the file looks exactly like DVDFAB single layer remuxed in tsmuxer ( dv 5.6 become dv 8.6). EL is gone.
so unless yusesope did something different, I dont see how this will be any different (colors) than dvdfab SL.
I have no idea, are you using the tsmuxer build from RESET_9999's post? I think I read something in the tsmuxer forum about it reporting 08.06 for some reason, I think it should be saying 07.06
Yes, please confirm I did it correct.
I dropped the tsMuxeR.exe in the TsMuxer folder, removing the "original" one.
And then I click on the tsMuxerGUI.exe (2.6.12) and I'm assuming its using the modified tsMuxeR.exe
Yes?
Yes that's all I did, unless I mixed up my versions of tsmuxer somehow, there seem to be quite a few around now!
Please, drag and drop here the the Base Layer HEVC file and press ENTER:
C:\mp4\BL.hevc
Please, drag and drop here the the Enhancement Layer HEVC file and press ENTER
C:\mp4\EL.hevc
You did not specify an output file.
The BL_EL_RPU.hevc file will be created in the program folder.
(C:\temp\dv)
Exception in thread Thread-3:
Traceback (most recent call last):
File "C:\temp\dv\python-3.7.6.amd64\lib\threading.py", line 926, in _bootstr
_inner
self.run()
File "src\bl_el_rpu_builder.py", line 238, in run
self.output_queue.put((bl_nal_offset,bl_nal_size,el_nal_offset,el_nal_size
UnboundLocalError: local variable 'el_nal_offset' referenced before assignment
Yes?
Updated Mediainfo, now shows 08.06 - so mine matches what you did also.
C:\mp4\BL.hevc
C:\mp4\EL.hevc
(C:\temp\dv)
_inner
self.run()
I have no idea, could you try running it on a different hard drive?
...I recommend you to mux the file obtained using mp4muxer (as far as I know it is the only program able to process the information present in the NAL relating to the Enhancement Layer).
Try both with profile 4 and with profile 7...
The part that scans the NAL units relating to the enhancement layer is not yet present in the tsMuxeR code.
(take a look HERE, only the part related to RPU metadata (NAL_DV) is taken into consideration).
Let go of the audio for a moment.
Create a test file with profile 4 (and if you have time also with profile 7) using mp4muxer and who has the possibility (LG TV, X700 ...) compare it with the same track but "Double Track and Double Layer".
In case the image quality should be the same, you go to the great developers of tsMuxeR and kindly ask them if it is also possible to process the NAL units related to EL (NAL_UNSPEC63)
_inner
self.run()
Right click on the "start_bl_el_rpu_builder.bat" file.
Left click on the "Edit" item.
In the newly opened text file there is this string:
_inner
self.run()
-if you're working with original m2ts from uhd-bd, you should remux to DV TS directly in tsMuxer. No mp4muxer needed.
-if you're working with DV MP4: on my end, because I also experienced the washed-out picture with grey black bars, I started using the mp4demuxer to demux first and then use the raw hevc layers to build a new DV TS with Atmos. https://github.com/DolbyLaboratories/dlb_mp4demux
Général
Nom complet : Y:\4k\midway.ts
Format : MPEG-TS
Taille du fichier : 69,3 Gio
Durée : 2 h 18 min
Type de débit global : Variable
Débit global moyen : 71,7 Mb/s
Débit global maximum : 35,5 Mb/s
Vidéo #1
ID de menu : 1 (0x1)
Format : HEVC
Profil du format : Main 10@L5.1@High
HDR_Format/String : SMPTE ST 2086, HDR10 compatible
Identifiant du codec : 36
Durée : 2 h 18 min
Largeur : 3 840 pixels
Hauteur : 2 160 pixels
Format à l'écran : 16/9
Images par seconde : 23,976 (24000/1001) Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0 (Type 2)
Profondeur des couleurs : 10 bits
Gamme de couleurs : Limited
Coordonnées de chromaticité : BT.2020
Caractéristiques du transfert : PQ
Coefficients de la matrice : BT.2020 non-constant
MasteringDisplay_ColorPrimaries : BT.2020
MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
MaxCLL : 1000 cd/m2
MaxFALL : 502 cd/m2
Vidéo #2
Format : HEVC
HDR_Format/String : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Durée : 2 h 18 min
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Général
Nom complet : Y:\4k\Midway [dts][4k][DV].mp4
Format : MPEG-4
Profil du format : Base Media
Identifiant du codec : isom (isom)
Taille du fichier : 69,2 Gio
Durée : 2 h 18 min
Débit global moyen : 71,6 Mb/s
Date d'encodage : UTC 2020-03-03 12:24:09
Date de marquage : UTC 2020-03-03 12:24:09
Vidéo #1
Format : HEVC
Identifiant du codec : hev1
Identifiant du codec/Info : High Efficiency Video Coding
Durée : 2 h 18 min
Débit : 63,0 Mb/s
Type d'images/s : Constant
Bits/(Pixel*Image) : 0.317
Taille du flux : 60,9 Gio (88%)
Default : Non
Date d'encodage : UTC 2020-03-03 09:20:45
Date de marquage : UTC 2020-03-03 12:31:27
MaxCLL : 1000 cd/m2
MaxFALL : 502 cd/m2
Codec configuration box : hvcC
Vidéo #2
Format : HEVC
Identifiant du codec : dvhe
Identifiant du codec/Info : High Efficiency Video Coding with Dolby Vision
Durée : 2 h 18 min
Débit : 7 074 kb/s
Bits/(Pixel*Image) : 0.142
Taille du flux : 6,84 Gio (10%)
Default : Non
Codec configuration box : hvcC+dvcC
