Post by RESET_9999 » Wed Mar 04, 2020 5:45 pm
the file looks exactly like DVDFAB single layer remuxed in tsmuxer ( dv 5.6 become dv 8.6). EL is gone.
so unless yusesope did something different, I dont see how this will be any different (colors) than dvdfab SL.
 Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Duration                                 : 4 min 59 s
Maximum Frame-Average Light Level        : 644 cd/m2
EDIT: but using mp4muxer the EL remain in the file
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 31.7 Mb/s
Bits/(Pixel*Frame)                       : 0.159
Stream size                              : 1.11 GiB (100%)
Encoded date                             : UTC 2020-03-04 17:46:37
Tagged date                              : UTC 2020-03-04 17:46:37
Codec configuration box                  : hvcC+dvcC+hvcE
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:47 pm
baker99 wrote:
Wed Mar 04, 2020 5:44 pm
I have no idea, are you using the tsmuxer build from RESET_9999's post? I think I read something in the tsmuxer forum about it reporting 08.06 for some reason, I think it should be saying 07.06
Yes, please confirm I did it correct.
I dropped the tsMuxeR.exe in the TsMuxer folder, removing the "original" one.
And then I click on the tsMuxerGUI.exe (2.6.12) and I'm assuming its using the modified tsMuxeR.exe
Yes?
baker99
Post by baker99 » Wed Mar 04, 2020 5:49 pm
Yes?
Yes that's all I did, unless I mixed up my versions of tsmuxer somehow, there seem to be quite a few around now!
mattmarsden
Post by mattmarsden » Wed Mar 04, 2020 5:51 pm
I get this error:
Please, drag and drop here the the Base Layer HEVC file and press ENTER:
C:\mp4\BL.hevc
Please, drag and drop here the the Enhancement Layer HEVC file and press ENTER
C:\mp4\EL.hevc
You did not specify an output file.
The BL_EL_RPU.hevc file will be created in the program folder.
(C:\temp\dv)
Exception in thread Thread-3:
Traceback (most recent call last):
File "C:\temp\dv\python-3.7.6.amd64\lib\threading.py", line 926, in _bootstr
_inner
self.run()
File "src\bl_el_rpu_builder.py", line 238, in run
self.output_queue.put((bl_nal_offset,bl_nal_size,el_nal_offset,el_nal_size
UnboundLocalError: local variable 'el_nal_offset' referenced before assignment
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:53 pm
Yes?
Updated Mediainfo, now shows 08.06 - so mine matches what you did also.
Angryunibrow
Post by Angryunibrow » Wed Mar 04, 2020 5:55 pm
 Video
Video
Codec ID                                 : hev1
I guess we need someone to do some comparisons with a couple of the "trouble" movies like Hereditary and Joker where we have seen the color shift.
baker99
Post by baker99 » Wed Mar 04, 2020 6:01 pm
Yes I think we need some tests, it could be tsmuxer or the tool
Edit: Or could it be mediainfo not reporting correctly?
baker99
Post by baker99 » Wed Mar 04, 2020 6:02 pm
I get this error:
C:\mp4\BL.hevc
C:\mp4\EL.hevc
(C:\temp\dv)
_inner
self.run()
I have no idea, could you try running it on a different hard drive?
yusesope
Post by yusesope » Wed Mar 04, 2020 6:06 pm
guys, I quote myself from my last post.
yusesope wrote:
Wed Mar 04, 2020 3:36 pm
...I recommend you to mux the file obtained using mp4muxer (as far as I know it is the only program able to process the information present in the NAL relating to the Enhancement Layer).
Try both with profile 4 and with profile 7...
The part that scans the NAL units relating to the enhancement layer is not yet present in the tsMuxeR code.
(take a look HERE, only the part related to RPU metadata (NAL_DV) is taken into consideration).
Let go of the audio for a moment.
Create a test file with profile 4 (and if you have time also with profile 7) using mp4muxer and who has the possibility (LG TV, X700 ...) compare it with the same track but "Double Track and Double Layer".
In case the image quality should be the same, you go to the great developers of tsMuxeR and kindly ask them if it is also possible to process the NAL units related to EL (NAL_UNSPEC63)
I get this error:
I'll take a look
baker99
Post by baker99 » Wed Mar 04, 2020 6:09 pm
I get this error:
I'll take a look
Ah that makes sense! I'll try mp4muxer
yusesope
Post by yusesope » Wed Mar 04, 2020 6:18 pm
_inner
self.run()
Right click on the "start_bl_el_rpu_builder.bat" file.
Left click on the "Edit" item.
In the newly opened text file there is this string:
python-3.7.6.amd64\python src\bl_el_rpu_builder.py
Modify it as follows
python-3.7.6.amd64\python src\bl_el_rpu_builder.py -tbw 4
Save your changes and try again by double clicking on the "start_bl_el_rpu_builder.bat" file.
mattmarsden
Post by mattmarsden » Wed Mar 04, 2020 6:23 pm
_inner
self.run()
Thank you I will try that. Could you tell me how I mux this hevc file with mp4muxer? Thank you!
daddy
Post by daddy » Wed Mar 04, 2020 6:27 pm
RESET_9999 wrote:
Wed Mar 04, 2020 12:04 am
-if you're working with original m2ts from uhd-bd, you should remux to DV TS directly in tsMuxer. No mp4muxer needed.
-if you're working with DV MP4: on my end, because I also experienced the washed-out picture with grey black bars, I started using the mp4demuxer to demux first and then use the raw hevc layers to build a new DV TS with Atmos.
https://github.com/DolbyLaboratories/dlb_mp4demux
-personally I'm now using the newest tsmuxer with no DV descriptor in the HDR10 layer.
this one: https://drive.google.com/open?id=1Gq5TA ... B1io4OwHW9
I tryed, and it's not working yet. The .ts file is not recognized by the LG C7 player.
.ts
Général
Nom complet                              : Y:\4k\midway.ts
Taille du fichier                        : 69,3 Gio
Durée                                    : 2 h 18 min
Type de débit global                     : Variable
Débit global moyen                       : 71,7 Mb/s
Débit global maximum                     : 35,5 Mb/s
Vidéo #1
ID de menu                               : 1 (0x1)
Profil du format                         : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : 36
Durée                                    : 2 h 18 min
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
MasteringDisplay_ColorPrimaries          : BT.2020
MasteringDisplay_Luminance               : min: 0.0001 cd/m2, max: 1000 cd/m2
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 502 cd/m2
Vidéo #2
HDR_Format/String                        : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Durée                                    : 2 h 18 min
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
.mp4
Général
Nom complet                              : Y:\4k\Midway [dts][4k][DV].mp4
Profil du format                         : Base Media
Identifiant du codec                     : isom (isom)
Taille du fichier                        : 69,2 Gio
Durée                                    : 2 h 18 min
Débit global moyen                       : 71,6 Mb/s
Date d'encodage                          : UTC 2020-03-03 12:24:09
Date de marquage                         : UTC 2020-03-03 12:24:09
Vidéo #1
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 18 min
Débit                                    : 63,0 Mb/s
Type d'images/s                          : Constant
Bits/(Pixel*Image)                       : 0.317
Taille du flux                           : 60,9 Gio (88%)
Default                                  : Non
Date d'encodage                          : UTC 2020-03-03 09:20:45
Date de marquage                         : UTC 2020-03-03 12:31:27
MaxCLL                                   : 1000 cd/m2
MaxFALL                                  : 502 cd/m2
Vidéo #2
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 18 min
Débit                                    : 7 074 kb/s
Bits/(Pixel*Image)                       : 0.142
Taille du flux                           : 6,84 Gio (10%)
Default                                  : Non
yusesope
Post by yusesope » Wed Mar 04, 2020 6:29 pm
mp4muxer.exe -i path\to\my\new\and\sparkling\BL_EL_RPU.hevc --dv-profile 4 -o path\to\wherever\you\want\BL_EL_RPU.mp4
Post by RESET_9999 » Wed Mar 04, 2020 6:33 pm
of course, only the x700 and the oppo can play those dual layer TS file so far.
