Angryunibrow
Post
by Angryunibrow » Wed Mar 04, 2020 7:20 pm
How about this - Not Atmos, but HD Audio in a single layer using the new tool.
I converted the Atmos to DTS-HD MA 7.1 and used MP4BOX to mux it into the Single Layer file.
Of course I'm not at home to test this yet
Wasn't sure if MP4BOX would mux in an Atmos file?
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42/dby1)
File size : 40.9 GiB
Duration : 1 h 53 min
Overall bit rate mode : Variable
Overall bit rate : 51.7 Mb/s
Encoded date : UTC 2020-03-04 19:10:07
Tagged date : UTC 2020-03-04 19:10:07
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 47.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.241
Stream size : 37.9 GiB (93%)
Default : No
Encoded date : UTC 2020-03-04 18:59:56
Tagged date : UTC 2020-03-04 19:12:23
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 4000 cd/m2
Maximum Frame-Average Light Level : 1193 cd/m2
Codec configuration box : hvcC+dvcC+hvcE
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : mp4a-A9
Bit rate mode : Variable
Bit rate : 3 743 kb/s
Maximum bit rate : 6 099 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.96 GiB (7%)
Default : No
Alternate group : 1
Post
by RESET_9999 » Wed Mar 04, 2020 7:26 pm
Hey, this not related to single layer remux playback but could your tool be able to export the RPU data only in a file that would be accepted by x265.exe? maybe like the .json file created by the HDR10+parser ?
I would like to experiment profile 5 single layer encoding.
Angryunibrow
Post
by Angryunibrow » Wed Mar 04, 2020 7:49 pm
And here is the file with Atmos, Atmos in the .mp4 container does not show properly in mediainfo.
The software I use on my server does register Atmos though.
Again, I need to wait until I get home to test these files on the Shield.
Format : MPEG-4
File size : 40.4 GiB
Overall bit rate : 51.0 Mb/s
Encoded date : UTC 2020-03-04 19:40:25
Tagged date : UTC 2020-03-04 19:40:25
Video
Format : HEVC
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Stream size : 37.9 GiB (94%)
Default : No
Tagged date : UTC 2020-03-04 19:42:25
Audio
Format : mlpa
Codec ID : mlpa
Bit rate : 3 051 kb/s
Maximum bit rate : 5 012 kb/s
Stream size : 2.41 GiB (6%)
Default : No
Alternate group : 1
FusionNeo
Post
by FusionNeo » Wed Mar 04, 2020 7:54 pm
I’m trying to create the file in MP4Muxer, and I was able to create a DL DV MP4 file with the BL+EL, but when I try to mux the BL_EL_RPU.hevc file that was generated with yusesope’s tool, MP4muxer is generating a 0 byte file. Any suggestions?
Yusesope’s tool appears to have generated the BL_EL_RPU.hevc correctly (it’s the size of the BL+EL combined) but MP4Muxer just doesn’t seem to do anything with it.
Angryunibrow
Post
by Angryunibrow » Wed Mar 04, 2020 7:59 pm
FusionNeo wrote: ↑Wed Mar 04, 2020 7:54 pm
Are you letting mp4muxer finish?
On my NVME drives it takes 7-8 minutes probably (for an entire movie that is)
Angryunibrow on Wed Mar 04, 2020 8:03 pm, edited 1 time in total.
ATD555
Post
by ATD555 » Wed Mar 04, 2020 8:00 pm
I am testing a full movie remux using the BL+EL+RPU tool (John Wick Chapter 3). I will let you all know how it goes.
FusionNeo
Post
by FusionNeo » Wed Mar 04, 2020 8:02 pm
Angryunibrow wrote: ↑Wed Mar 04, 2020 7:59 pm
It seems to finish. It goes over to the next line in command prompt, ready for another input.
I’m only using a 4 minute file, and it was able to create a dual layer file in a minute or two, but that’s not the case with the single layer HEVC. It finishes almost immediately - after entering the command, it waits for a second or two and then goes to the next like in command prompt ready for another input.
I’ll try to do more troubleshooting when I get back home as I had to leave, was just curious if anyone had the problem. For all I know a simple restart of my PC will fix it.
baker99
Post
by baker99 » Wed Mar 04, 2020 8:25 pm
Seems to work with mp4muxer, plays nicely on the shield, audio says truehd when I look in the plex settings but no audio, I'm guessing the only current option for Atmos is still the yusesope player. Still great work making a proper single layer DV file
Angryunibrow
Post
by Angryunibrow » Wed Mar 04, 2020 8:28 pm
baker99 wrote: ↑Wed Mar 04, 2020 8:25 pm
May I ask what profile you tested, 4 or 7?
I'll be testing 4 files when I get home, I made both profiles - Not sure what the difference is.
2 Files with DTS-HD MA 7.1 - Profile 4 & 7
2 Files with Atmos (Which I do not think will play) - Profile 4 & 7
Angryunibrow on Wed Mar 04, 2020 8:30 pm, edited 1 time in total.
hepe9
Post
by hepe9 » Wed Mar 04, 2020 8:30 pm
It's too early for that
We need a comparative
baker99
Post
by baker99 » Wed Mar 04, 2020 8:31 pm
Angryunibrow wrote: ↑Wed Mar 04, 2020 8:28 pm
Profile 4, may try 7 later
Post
by RESET_9999 » Wed Mar 04, 2020 8:42 pm
hepe9 wrote: ↑Wed Mar 04, 2020 8:30 pm
+1
baker99
Post
by baker99 » Wed Mar 04, 2020 8:50 pm
RESET_9999 wrote: ↑Wed Mar 04, 2020 8:42 pm
+1
I'm trying to be optimistic, at least mediainfo is looking good
Looking forward to some comparison shots and people with HDfury checking
Post
by RESET_9999 » Wed Mar 04, 2020 9:39 pm
baker99 wrote: ↑Wed Mar 04, 2020 8:50 pm
+1
Yes this new method looks promising. unlike dvdfab SL, the BL + EL + RPU are present & same size as the original, so everything seems right. I just hope the shield will actually make use of the EL.
HDfury wont tell us anything special because DV(fake or not) is always sent in an 8bit RGB container on my setup (denon avr ---> C8).
But I can do some screenshot comparison if i get a chance tonight.
LucasSimba
Post
by LucasSimba » Wed Mar 04, 2020 9:47 pm
What media player do Shield TV users are using to play single DV? Kodi? Other? Thanks
