FusionNeo
#1381 Post by FusionNeo » Wed Mar 04, 2020 8:02 pm
Angryunibrow wrote: Wed Mar 04, 2020 7:59 pm
FusionNeo wrote: Wed Mar 04, 2020 7:54 pm I’m trying to create the file in MP4Muxer, and I was able to create a DL DV MP4 file with the BL+EL, but when I try to mux the BL_EL_RPU.hevc file that was generated with yusesope’s tool, MP4muxer is generating a 0 byte file. Any suggestions?
Yusesope’s tool appears to have generated the BL_EL_RPU.hevc correctly (it’s the size of the BL+EL combined) but MP4Muxer just doesn’t seem to do anything with it.
Are you letting mp4muxer finish?
On my NVME drives it takes 7-8 minutes probably
It seems to finish. It goes over to the next line in command prompt, ready for another input.
I’m only using a 4 minute file, and it was able to create a dual layer file in a minute or two, but that’s not the case with the single layer HEVC. It finishes almost immediately - after entering the command, it waits for a second or two and then goes to the next like in command prompt ready for another input.
I’ll try to do more troubleshooting when I get back home as I had to leave, was just curious if anyone had the problem. For all I know a simple restart of my PC will fix it.
baker99
#1382 Post by baker99 » Wed Mar 04, 2020 8:25 pm
Seems to work with mp4muxer, plays nicely on the shield, audio says truehd when I look in the plex settings but no audio, I'm guessing the only current option for Atmos is still the yusesope player. Still great work making a proper single layer DV file :)
Angryunibrow
#1383 Post by Angryunibrow » Wed Mar 04, 2020 8:28 pm
baker99 wrote: Wed Mar 04, 2020 8:25 pm Seems to work with mp4muxer, plays nicely on the shield, audio says truehd when I look in the plex settings but no audio, I'm guessing the only current option for Atmos is still the yusesope player. Still great work making a proper single layer DV file :)
May I ask what profile you tested, 4 or 7?
I'll be testing 4 files when I get home, I made both profiles - Not sure what the difference is.
2 Files with DTS-HD MA 7.1 - Profile 4 & 7
2 Files with Atmos (Which I do not think will play) - Profile 4 & 7
hepe9
#1384 Post by hepe9 » Wed Mar 04, 2020 8:30 pm
It's too early for that
We need a comparative
baker99
#1385 Post by baker99 » Wed Mar 04, 2020 8:31 pm
Angryunibrow wrote: Wed Mar 04, 2020 8:28 pm
Profile 4, may try 7 later
#1386 Post by RESET_9999 » Wed Mar 04, 2020 8:42 pm
hepe9 wrote: Wed Mar 04, 2020 8:30 pm
+1
baker99
#1387 Post by baker99 » Wed Mar 04, 2020 8:50 pm
RESET_9999 wrote: Wed Mar 04, 2020 8:42 pm
+1
I'm trying to be optimistic, at least mediainfo is looking good :) Looking forward to some comparison shots and people with HDfury checking
#1388 Post by RESET_9999 » Wed Mar 04, 2020 9:39 pm
baker99 wrote: Wed Mar 04, 2020 8:50 pm
+1
Yes this new method looks promising. unlike dvdfab SL, the BL + EL + RPU are present & same size as the original, so everything seems right. I just hope the shield will actually make use of the EL.
HDfury wont tell us anything special because DV(fake or not) is always sent in an 8bit RGB container on my setup (denon avr ---> C8).
But I can do some screenshot comparison if i get a chance tonight.
LucasSimba
#1389 Post by LucasSimba » Wed Mar 04, 2020 9:47 pm
What media player do Shield TV users are using to play single DV? Kodi? Other? Thanks
baker99
#1390 Post by baker99 » Wed Mar 04, 2020 9:51 pm
LucasSimba wrote: Wed Mar 04, 2020 9:47 pm Hi,
Plex and mx player I think are the only ones working with DV
hepe9
#1391 Post by hepe9 » Wed Mar 04, 2020 10:28 pm
RESET_9999 wrote: Wed Mar 04, 2020 9:39 pm
+1
Thank you, if you can try the profiles 4 and 7 like yusesope said
ragico
#1392 Post by ragico » Wed Mar 04, 2020 10:37 pm
I have followed the steps and now have the final .mp4 file created by mp4muxer as yusesope reccomends. Can I now using it to create the .ts file in tsmuxer so that I can add the atmos track? Or I will loose some dv quality?
Angryunibrow
#1393 Post by Angryunibrow » Wed Mar 04, 2020 10:44 pm
ragico wrote: Wed Mar 04, 2020 10:37 pm I have followed the steps and now have the final .mp4 file created by mp4muxer as yusesope reccomends. Can I now using it to create the .ts file in tsmuxer so that I can add the atmos track? Or I will loose some dv quality?
TSMuxer will lose some of the DV, read back a few posts. If you do that you will lose the EL bits and pieces
ragico
#1394 Post by ragico » Wed Mar 04, 2020 10:49 pm
Angryunibrow wrote: Wed Mar 04, 2020 10:44 pm
Thank you
baker99
#1395 Post by baker99 » Wed Mar 04, 2020 10:56 pm
A quick question, if this works will it be identical (in theory) to the original dual layer source? As it has BL+El, or do we lose something like 12bit?
