Knives Out UHD
Knives Out UHD
My U.S. retail version of the disc is not currently decrypting.
Dump submitted!
Dump submitted!
Re: Knives Out UHD
Wow, that was fast! Thanks Mike.
Edit:
This one has screenpass like Midway. It seems it has officially come to UHD.
I can't confirm it 100%, but I believe the correct playlist is: 945.
Edit:
Re: Knives Out UHD
The sheep reporting 945 as correct playlist.
Re: Knives Out UHD
I just submitted the dump for this disc. Monkey says 945 for mine, too,
stuckinkodiagain
cheeplives
Re: Knives Out UHD
I submitted my Amazon copy's dump as well.
Re: Knives Out UHD
Mine did, hours before your post.stuckinkodiagain wrote: ↑Wed Feb 26, 2020 12:17 amBest Buy retail copy will not decrypt yet. Dump file submitted to svq@makemkv.com
stuckinkodiagain
Re: Knives Out UHD
Steelbook or regular? (Mine is regular, and I just tried again but it won't decrypt.)rdgrimes wrote: ↑Wed Feb 26, 2020 3:29 amMine did, hours before your post.stuckinkodiagain wrote: ↑Wed Feb 26, 2020 12:17 amBest Buy retail copy will not decrypt yet. Dump file submitted to svq@makemkv.com
Re: Knives Out UHD
I likely have the same disc as yours. I just tried it a couple minutes ago and it's not yet supported. I made a protected iso so I can quickly check periodically without having to keep manhandling the disc.
Re: Knives Out UHD
Regular, I pre-ordered from BB. I did notice it had the little sticker that seals the edge of the case - that you have to peel off. They don't normally have that, so it could have been sourced differently.stuckinkodiagain wrote: ↑Wed Feb 26, 2020 4:05 amSteelbook or regular? (Mine is regular, and I just tried again but it won't decrypt.)rdgrimes wrote: ↑Wed Feb 26, 2020 3:29 amMine did, hours before your post.stuckinkodiagain wrote: ↑Wed Feb 26, 2020 12:17 amBest Buy retail copy will not decrypt yet. Dump file submitted to svq@makemkv.com
Re: Knives Out UHD
Mine had the same anti-theft sticker across the top. I thought they got away from doing that given that they're shrink wrapped but apparently not. I've been checking my ISO periodically and it's still not support yet.
Re: Knives Out UHD
I just rented the Redbox version in UHD and it did not have multiple copies. It did fail to read the first time, I closer makemkv and reopened it and it worked just fine.
Re: Knives Out UHD
Submitted a dump for the Redbox UHD of this last night, still no luck.
Anyone successfully backed it up yet?
Re: Knives Out UHD
I just tried again as well. No go. I purchased my version from Amazon. It had the sticker on the top edge also. I sent the Dump yesterday as well.
Re: Knives Out UHD
Mike will get to it. We just need to wait a bit and keep checking.
(I know... easy for me to say since I already backed it up. Lol)
