Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 4:53 pm
ATD555 wrote: Wed Mar 04, 2020 3:59 pm
mattmarsden wrote: Wed Mar 04, 2020 3:54 pm Thank you so much. Whats the best way to demux the hevc layers? Also what commands do we use in mp4muxer? Thanks!
To demux the HEVC files
ffmpeg.exe -i bluray:\path\to\bluray -map 0:0 -c copy %userprofile%\Desktop\BL.hevc -map 0:1 -c copy %userprofile%\Desktop\EL.hevc
To use MP4Muxer
mp4muxer_64bits.exe --dv-profile 7.06 --input-file %userprofile%\Desktop\BL.hevc --input-file %userprofile%\Desktop\EL.hevc --output-file %userprofile%\Desktop\mp4muxer_out.mp4
Any chance someone could put together a complete post with steps involved to use this new tool for single layer, plus adding in an Atmos track?
I'm interested in creating single layer files with Atmos to play on the Shield.
I'm using DVDFab now, but would like to try out this method.
baker99
Post by baker99 » Wed Mar 04, 2020 4:57 pm
Using a 1 minute test from Shazam! Single layer DV is produced with no obvious issues, I muxed in Atmos audio with the special tsmuxer build and everything seemed perfect on the shield. I'll let you guys compare the quality as I'm not great at spotting subtle differences. I'm holding off converting my whole library until you all confirm it's perfect.
WELL DONE yusesope !
mattmarsden
Post by mattmarsden » Wed Mar 04, 2020 5:03 pm
baker99 wrote: Wed Mar 04, 2020 4:57 pm Using a 1 minute test from Shazam! Single layer DV is produced with no obvious issues, I muxed in Atmos audio with the special tsmuxer build and everything seemed perfect on the shield. I'll let you guys compare the quality as I'm not great at spotting subtle differences. I'm holding off converting my whole library until you all confirm it's perfect.
What did you use to demux the layers? It crashes out when I add mine
baker99
Post by baker99 » Wed Mar 04, 2020 5:14 pm
Angryunibrow wrote: Wed Mar 04, 2020 4:53 pm
To use MP4Muxer
A brief guide to yusesope's single layer DV tool
extract bl_el_rpu_builder.zip on a hard drive with plenty of space
Use ffmpeg to extract layers as follows
ffmpeg -ss 0 -i bluray:\path\to\bluray -t 60 -map 0:BL_STREAM_ID -c copy %userprofile%\Desktop\BL.hevc
ffmpeg -ss 0 -i bluray:\path\to\bluray -t 60 -map 0:EL_STREAM_ID -c copy %userprofile%\Desktop\EL.hevc
Run start_bl_el_rpu_builder.bat
drop in the BL then press enter
drop in the EL then press enter
The tool will do it's magic
you will then see a file called BL_EL_RPU.hevc has been created
Using the special tsmuxer build from RESET_9999 post https://onedrive.live.com/?authkey=%21A ... ion=locate
drop BL_EL_RPU.hevc in
then drop either your m2ts file for the movie or the movie playlist file in tsmuxer
delete the two video tracks that are added from that file leaving only BL_EL_RPU.hevc
don't delete any audio files (unless you don't need specific tracks)
Press start muxing and wait
once complete you should have a single layer DV file which plays on the shield
baker99
Post by baker99 » Wed Mar 04, 2020 5:15 pm
mattmarsden wrote: Wed Mar 04, 2020 5:03 pm
just ffmpeg
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:17 pm
baker99 wrote: Wed Mar 04, 2020 5:14 pm
To use MP4Muxer
This is what I needed, perfect - thank you.
Testing this out now!
baker99
Post by baker99 » Wed Mar 04, 2020 5:34 pm
Here's the mediainfo for the output just in case it helps anyone
General
Complete name                            : G:\Dolby Vision SL\shazam-test.ts
File size                                : 603 MiB
Duration                                 : 59 s 643 ms
Overall bit rate                         : 84.7 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 59 s 726 ms
Bit rate                                 : 80.0 Mb/s
Bits/(Pixel*Frame)                       : 0.402
Stream size                              : 570 MiB (95%)
Maximum Content Light Level              : 1351 cd/m2
Maximum Frame-Average Light Level        : 384 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 59 s 617 ms
Maximum bit rate                         : 5 931 kb/s
Stream size                              : 3.18 MiB (1%)
Number of dynamic objects                : 15
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:37 pm
baker99 wrote: Wed Mar 04, 2020 5:34 pm Here's the mediainfo for the output just in case it helps anyone
General
File size                                : 603 MiB
Video
Audio
Codec ID                                 : 131
How did you get this - dvhe.08.06
Mine output as 7.06
baker99
Post by baker99 » Wed Mar 04, 2020 5:44 pm
I have no idea, are you using the tsmuxer build from RESET_9999's post? I think I read something in the tsmuxer forum about it reporting 08.06 for some reason, I think it should be saying 07.06
Post by RESET_9999 » Wed Mar 04, 2020 5:45 pm
the file looks exactly like DVDFAB single layer remuxed in tsmuxer ( dv 5.6 become dv 8.6). EL is gone.
so unless yusesope did something different, I dont see how this will be any different (colors) than dvdfab SL.
 Video
Duration                                 : 4 min 59 s
Maximum Frame-Average Light Level        : 644 cd/m2
EDIT: but using mp4muxer the EL remain in the file
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 31.7 Mb/s
Bits/(Pixel*Frame)                       : 0.159
Stream size                              : 1.11 GiB (100%)
Encoded date                             : UTC 2020-03-04 17:46:37
Tagged date                              : UTC 2020-03-04 17:46:37
Codec configuration box                  : hvcC+dvcC+hvcE
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:47 pm
baker99 wrote: Wed Mar 04, 2020 5:44 pm I have no idea, are you using the tsmuxer build from RESET_9999's post? I think I read something in the tsmuxer forum about it reporting 08.06 for some reason, I think it should be saying 07.06
Yes, please confirm I did it correct.
I dropped the tsMuxeR.exe in the TsMuxer folder, removing the "original" one.
And then I click on the tsMuxerGUI.exe (2.6.12) and I'm assuming its using the modified tsMuxeR.exe
Yes?
baker99
Post by baker99 » Wed Mar 04, 2020 5:49 pm
Angryunibrow wrote: Wed Mar 04, 2020 5:47 pm
Yes?
Yes that's all I did, unless I mixed up my versions of tsmuxer somehow, there seem to be quite a few around now!
mattmarsden
Post by mattmarsden » Wed Mar 04, 2020 5:51 pm
I get this error:
Please, drag and drop here the the Base Layer HEVC file and press ENTER:
C:\mp4\BL.hevc
Please, drag and drop here the the Enhancement Layer HEVC file and press ENTER
C:\mp4\EL.hevc
You did not specify an output file.
The BL_EL_RPU.hevc file will be created in the program folder.
(C:\temp\dv)
Exception in thread Thread-3:
Traceback (most recent call last):
File "C:\temp\dv\python-3.7.6.amd64\lib\threading.py", line 926, in _bootstr
_inner
self.run()
File "src\bl_el_rpu_builder.py", line 238, in run
self.output_queue.put((bl_nal_offset,bl_nal_size,el_nal_offset,el_nal_size
UnboundLocalError: local variable 'el_nal_offset' referenced before assignment
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:53 pm
baker99 wrote: Wed Mar 04, 2020 5:49 pm
Yes?
Updated Mediainfo, now shows 08.06 - so mine matches what you did also.
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:55 pm
RESET_9999 wrote: Wed Mar 04, 2020 5:45 pm the file looks exactly like DVDFAB single layer remuxed in tsmuxer ( dv 5.6 become dv 8.6). EL is gone.
 Video
Video
Codec ID                                 : hev1
I guess we need someone to do some comparisons with a couple of the "trouble" movies like Hereditary and Joker where we have seen the color shift.
