ET The Extra-Terrestrial
toddInPortland
#1 Post by toddInPortland » Thu Feb 27, 2020 1:22 am
Makemkv reports "AACS v25 with blu-ray label ET_DOM
Failure:
Using LibreDrive mode (v05 id=7FA2657C7667)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?c6gTNCc10trFUd...
Saved AACS dump file as /archive1/backup/movies/MKB_v25_E_T_The_Extra-Terrestrial_F1A2.tgz
I have the tar file (1.2M) if that would be helpful.
Re: ET The Extra-Terrestrial
#2 Post by Woodstock » Thu Feb 27, 2020 3:07 am
What version of MakeMKV are you running?!?
AACSv25 support was added to MakeMKV v1.6.10, in May of 2011.
The current version is 1.14.7.
#3 Post by Billycar11 » Thu Feb 27, 2020 3:16 am
but he has libre drive mode that was added much later then 2011
are you sure this is not a UHD?
#4 Post by Woodstock » Thu Feb 27, 2020 3:37 am
UHD would create an MKB2 file.
#5 Post by Billycar11 » Thu Feb 27, 2020 3:46 am
yeah i guess so
Grauhaar
#6 Post by Grauhaar » Thu Feb 27, 2020 1:42 pm
I have had this also for serval discs in the past with older AACS versions. Looks that sometimes MakeMKV or the Drive has some strange problem. Restarting the system solves this kind of trouble for me in all cases.
Good Luck :)
