Weird Result with MAKEMKV
servocrow
#1 Post by servocrow » Fri Oct 22, 2010 11:17 am
Have been using MAKEMKV without a hiccup until today. AMERICAN WEREWOLF IN LONDON seemed to rip ok, plays in almost any media player etc.. howvever every program I put it in to shrink it down a bit, handbrake, divx convertor will not work, this file crashes both programs, i tried re ripping the disc with updated MAKEMKV to only have the same results?? help !!
crowfax
Re: Weird Result with MAKEMKV
#2 Post by crowfax » Fri Oct 22, 2010 4:49 pm
servocrow wrote:Have been using MAKEMKV without a hiccup until today. AMERICAN WEREWOLF IN LONDON seemed to rip ok, plays in almost any media player etc.. howvever every program I put it in to shrink it down a bit, handbrake, divx convertor will not work, this file crashes both programs, i tried re ripping the disc with updated MAKEMKV to only have the same results?? help !!
Try using the latest version of Handbrake from here: https://build.handbrake.fr/
servocrow
#3 Post by servocrow » Fri Oct 22, 2010 7:53 pm
I did in fact attempt running it though the NIGHTLY rebuild of HANDBRAKE early this am, can check on it once I get home but it did get alot farther down the line as I left to go to work.....
someone else suggested I run ANY DVD then run MAKEMKV and re-rip it????
think that might make a differnce??
I am gonna give that a try as well
thoughts?
skittle
#4 Post by skittle » Fri Oct 22, 2010 8:07 pm
No, that will no help. Please post mediainfo output of the file.
servocrow
#5 Post by servocrow » Fri Oct 22, 2010 10:06 pm
i am still at work for a few more hours, I WILL def. post mediainfo output when I get a chance. I really would like to know what the heck is going on. Thx :)
servocrow
#6 Post by servocrow » Fri Oct 22, 2010 11:20 pm
here is a copy of the text file:
General
Complete name : C:\Users\XXXXX\Desktop\title00.mkv
Format : Matroska
File size : 22.5 GiB
Duration : 1h 37mn
Overall bit rate : 33.1 Mbps
Encoded date : UTC 2010-10-22 02:54:36
Writing application : MakeMKV v1.6.2 win(x64-release)
Writing library : libmakemkv v1.6.2 (0.7.7/0.8.1) win(x64-release)
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 1h 37mn
Bit rate : 30.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.621
Stream size : 21.0 GiB (93%)
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.03 GiB (5%)
Title : 3/2+1
Language : English
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Spanish
Menu
00:00:00.000 : en:Chapter 00
00:02:33.153 : en:Chapter 01
00:06:19.629 : en:Chapter 02
00:13:52.456 : en:Chapter 03
00:17:24.126 : en:Chapter 04
00:28:34.629 : en:Chapter 05
00:33:01.646 : en:Chapter 06
00:37:40.967 : en:Chapter 07
00:42:56.615 : en:Chapter 08
00:47:38.230 : en:Chapter 09
00:53:32.000 : en:Chapter 10
00:58:16.618 : en:Chapter 11
01:01:22.470 : en:Chapter 12
01:05:31.010 : en:Chapter 13
01:09:15.818 : en:Chapter 14
01:15:18.096 : en:Chapter 15
01:21:42.731 : en:Chapter 16
01:26:29.142 : en:Chapter 17
01:31:56.844 : en:Chapter 18
01:33:42.992 : en:Chapter 19
setarip_old
#7 Post by setarip_old » Sat Oct 23, 2010 1:15 am
@servocrow
Hi!
Are you sure that the compression programs you've tried to use are capable of processing VC-1 video format?
servocrow
#8 Post by servocrow » Sat Oct 23, 2010 1:46 am
not sure i was trying to use HandBrake, then tried DIVX convertor, both to no avail.
setarip_old
#9 Post by setarip_old » Sat Oct 23, 2010 4:25 am
Well, you might want to research that ;>}
skittle
#10 Post by skittle » Sat Oct 23, 2010 5:53 am
Yes, its the VC-1 causing issues, but nightly handbrake build should be able to handle it. If not you can use a newer x264 build with ffmpegsource.
servocrow
#11 Post by servocrow » Sat Oct 23, 2010 10:58 am
ran it through RIPBOT, worked out fine as well as HB's nightly build.
THx for everyones help.
setarip_old
Re: Weird Result with MAKEMKV - RESOLVED
#12 Post by setarip_old » Sat Oct 23, 2010 9:30 pm
Glad to hear your problem was so easily resolved ;>}
