
baker99
Post by baker99 » Thu Mar 05, 2020 7:11 pm
yusesope wrote:
Thu Mar 05, 2020 5:47 pm
Here are several clips of 23 seconds each relating to the Joker movie (with the iconic scene that has been discussed HERE on the Plex forum).
You can also find the original HEVC raw streams *** and those obtained with my program (the BL_EL_RPU version HERE, and the second BL_RPU iteration HERE).
I also muxed the Bluray disc with DVDFab and after an analysis with a hexadecimal editor, the file obtained is identical to what can be obtained with my program - second iteration)
If you want to share files on other forums too, there is no problem for me.
ffmpeg -i bluray:D:\Joker_BD -map 0:0 -ss 19 -to 42 -c copy D:\Joker_BL.hevc
ffmpeg -i bluray:D:\Joker_BD -map 0:1 -ss 19 -to 42 -c copy D:\Joker_EL.hevc
It may just be my old eyes or a placebo effect but the colours do look different on some of these, the double track double layer looks less saturated, hopefully someone can do some side by side screenshots.
Edit using C6 and plex on shield
Edit 2 - The double track double layer seems to play on the X700 and looks similar to the shield, I tried 2 of the other tracks but they were jumpy and locked up the X700, they did all look the same as the double layer double track to me though
Grencola
Post by Grencola » Thu Mar 05, 2020 8:43 pm
hepe9 wrote:
Thu Mar 05, 2020 6:20 pm
Why that device is special?
They are many android devices with DV, they confirmed that device can read DV DL?
The price is similar to x700
not sure why your reply sounds so arrogant, maybe it's just me being tired :P can you name me some of these many android devices that can do dolby vision and, like I said, are NOT netflix or google etc certified (single layer) devices? it's special because it's the first one with a dolby license that doesn't seem to require being single layer. but who knows, it's just why I'm keeping an eye on it..
hepe9
Post by hepe9 » Thu Mar 05, 2020 9:15 pm
not sure why your reply sounds so arrogant, maybe it's just me being tired :P can you name me some of these many android devices that can do dolby vision and, like I said, are NOT netflix or google etc certified (single layer) devices? it's special because it's the first one a dolby vision license that doesn't seem to require being single layer. but who knows, it's just why I'm keeping an eye on it..
English is not my language and maybe I don't express myself well
I don't want to offend or disrespect anyone
A quick search; Transpeed X3, X3 Max, UGOOS AM6 Plus, etc.
Like I said they are many Android devices with DV support
Grencola
Post by Grencola » Thu Mar 05, 2020 9:49 pm
no worries. none of these devices from what I've read have a dolby vision license though. there are many SOCs with physically capable hw, but it still can't do dolby vision without a license.
edit: ok not sure about the am6 as I can't find proper info
ATD555
Post by ATD555 » Thu Mar 05, 2020 9:51 pm
As much as this was a breakthrough and very exciting I feel like we are back to square one. Anyone else feel this?
hepe9
Post by hepe9 » Thu Mar 05, 2020 10:10 pm
UGOOS AM6 Plus is 1:1 hardware like the minix
Same SOC and GPU
SoC Amlogic S922XJ
GPU ARM Mali-G52 MP6
And the "Amlogic Video Engine" and more cheap
And remember, they don't respond your answer about DV DL
MastaG
Post by MastaG » Thu Mar 05, 2020 10:28 pm
So did anybody tried to produce a single layer DV 60fps movie with hd audio using yusecope's second version of his tool?
I believe the 60fps DV movies didn't play without stuttering on LG TV's when they are dual layer right?
Grencola
Post by Grencola » Thu Mar 05, 2020 10:59 pm
Same SOC and GPU
SoC Amlogic S922XJ
once again, it has physically capable hardware, but also needs a dolby license. Minix has told me they have the full paid license. obviously they haven't said about dual layer, or I wouldn't be 'keeping my eye on it' to test what it's capable of at launch. English is not your primary language though, so I forgive you :wink:
Post by RESET_9999 » Thu Mar 05, 2020 11:25 pm
one more comparison: https://slow.pics/c/TyeCCLDz
no doubt in my mind, it's not identical. at least not from X700 vs Shield
Post by RESET_9999 » Fri Mar 06, 2020 12:10 am
after more comparisons with my TV internal app and the x700, I now believe the Shield actually output over-saturated color in DV.
I suspect it's because they send a bt2020 rgb 8bit signalwhile the x700 and the appleTV send RGB 8 bit ( no color primaries signaled).
Netflix Stranger Things DV comparisons
Shield vs LG C8 TV: https://slow.pics/c/ah3JaROY
x700 vs LG C8: https://slow.pics/c/Stl6kE9t
x700 vs Shield: https://slow.pics/c/K3bky83X
P-S: before you ask, yes my shield is up to date
Post by shawnc22 » Fri Mar 06, 2020 2:21 am
wonder if it may be because of the AI-enhanced upscaler? I know that it's only supposed to be used for regular HD videos, but maybe it's still doing something to these 4k videos.
Post by RESET_9999 » Fri Mar 06, 2020 2:28 am
nop... AI upscaler is turned off, I hate it. https://www.avsforum.com/forum/39-netwo ... st58785700
on my end, anything that needs upscaling goes into HTPC/madVR. :)
smartrobot
Post by smartrobot » Fri Mar 06, 2020 4:35 am
Is anyone else having this issue with @yusesope tool
Throws an error and hangs the video works it is just missing the last second or so
I can still use the output and create a mp4 using dlb_mp4base and will play back on my Visio TV
FFMPEG output warnings
[NULL @ 0x5568201f5c80] Invalid NAL unit 36, skipping.
[NULL @ 0x5568201f6e40] Invalid NAL unit 36, skipping.
yusesope output
___@little-server:~/src$ python3 bl_el_rpu_builder.py -tbw 4 -bl ~/BL.hevc -el ~/EL.hevc -o ~/Out.hvec
Exception in thread Thread-1:LYSIS: 86.8%     BL_EL_RPU WRITING: 86.0%
Traceback (most recent call last):
  File "/usr/lib/python3.6/threading.py", line 916, in _bootstrap_inner
    self.run()
  File "bl_el_rpu_builder.py", line 175, in run
    self.read()
  File "bl_el_rpu_builder.py", line 163, in read
    self.get_nal_info(mm,length,global_offset)
  File "bl_el_rpu_builder.py", line 138, in get_nal_info
    nal_type = self.get_nal_type(mmap_obj[(nal_offset + 3):(nal_offset + 5)])
  File "bl_el_rpu_builder.py", line 128, in get_nal_type
    nuh_layer_id = b_stream.read('uint:6')
  File "/home/nick/.local/lib/python3.6/site-packages/bitstring.py", line 3902, in read
    value, self._pos = self._readtoken(name, self._pos, length)
  File "/home/nick/.local/lib/python3.6/site-packages/bitstring.py", line 2016, in _readtoken
    "Tried to read {0} bits when only {1} available.".format(int(length), self.length - pos))
bitstring.ReadError: Reading off the end of the data. Tried to read 6 bits when only 1 available.
Exception in thread Thread-2:LYSIS: 92.4%     BL_EL_RPU WRITING: 91.3%
    self.run()
    self.read()
  File "~/.local/lib/python3.6/site-packages/bitstring.py", line 3902, in read
  File "~/.local/lib/python3.6/site-packages/bitstring.py", line 2016, in _readtoken
BL ANALYSIS: 99.3%     EL ANALYSIS: 99.3%     BL_EL_RPU WRITING: 99.3%
Arbigator
Post by Arbigator » Fri Mar 06, 2020 5:26 am
Have you tried setting the Shield's output to YUV 4:2:0 10 bit or YUV 4:2:2 12 bit rather than RGB 8 bit? I could definitely see things looking different if not set to YUV.
