Newbie - Just Flashed Asus BW-16D1HT
SykesiT
Post by SykesiT » Fri Feb 28, 2020 7:43 pm
I have just flashed my Asus BW-16D!HT from 3.10 to 3.10MK but on MKV the firmware still says 3.10 but how do I know it has worked as I don't have a 4K disc yet to test.
Re: Newbie - Just Flashed Asus BW-16D1HT
Post by Billycar11 » Sat Feb 29, 2020 12:36 am
read firmware type
jonghotti
Post by jonghotti » Sat Feb 29, 2020 12:36 am
If you'd taken a screen shot before you'd flashed it you'd have the two to compare and see the difference. I can verify, you did it right :)
SykesiT
Post by SykesiT » Sat Feb 29, 2020 9:48 am
Thanks.
I know I should have taken a screenshot before but hindsight is a wonderful thing.
jonghotti
Post by jonghotti » Sat Feb 29, 2020 11:42 am
SykesiT wrote: Sat Feb 29, 2020 9:48 am Thanks.
And I wasn't saying that in a snarky way, sorry if it came out like that.
SykesiT
Post by SykesiT » Wed Mar 04, 2020 6:45 pm
No I know, I should have taken a screenshot.
Mondays
Post by Mondays » Thu Mar 05, 2020 10:52 pm
SykesiT wrote: Fri Feb 28, 2020 7:43 pm I have just flashed my Asus BW-16D!HT from 3.10 to 3.10MK but on MKV the firmware still says 3.10 but how do I know it has worked as I don't have a 4K disc yet to test.
I just added the same drive ASUS BW-16D1HT
Can you point me to where you found the correct firmware to flash?
This is what my drive shows now
Harware support: Yes
Firmware support: No
Firmware version: 3.10
So I assume yours said the same and it looks like your firmware update worked??
Post by SamuriHL » Thu Mar 05, 2020 11:00 pm
Look at the sticky topics at the top of this very forum and you'll find the custom mk firmware thread. The link to the firmware is in there.
Mondays
Post by Mondays » Thu Mar 05, 2020 11:14 pm
SamuriHL wrote: Thu Mar 05, 2020 11:00 pm Look at the sticky topics at the top of this very forum and you'll find the custom mk firmware thread. The link to the firmware is in there.
Found the thread in the firmware for the drive. Two questions.
Mike says" (this topic will be updated with detailed flashing instructions later)"
I do not see any flash instructions in the thread yet. Do I update the firmware like I would standard firmware for a DVD drive? Would hate to mess up a drive I just installed in my computer.
Since I seem to be able to rip Blu-rays and find the FLP title just fine, and no UHD yet, what does the patch get me ?
Post by SamuriHL » Thu Mar 05, 2020 11:43 pm
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
See that thread for info on how to flash. It's pretty painless and if you follow the instructions (there are videos linked in that first post) there's not a lot of risk involved.
Having LibreDrive support is a benefit even on regular blu-rays. Typically new MKB's are released (from time to time) with new titles. These MKB's can block your ability to decrypt even older discs until new MKB support is released in MakeMKV. mike's usually quite fast at that so not a really big deal, however, LibreDrive allows you to ignore MKB's altogether and will allow you to forever decrypt all your titles that have title keys available forever. So, that's quite the benefit I think. :)
Mondays
Post by Mondays » Fri Mar 06, 2020 12:19 am
SamuriHL wrote: Thu Mar 05, 2020 11:43 pm https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Perfect. A couple quick questions before I flash. How do I determine the drive platform? I googled, could not find anything about drive platforms related to MT1959
Also, since my drive is ASUS BW-16D1HT I assume number 3 (SVC NS50+ LG only) does not apply to me
IMPORTANT Before you flash:
2. Drive Platform MT1959<Most important
3. SVC NS50+ LG only
Post by SamuriHL » Fri Mar 06, 2020 12:30 am
Right. You should be flashing the BW-16D1HT 3.10 MK firmware. And then you are done.
Mondays
Post by Mondays » Fri Mar 06, 2020 12:56 am
I flashed my drive and it now says:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ***
Bus encryption flags: 1F
Highest AACS version: 70
In the video, he flashes, then skips the reboot and says he wants to show everything in one take, so goes to an Asus downgrade tool, I couldn't find that tool and don't know if I need to run it?
Do I need to run the the Asus downgrade tool now? Maybe I am only halfway done.
I tested and everything seems to be working normally with the drive.
Post by SamuriHL » Fri Mar 06, 2020 1:01 am
Nope. Leave it alone at this point . It's now fully LibreDrive compatible and if in the future you wanted to, ready to support UHD.
Mondays
Post by Mondays » Fri Mar 06, 2020 1:05 am
Yeah, thanks for your help. So easy.
