Frozen 2 4k UHD Volume Key Unknown
BrettE
Post by BrettE » Sat Feb 29, 2020 2:20 pm
I'm having some trouble ripping my new copy of Frozen 2 in 4k. I've ripped lots of UHD discs with this drive. It's an LG WH16NS4, and I forget the precise firmware version, but I loaded it with some version in about April of 2019. lshw shows 1.00, but I'm not 100% confident that's the version on there.
I've attached the MKB20_v72_Frozen_II_E424.tgz file and the log file. Since the log is short, I also pasted it below if that's easier for anyone.
I've tried grabbing the latest keys_hashed.txt and the lastest SDF file, but neither of those seemed to help. I restarted MakeMKV after getting each of those files.
Thanks!!
Bret
MakeMKV v1.14.7 linux(x64-release) started
Debug logging enabled, log will be saved as /home/brett/MakeMKV_log.txt
Downloading latest SDF to /home/brett/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
DEBUG: Code 109 at %4eb&faOBy\h%NPd:213143922
Using LibreDrive mode (v05 id=4FBA32AEC678)
Downloading latest HK to /home/brett/.MakeMKV ...
DEBUG: Code 0 at %4eb&faOBy\h%NPd:121267500
Saved AACS dump file as /home/brett/.MakeMKV/MKB20_v72_Frozen_II_E424.tgz
DEBUG: Code 0 at Y<;Se1SdA#A1v ue:29396092
DEBUG: Code 0 at Y<;Se1SdA#A1v ue:29395172
(3.25 MiB) Downloaded 651 times
MakeMKV_log.txt
(1.5 KiB) Downloaded 653 times
Re: Frozen 2 4k UHD Volume Key Unknown
Post by Woodstock » Sat Feb 29, 2020 3:38 pm
Posting the MKB2 file here doesn't do much good; it needs to be emailed to svq@makemkv.com for processing.
According to this topic on Frozen 2, others are ripping the disk; this part of the log probably indicates why you're having issues:
Have you checked this topic for ways to find out if your system is preventing the download of the latest hash keys? The automatic download is significantly newer than the static download.
Malwarebytes blocks access to hkdata.fairuse.org. I just had to create an exception for that domain to continue getting new keys.
I've been using CloudFlare's 1.1.1.1 DNS service for a few months and it turns out hkdata.fairuse.org just won't resolve with this DNS service. Switched to Google's 8.8.8.8 DNS address and all is working now!
BrettE
Post by BrettE » Sat Feb 29, 2020 10:59 pm
Admittedly I did not read through all 10 pages of that topic. The second post in the topic said something like:
You can always download SDF.bin manually from https://www.makemkv.com/svq/sdf.bin and put it into MakeMKV data directory. On next launch MakeMKV will consume the file and shut up
Which I assumed meant I could just do that. When that didn't work I thought perhaps something else was wrong.
I'll go back to that topic and dig through it to figure out what's wrong.
Brett
BrettE
Post by BrettE » Sat Feb 29, 2020 11:31 pm
Mission success has been achieved. I'm running PiHole, and it's pointed to Quad9 filtered with DNSSEC, which won't resolve hkdata.fairuse.org. I temporarily switched my upstream DNS for PiHole, and it was able to get the latest HK data.
Next I'll figure out how to make PiHole resolved a specific URL with a specific DNS, so I won't have to poke it every time I need to update hash keys.
Thank you for your help.
Brett
drdmal
Post by drdmal » Sun Mar 01, 2020 2:09 am
I'm also unable to rip Frozen II. If it matters, I bought my copy at WalMart. I've sent the MKB2 file on to svq@makemkv.com. Hopefully it'll get fixed with the next SDF download for me.
