hepe9
#1411 Post by hepe9 » Thu Mar 05, 2020 11:31 am
100% agree with @built_to_chill
This is DV; https://www.youtube.com/watch?v=voePq29-U6M
https://www.youtube.com/watch?v=do6l3frfLcQ
I only want it if is 100% DV with correct colors and all correct, if not, HDR is better
hepe9
#1412 Post by hepe9 » Thu Mar 05, 2020 11:57 am
LucasSimba wrote: Thu Mar 05, 2020 8:17 am Just tested with Joker on a Sony 4K TV (XF9005). It works with Plex, but not with MX Player (only HDR was detected) and Sony's own player.
But for some reason, the image is really red/pink. Somebody has the same problem? (see De Niro's face)
I used yusesope's tool to have single DV, then I used mp4muxer. It might be a Plex problem, but it would surprise me.
I have the same TV and I posted the results of the test in previous pages
Basically the profiles doesn't work
You say "work" on Plex but not on Sony Player?
Thats the key, Plex can't do magic, Plex only can play what your TV can
But don't worry, at the moment is not correct DV even with players can play it
yusesope
#1413 Post by yusesope » Thu Mar 05, 2020 12:07 pm
There are however many positive aspects.
  • I believe I have reached the level of DVDFab. I modified the source code to take into account only the RPU NALs (you can find it HERE) to create a BL + RPU file.
    Simply rename the file in the "src" folder by adding the ".old" extension and copy the new file in the same folder.
    I would not be surprised if the raw HEVC stream (obtained after demuxing the DVDfab mp4 file) was the same as mine after an analysis with an HEX editor (for example FlexHex, menu Search-> Compare)
  • The idea of ​​how the RPU NALs (UNSPEC_62) and those related to the Enhancement Layer (UNSPEC_63) combine with each other (as I said in THIS post) seems valid. In support of my idea, mp4muxer (Dolby's tool) accepts my files without returning errors and then I successfully demuxed the LG demo file (THIS post) into its BL and EL + RPU components (using the inverse of my technique). I also believe that other people involved in "defeating" Dolby Vision (for example, the developers of Open tsMuxeR) may find my idea at least "interesting".
    • Suboptimal reproduction on LG C8 is good news. In my opinion, the file is correctly recognized but what I said in the last lines of THIS post (about dvhe.04) occurs. On LG C9 (thanks to @mattmarsden), much more powerful, the problem does not arise (at least for a film ... Cliffhanger also has a fairly large FEL ... it's about a quarter of the Base Layer ... it's a good sign).
      Who knows how it would be reproduced on an OPPO
    • The X700 may have compatibility issues with the mp4 container. Maybe with a TS ... who knows?
    • The Shield instead "worried" me already when some of you reported the correct functioning of the files with profile dvhe.07.06. In my opinion, some fallback mechanism takes over and the playback is started with dvhe.05 profile (thus ignoring EL). The images of @RESET_9999 (which I thank) may not be the absolute truth ...
It is not the end yet...
hepe9 wrote: Thu Mar 05, 2020 11:57 am But don't worry, at the moment is not correct DV even with players can play it
Aside from complaining a lot, what is your contribution to the discussion?
I am ready to listen to your ideas...
codeXRes
#1414 Post by codeXRes » Thu Mar 05, 2020 12:09 pm
Thanks. I was planning to do exactly the same test (Joker UHD > SL DV > Mp4muxer > XF9005). :mrgreen:
yusesope
#1415 Post by yusesope » Thu Mar 05, 2020 12:29 pm
Take a look here:
yusesope wrote: Sat Feb 29, 2020 6:26 pm If instead I choose to play my files with the profiles dvhe.05 and dvhe.08 (useful for processing Single Track Single Layer files (BL + RPU)), the hardware decoder will try to process the Base Layer (BL) and to improve it through RPU metadata by discarding the EL layer.
however, the Base Layer is non-standard (it has a different color space than the IPTPQc2/IPT one) as extracted from a Bluray disk.
It should appear better than an HDR stream (since metadata is dynamic and non-static) but will not reach its maximum splendor due to the lack of data contained in the EL layer.
The lack of this information, however, could lead, in some cases, to evident chromatic aberrations.
DaMacFunkin
#1416 Post by DaMacFunkin » Thu Mar 05, 2020 12:51 pm
I’ve said it before and I’ll say it again, Shield can’t process 2 streams into one output, whether that be Dolby Vision or MVC.
hepe9
#1417 Post by hepe9 » Thu Mar 05, 2020 1:12 pm
@yusesope I'm so sorry if you think I'm just complaining, it's not my intention
ragico
#1418 Post by ragico » Thu Mar 05, 2020 1:15 pm
yusesope wrote: Thu Mar 05, 2020 12:07 pm There are however many positive aspects.
Thanks for your work and researches. I am learning a lot from you.
baker99
#1419 Post by baker99 » Thu Mar 05, 2020 1:30 pm
Interesting and definitely good progress, even if the Shield ends up not being the super box we'd all hoped for. I can't wait to see where this goes next, I'm currently doing a full movie SL mux to see how it looks on my setup.
ATD555
#1420 Post by ATD555 » Thu Mar 05, 2020 3:24 pm
mattmarsden wrote: Thu Mar 05, 2020 8:57 am Well I'm more positive about this method - I've used Cliffhanger DV as my test. I've got an LG C9 that can play both dual layer and the single layer files created by Yuescope and I have to say they both look identical. I use this title as the SL file created by DVDfab had obvious colour problems but the Yuescope version doesn't. Still need to do some more testing before I can say I'm perfectly happy. The Yuescope SL file played on the Sheild looks the same as played on the C9 so that again is quite positive. Its difficult to do comparisons between different devices as they can output significantly differently - the Oppo 203 uses the same SOC as the Sony X700 but looks quite different.
Cliffhanger is not a Dolby Vision movie, why are you using this as a test?
mattmarsden
#1421 Post by mattmarsden » Thu Mar 05, 2020 3:36 pm
The Studio Canal version is DV, the Sony one isn't.
ATD555
#1422 Post by ATD555 » Thu Mar 05, 2020 4:36 pm
mattmarsden wrote: Thu Mar 05, 2020 3:36 pm The Studio Canal version is DV, the Sony one isn't.
Sorry, my bad
mrhollywood
#1423 Post by mrhollywood » Thu Mar 05, 2020 4:38 pm
So what's the current preferred player for DV? I'm currently using the emby app on my C9, which works pretty well but the ethernet port is only 100mbs and there's no way to use lossless audio. The X700 still only has 100mbs LAN, and I'd rather use some kind of native app instead of messing around with DLNA. The Shield seems like a good choice, but I'd really like to have dual layer support.
FusionNeo
#1424 Post by FusionNeo » Thu Mar 05, 2020 4:45 pm
mrhollywood wrote: Thu Mar 05, 2020 4:38 pm So what's the current preferred player for DV? I'm currently using the emby app on my C9, which works pretty well but the ethernet port is only 100mbs and there's no way to use lossless audio. The X700 still only has 100mbs LAN, and I'd rather use some kind of native app instead of messing around with DLNA. The Shield seems like a good choice, but I'd really like to have dual layer support.
You’ve pretty much summed up the pros and cons of each one pretty well. :lol:
The only other player I know of is the M9702, which is an OPPO UDP-203 clone. Do some research, there is a website that does a group buy for $320 but the normal selling price is $400. It has a 1Gb Ethernet port but you’re still limited to DLNA, can’t use Plex.
Unfortunately no player has it all.
Give it time though, if you can use eARC on the C9 then if the tsMuxer people can figure out why the files won’t playback on the LG OLED TVs and fix that bug you’ll have lossless audio with DV and Emby. You'll still be limited by that 100Mbps Ethernet port though.
baker99
#1425 Post by baker99 » Thu Mar 05, 2020 5:18 pm
Successfully made a SL DV mux of Jurassic World Fallen Kingdom, it plays well on the Shield.
