mrhollywood
#1426 Post by mrhollywood » Thu Mar 05, 2020 4:38 pm
So what's the current preferred player for DV? I'm currently using the emby app on my C9, which works pretty well but the ethernet port is only 100mbs and there's no way to use lossless audio. The X700 still only has 100mbs LAN, and I'd rather use some kind of native app instead of messing around with DLNA. The Shield seems like a good choice, but I'd really like to have dual layer support.
FusionNeo
#1427 Post by FusionNeo » Thu Mar 05, 2020 4:45 pm
You’ve pretty much summed up the pros and cons of each one pretty well. :lol:
The only other player I know of is the M9702, which is an OPPO UDP-203 clone. Do some research, there is a website that does a group buy for $320 but the normal selling price is $400. It has a 1Gb Ethernet port but you’re still limited to DLNA, can’t use Plex.
Unfortunately no player has it all.
Give it time though, if you can use eARC on the C9 then if the tsMuxer people can figure out why the files won’t playback on the LG OLED TVs and fix that bug you’ll have lossless audio with DV and Emby. You'll still be limited by that 100Mbps Ethernet port though.
baker99
#1428 Post by baker99 » Thu Mar 05, 2020 5:18 pm
Successfully made a SL DV mux of Jurassic World Fallen Kingdom, it plays well on the Shield.
Grencola
#1429 Post by Grencola » Thu Mar 05, 2020 5:26 pm
I'm keeping my eye on this device: https://theminixforum.com/index.php?thr ... 2020.2404/ hoping it will be the first to do dual-layer as it's been requested to the devs for months during production, and they've already said the full dolby license has been paid. it's not an official Netflix or Amazon etc certified device, so if it can't do dv with DRM services, I don't see why else they need a dolby vision license. anyway it's out in 3 weeks so we'll see.
kazuma
#1430 Post by kazuma » Thu Mar 05, 2020 5:34 pm
i don't know how you did it, but you're tool works better then dvdfab...
yusesope
#1431 Post by yusesope » Thu Mar 05, 2020 5:47 pm
Here are several clips of 23 seconds each relating to the Joker movie (with the iconic scene that has been discussed HERE on the Plex forum).
You can also find the original HEVC raw streams *** and those obtained with my program (the BL_EL_RPU version HERE, and the second BL_RPU iteration HERE).
I also muxed the Bluray disc with DVDFab and after an analysis with a hexadecimal editor, the file obtained is identical to what can be obtained with my program - second iteration)
If you want to share files on other forums too, there is no problem for me.
EDIT by Mike: MKV files for samples above - http://www.makemkv.com/download/dv/
ffmpeg -i bluray:D:\Joker_BD -map 0:0 -ss 19 -to 42 -c copy D:\Joker_BL.hevc
ffmpeg -i bluray:D:\Joker_BD -map 0:1 -ss 19 -to 42 -c copy D:\Joker_EL.hevc
ATD555
#1432 Post by ATD555 » Thu Mar 05, 2020 5:52 pm
This will be good for testing/comparison. So have we just essentially found out how DVDFab has been making their Single Layer DV files?
yusesope
#1433 Post by yusesope » Thu Mar 05, 2020 5:58 pm
I really think so. If you have desire and patience, you can check for yourself.
hepe9
#1434 Post by hepe9 » Thu Mar 05, 2020 6:15 pm
Wow
This is the perfect comparasion
ATD555
#1435 Post by ATD555 » Thu Mar 05, 2020 6:16 pm
I'm hoping TSMuxer devs update their program so that the BL+EL+RPU hevc can be preserved. Obviously Dual Layer will produce more accurate results (for now) but for those out there who can only play Single Layer this is the best we got right now.
hepe9
#1436 Post by hepe9 » Thu Mar 05, 2020 6:20 pm
Why that device is special?
They are many android devices with DV, they confirmed that device can read DV DL?
The price is similar to x700
Edit: I read the forums and the answers to your question is just is the first device with the exact cpu comes with DV, and yes they pay to Dolby, like all the devices come with it, but no respond to your question if he play DV DL, be careful and read until buy, or buy if you can return
mrhollywood
#1437 Post by mrhollywood » Thu Mar 05, 2020 6:25 pm
That looks almost perfect for what I need. Hopefully someone on here picks it up and tests it out. If not I may just bite the bullet and get one myself.
mattmarsden
#1438 Post by mattmarsden » Thu Mar 05, 2020 6:32 pm
I’m surprised Dolby have granted them a license!
#1439 Post by RESET_9999 » Thu Mar 05, 2020 6:48 pm
They are working on it.
https://forum.doom9.org/showpost.php?p= ... tcount=534
Angryunibrow
#1440 Post by Angryunibrow » Thu Mar 05, 2020 6:59 pm
The Holy Grail if it supports Profile 7 and we can play back DL DV.
What I would like even more is full BDMV support so we don't have to worry about muxing anything and we would get the Atmos audio also.
Pipe Dreams......
