Starting a thread to capture Zombieland UHD fails to read.
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXXXX/MakeMKV_log.txt
Using LibreDrive mode (v05 id=4FBA32AEC678)
Saved AACS dump file as C:\Users\XXXXXXXXXXX/.MakeMKV/MKB21_v70_Zombieland_1C8D.tgz
DEBUG: Code 0 at fQBBRwh9d#b@m]:t:29396092
DEBUG: Code 0 at fQBBRwh9d#b@m]:t:29395172
Zombieland UHD - Failed to open disc
khaitzu
- MKB21_v70_Zombieland_1C8D.tgz
- (1.62 MiB) Downloaded 657 times
st4evr
Re: Zombieland UHD - Failed to open disc
Read this:
https://www.makemkv.com/forum/viewtopic ... 12&t=21380
Posting the dump file in the forum is of no help.
And there are already plenty of existing discussions for this release:
https://www.makemkv.com/forum/search.ph ... bbdd275ffb
Forum search function works. Use it. It will often provide answers to these common questions/problems.
