I love how MakeMKV can create MKVs with FLAC audio right from a disc, but how can I configure MakeMKV to save those audio files as 16-bit rather than 24-bit (and from higher sampling rates to, say, 48KHz when necessary)?
I prefer to keep lossless audio when I can, but higher bits-per-sample and (usually) higher sample rate yields zero benefit outside of higher sales. I prefer to keep FLAC because the files are typically smaller than DTS-MA or Dolby THD, and are well supported on PCs. Still trying to get Kodi to work with them, but that's for another time .
EDIT: I had taken a look at the Advanced Usage forum threads "On the fly audio conversion" and "Audio Conversion" as well as other posts found with a search for "down16" (a command-line parameter used by eac3to, though I understand that MakeMKV uses ffmpeg, however I am not familiar with how to change ffmpeg's parameters in MakeMKV).
FLAC profile: Convert to 16-bit
Re: FLAC profile: Convert to 16-bit
Did you find a solution for this? I'm looking for the exact same thing. So much space wasted with 24/96 placebo
