Knives Out UHD
bmillham
Re: Knives Out UHD
Post by bmillham » Thu Feb 27, 2020 5:42 am
Walmart retail version still not working. Just submitted the dump.
thrillcat
Re: Knives Out UHD
Post by thrillcat » Thu Feb 27, 2020 11:30 pm
Anyone having luck yet?
Re: Knives Out UHD
Post by mike admin » Thu Feb 27, 2020 11:43 pm
in about 15 minutes...
thrillcat
Re: Knives Out UHD
Post by thrillcat » Thu Feb 27, 2020 11:46 pm
Excellent. Thank you v much!
dmillionz
Re: Knives Out UHD
Post by dmillionz » Fri Feb 28, 2020 12:10 am
Thanks Mike. Backing up now. 945.mpls
Re: Knives Out UHD
Post by SamuriHL » Fri Feb 28, 2020 12:45 am
Yup, confirmed mine is working now, as well. Thanks, Mike!
rstevens76
Re: Knives Out UHD
Post by rstevens76 » Sat Feb 29, 2020 7:39 am
I have backed up this film twice and all of the scenes are out of order. Has anyone else experienced this problem?
dmillionz
Re: Knives Out UHD
Post by dmillionz » Sat Feb 29, 2020 8:07 pm
I haven't tried to watch it yet. What mpls did you rip?
Re: Knives Out UHD
Post by SamuriHL » Sat Feb 29, 2020 9:08 pm
Title 945 was correct on my particular disc. And because I wanted to watch it with madvr, I had to rip it to MKV using the monkey because at the time MakeMKV didn't yet support it. And let me tell you, that experience reenforced the exact process I use because I had massive audio sync issues with the dvdfab created MKV 43 minutes into the movie. I ended up switching to the UB820 and watching the rest of it on disc as a result. Ripping with MakeMKV and using CloneBD to create the MKV worked perfectly with no audio sync issues. Thank god for MakeMKV!!!! These ATMOS tracks are seriously problematic. /soapbox:whining :D
Re: Knives Out UHD
Post by shawnc22 » Sun Mar 01, 2020 2:10 am
do you think you'd have same the audio sync issue if you go now straight from the disk to mkv with makemkv? i was under the impression that most of those issues were had with the pixar movies
Re: Knives Out UHD
Post by SamuriHL » Sun Mar 01, 2020 3:15 am
The issue is more prominent in Pixar/Disney titles, yes, but, it's a problem with the way ATMOS is stored in MKV. So my guess is that maybe. I don't process them that way and use MakeMKV just as a backup to folder option. The process works really well.
rstevens76
Re: Knives Out UHD
Post by rstevens76 » Sun Mar 01, 2020 3:42 am
I did try a different title (though I don’t remember which one off the top of my head) and it appears to have worked the third time around.
bmillham
Re: Knives Out UHD
Post by bmillham » Mon Mar 02, 2020 5:15 am
I can confirm it's working now for the Walmart retail version. It's interesting but the Walmart version does not seem to have ScreenPass as I only had one title available and it was 945.
speeddemon
Re: Knives Out UHD
Post by speeddemon » Thu Mar 05, 2020 7:09 am
Is there eventually going to be a fix in MakeMKV to enable us to perform full backups of these films while removing ScreenPass?
My issue is that the I want to be able to backup my movies so I can play them back on my Oppo BDP-203, but I don't want to lose Dolby Vision in the process.
If I have to just backup Playlist 945 in this case to an MKV file then I lose the ability to playback Dolby Vision and also run into the Oppo's "issues" with Dolby Atmos tracks in MKV files.
jonghotti
Re: Knives Out UHD
Post by jonghotti » Wed Mar 25, 2020 5:16 am
