FusionNeo
Post by FusionNeo »
Grencola wrote:
Tue Mar 03, 2020 5:18 am
FusionNeo wrote:
Tue Mar 03, 2020 5:09 am
Thanks for the link. Unfortunately I do see a pretty big difference in color accuracy between the DV SL created by DVDFab and the DL DV rip, not just in Joker but in the screenshot from Hereditary as well. Oh well.
I see something up with Joker for sure (hadn't seen that comparison before), but those last two screenshots of Hereditary (dual layer vs single layer) look pretty much the same to these old eyeballs. there's more contrast in the curtains and things like that, but the color seems the same to me, shrug..
The difference is a little more pronounced when doing side by side comparisons.
https://slow.pics/c/C2FkFprY
The wall in the DV copy looks a little more blue, for instance.
Tbh to my eyes the DVDFab copy actually looks better here than the actual UHD DV, but I like to watch and listen to things as they were intended by the creators. Hopefully that doesn’t come off as snobby, I just like having the most accurate representation of how something was intended to be seen or heard.
ATD555
Post by ATD555 »
I just can't wait for the dual to single layer tool comes out, then I can rest at ease knowing it looks as accurate as we can get.
mattmarsden
Post by mattmarsden »
Yes so it looks like the version of TSmuxer linked to a few posts back can definitely mux DV and thd+ac3 and is recognisable by Plex so we're nearly set....
baker99
Post by baker99 »
RESET_9999 wrote:
Tue Mar 03, 2020 3:22 am
if i take the full movie ts that wont play atmos on plex and remux it again in the test build this time, then atmos works...
so.... not ideal but this allow DV + atmos on plex shield.
1- create SL DV in dvdfab
2- create TS with atmos in build: nightly-2020-02-23--01-10-39.zip
3- remux again in test build: https://onedrive.live.com/?authkey=%21A ... ion=locate
I can confirm this method also works with BL_EL_RPU_dvhe.07.06.mp4 muxed with Atmos, so now DV + Atmos works on the shield :)
rosavanwinkle
Post by rosavanwinkle »
you guys are legendary....
Think this is one of the biggest forum posts i have ever seeing so alive
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Grencola
Post by Grencola »
baker99 wrote:
Tue Mar 03, 2020 9:48 am
This is definitely the best hope we have for real DV + atmos on the shield. All the dv info and hd-audio data is intact so it's finally the first fully lossless dv remux that works on a non standalone player. I'm trying to make a simple tool to create them based on yusesope's mad hax but I never have enough time to be efficient :(
mattmarsden
The other bonus is that it looks like these ts files are playable on non DV hardware so I can play them on my other TVs with Kodi.
ATD555
Post by ATD555 »
Grencola wrote:
Tue Mar 03, 2020 3:08 pm
So I started just messing around with reading hex from a text file and searching for blocks of the required hex code and pasting it into a new text file in the correct order for the BL+EL+RPU file. Only thing is that I am using an array and it is using way too much RAM especially if the text file is GBs big. Any ideas on what to do?
if any x700 owner can try this new test build...
now the TS DL DV file looks just like the mp4muxer.. I bet this fix all the issue we are having.
https://drive.google.com/file/d/1Gq5TAc ... sp=sharing
Complete name                            : D:\test.split.1.ts
File size                                : 300 MiB
Duration                                 : 1 min 0 s
Overall bit rate                         : 41.7 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Frame-Average Light Level        : 644 cd/m2
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
baker99
Post by baker99 »
RESET_9999 wrote:
Tue Mar 03, 2020 9:17 pm
File size                                : 300 MiB
Video #1
Video #2
I'll give this a try tomorrow, sorry it's a bit late for me tonight.
ragico
Post by ragico »
File size                                : 300 MiB
Video #1
Video #2
Tried and working apart the "usual" problem. Everything looks good, but if I pulled back to play another file, the entire screen is smeared with colorful mosaics like a broken screen. This is very annoying.
yep, bummer... still not recognized on the C8 and same ''play only one time'' bug on the x700.
ATD555
Post by ATD555 »
Has anyone had it where the TV displays the Dolby Vision icon but the video is very washed out and the black bars on the video are pretty much bright gray?
ATD555 wrote:
Tue Mar 03, 2020 11:05 pm
yep, this happened to me when I tried to remux a DL DV MP4 to DV TS. my fix was to demux the mp4 first with ''dlb_mp4demux'' and then build a new TS.
rosavanwinkle
If you give me your test files,i'm more then willing too test them,
Same for everybody else
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
