How did you create the single layer DV 7.06 BL+EL+RPU file?yusesope wrote: ↑Fri Feb 28, 2020 8:04 pmThanks for the tests guys.
I made changes based on your feedbacks.
Are you ready for the second round?
HERE you can find the new files (I also added the profile dvhe.08.06)
I think I'm onto something: I am also able to demux Single Layer DV files and transform them into Dual Layer DV files.
I made an attempt with the file you find HERE.
The result is this (HERE the DL file):Code: Select all
Video #1 ID : 1 Formato : HEVC Formato/Informazioni : High Efficiency Video Coding Profilo formato : Main 10@L5@Main ID codec : hev1 ID codec/Informazioni : High Efficiency Video Coding Durata : 1 min 14s Bitrate : 15,4 Mb/s Larghezza : 3.840 pixel Altezza : 2.160 pixel Rapporto aspetto visualizzazione : 16:9 Modalità frame rate : Costante Frame rate : 23,976 (24000/1001) FPS Spazio colore : YUV Croma subsampling : 4:2:0 Profondità bit : 10 bit Bit/(pixel*frame) : 0.077 Dimensione della traccia : 137MiB (74%) Default : Si AlternateGroup/String : 1 Data codifica : UTC 2020-02-28 19:23:55 Data : UTC 2020-02-28 19:23:55 Codec configuration box : hvcC Video #2 ID : 2 Formato : HEVC Formato/Informazioni : High Efficiency Video Coding Profilo formato : Main 10@L4@Main Dolby Vision : 1.0, dvhe.04.06, EL+RPU ID codec : hev1 ID codec/Informazioni : High Efficiency Video Coding Durata : 1 min 14s Bitrate : 5.519 kb/s Larghezza : 1.920 pixel Altezza : 1.080 pixel Rapporto aspetto visualizzazione : 16:9 Modalità frame rate : Costante Frame rate : 23,976 (24000/1001) FPS Spazio colore : YUV Croma subsampling : 4:2:0 Profondità bit : 10 bit Bit/(pixel*frame) : 0.111 Dimensione della traccia : 49,0MiB (26%) Default : No AlternateGroup/String : 1 Data codifica : UTC 2020-02-28 19:23:55 Data : UTC 2020-02-28 19:23:55 Codec configuration box : hvcC+dvcC
@Grencola
I am not using any other tools.
Just my code.
If it works, I can write the part of the program that accepts prompt commands based on your needs.
My tool accepts the Base and Enhancement layer as input (raw HEVC, for example BL.hevc and EL.hevc after a demuxing with ffmpeg) and returns a raw HEVC file in which all the levels are combined (BL_EL_RPU.hevc) .
The file can be imported as it is into tsMuxeR.
At the moment, however, tsMuxeR discards the EL level by returning an BL + RPU file.
You can test it with my files.
You should use ffmpeg:and then import my_raw_test_file.hevc in tsMuxeRCode: Select all
ffmmpeg -i my_test_file.mp4 -c copy my_raw_test_file.hevc
When I get the code fixed I will release the source code so you can play it as much as you like.
As for the problems with the colors and DVDFab, my idea is similar to that expressed on the Mrmc forum (HERE)
I don't want to be pessimistic but I think like you, two things;DaMacFunkin wrote: ↑Sat Feb 29, 2020 7:30 amHi, it isn’t color space it is color profile, UHD disks don’t contain the correct profile for the single layer Dolby Vision specification, as good as this news is it is conceivable that the resulting files are also incorrect.mattmarsden wrote: ↑Fri Feb 28, 2020 8:48 pmSo do you think your tool is creating a DV file with correct colourspace etc?
- If this is only DV why people can't play certain profiles and play HDR instead?
- If this is posible, why the companies create a second stream for DV?
I attempted this yesterday and had the same result as with DVDFab SL, Atmos isn't triggered on the shield snd it causes jumpy playback, I suspect it's something to do with plex itself and ts filesGrencola wrote: ↑Fri Feb 28, 2020 6:22 pmare you able to use tsmuxer nightly to turn that mp4 file into a ts and add any old atmos track to see if it all works?mattmarsden wrote: ↑Fri Feb 28, 2020 4:28 pmSo as others have said the 05.06 profile works fine in Plex on the 2019 Shield - it would be great to be able to have a play around with the tool, especially as the start of Terminator is difficult to judge colours etc on.
DL also supports 12 bit I believe whereas SL doesn't, I doubt there's a huge difference without a 12bit display.hepe9 wrote: ↑Sat Feb 29, 2020 10:45 amI don't want to be pessimistic but I think like you, two things;DaMacFunkin wrote: ↑Sat Feb 29, 2020 7:30 amHi, it isn’t color space it is color profile, UHD disks don’t contain the correct profile for the single layer Dolby Vision specification, as good as this news is it is conceivable that the resulting files are also incorrect.mattmarsden wrote: ↑Fri Feb 28, 2020 8:48 pmSo do you think your tool is creating a DV file with correct colourspace etc?
I want to believe, but I don't want to get my hopes up, its to good to be truebaker99 wrote: ↑Sat Feb 29, 2020 10:48 amDL also supports 12 bit I believe whereas SL doesn't, I doubt there's a huge difference without a 12bit display.hepe9 wrote: ↑Sat Feb 29, 2020 10:45 amI don't want to be pessimistic but I think like you, two things;DaMacFunkin wrote: ↑Sat Feb 29, 2020 7:30 am
mattmarsden
I think its because plex doesnt like TrueHD with embedded ac3, but I’m not certain on this.baker99 wrote: ↑Sat Feb 29, 2020 10:46 amI attempted this yesterday and had the same result as with DVDFab SL, Atmos isn't triggered on the shield snd it causes jumpy playback, I suspect it's something to do with plex itself and ts filesGrencola wrote: ↑Fri Feb 28, 2020 6:22 pmare you able to use tsmuxer nightly to turn that mp4 file into a ts and add any old atmos track to see if it all works?mattmarsden wrote: ↑Fri Feb 28, 2020 4:28 pmSo as others have said the 05.06 profile works fine in Plex on the 2019 Shield - it would be great to be able to have a play around with the tool, especially as the start of Terminator is difficult to judge colours etc on.
Interesting, I wonder if we could strip the embedded ac3 and maintain the atmos/thdmattmarsden wrote: ↑Sat Feb 29, 2020 11:08 amI think its because plex doesnt like TrueHD with embedded ac3, but I’m not certain on this.
mattmarsden
Its easy to strip the ac3 its just that tsmuxer doesnt currently accept thd without embedded ac3.
Yep just figured this out, frustrating as it's so close to working. I'm pretty sure you are correct about the ac3 being the issue, I stripped it out using mkvtools and the test video ran with Atmos, unfortunately it also strips the DV leaving it as plain HDRmattmarsden wrote: ↑Sat Feb 29, 2020 12:52 pmIts easy to strip the ac3 its just that tsmuxer doesnt currently accept thd without embedded ac3.
A quick update, using the 7.06 test file muxed with an Atmos track seems to play with both Atmos and Dolby vision in mx player (it seems to not always detect dolby vision but that may be my settings).
superfans124
oh shit...here we go again! another breakthrough (and comes with another endless round of tinkering, lol)!RESET_9999 wrote: ↑Fri Feb 28, 2020 1:12 amgood news, DL DV TS made by Tsmuxer are the real deal.
identical in real life and so is the screenshots comparison: https://slow.pics/c/V994dhhF
DV, Atmos, Subtitles, and even fast-forwarding now works. this is awesome.
I tried it, tsmuxer + x700 = DL TS, seems to work: My go-to "DV lab rat" is The Meg, the UHD is mastered to 4000-nits, when played on my C6 (500-ish max nits) in HDR10, all the above-water scene have blown background: a solid white blanket. Only in DV I can see clear separation of blue sky and the white clouds in background. Maybe not exhaustive, but passed my eyeball test.
And AVR recognizes the Dolby Atmos in the DL TS file! And x700 can display PGS subtitle! Fast forward works without crashing the X700! AND it works off DLNA server (within its 100m ethernet port limitation).
Except I'm having this one MAJOR ANNOYING problem with my x700: I can only play one file...
I tested The Meg quick to see the DV highlights, everything looks good, then I pulled back to play another test file, now the entire screen is smeared with colorful mosaics like a broken screen. tested another file, same thing (audio-dolby atmos still plays in the background).
If I shut the x700 down for sometime (don't know how long is required) and come back, the first DL TS file would play PERFECTLY again, but then all other files would play corruptly AGAIN, forcing me to shut it down, or play this one file (though I have not played any one DL TS file in its entirety to verify).
IDK what the problem is: Tsmuxer is 2/28 nightly build, all my AV components: x700, x4300h, C6 are old models that haven't had an update for quite sometime. Judging how the first file plays fine, it's not a HDMI cable issue. I hope it's a software settings issue somewhere in my AV equipments, and not due to hardware limitation (2016 LG OLEDs do have "old man quirks")...
yep, same issue here.... this also happened when I tested DVDFab's single layers files in the past.superfans124 wrote: ↑Sat Feb 29, 2020 3:40 pmExcept I'm having this one MAJOR ANNOYING problem with my x700: I can only play one file...
this is not ideal but I'm still happy that I can now watch DV movies with Atmos. Well, I didn't watch a complete movie yet, maybe other issues will show up. fingers crossed...
so if my only problem is that I cant watch two movies in a row (which I almost never do) without rebooting, this is not that big of a deal for me.
Now it's time to enjoy that breakthrough and hopefully, no more issue shows up.
superfans124
...I.just.love.keep.discovering.all.the.capabilities.and.limitations.of.the.x700...(no, I don't. not really.RESET_9999 wrote: ↑Sat Feb 29, 2020 4:14 pmyep, same issue here.... this also happened when I tested DVDFab's single layers files in the past.superfans124 wrote: ↑Sat Feb 29, 2020 3:40 pmExcept I'm having this one MAJOR ANNOYING problem with my x700: I can only play one file...
Same problem here with Lg C8 and sony 5000 soundbar.superfans124 wrote: ↑Sat Feb 29, 2020 3:40 pmoh shit...here we go again! another breakthrough (and comes with another endless round of tinkering, lol)!RESET_9999 wrote: ↑Fri Feb 28, 2020 1:12 amgood news, DL DV TS made by Tsmuxer are the real deal.
Maybe the problem lies in the x700.
I doubt the problem is the x700.. it never happens with bluray disc or mp4 (made with mp4 muxer).
looks like tsmuxer is doing something wrong. It's probably the same reason why the file won't play on the C8
Also, a friend of mine tested the DL TS with a Phillips bluray player ( can play DL MP4) and the TS failed to play.
So far I think only the x700 and the oppo can play those DL TS files.
