So we are at another stumbling block, tsmuxer won't support TrueHD without ac3. Maybe Plex can add ac3 core support in a ts, although I'm not holding my breath for that.mattmarsden wrote: ↑Mon Mar 02, 2020 10:27 amYes mkv doesn't work, neither does m2ts - only ts at the moment.
From the tsmuxer dev forum -
Ok then, I'll do a build without the DoVi descriptors for testing...
Edit: ok, so after lots of trials and errors, I come to the conclusion that there seems to be no TS descriptor for PGS. And if we put back the HDMV registration descriptor to read PGS in TS would break DV compatibility with standalone players. Same for AC3/TrueHD.
So you can't have everything: PGS and interleaved AC3/TrueHD are HDMV streams and must be muxed in m2ts.
And there is no TS or HDMV descriptor for TrueHD (without AC3), so no way to include it in tsMuxer.
