built_to_chill
Post by built_to_chill »
RESET_9999 wrote: Mon Feb 24, 2020 5:28 pm
built_to_chill wrote: Mon Feb 24, 2020 2:48 pm
Hi there - I took a look at TSMuxer and it seems it can take various things (including mkv and i believe MP4) as input, and output an ISO. Just curious if you’re suggesting above this could be a route to getting Dolby vision and Dolby Atmos playback on the X700 when starting with an mkv?
Or whether this would require re-ripping everything to ISO using makemkv?
yes you can create a DV ISO from MKV using the latest tsmuxer but you'll have to process Atmos with eac3to first because tsmuxer wont accept ATmos without an AC3 core.
When a movie compress very well(CRF 14 or better) that's what i do. I re-encode the HDR10 layer to fit a BD-50 and then use tsmuxer to build a new iso with DV and Atmos and then i burn it.
I did that with a couple (about10) of movies and the x700 play my custom iso properly.
Many thanks for clarifying. Ah - if I follow - you have to literally burn to disc to get the X700 to play these.
I had been playing with eac3 to try and make m2ts files of my Atmos mkvs. So far it hasn’t run successfully but I am running it via wine on Ubuntu.
On the plus side I think the X700 effectively does DV auto switching for video files. With DV set to
on and playing an HDR10 mkv just now it did not play in forced Dolby vision. That’s great if don’t have to keep turning it on and off like you do for the actual discs.
built_to_chill wrote: Mon Feb 24, 2020 8:21 pm
on the plus side I think the X700 effectively does DV auto switching for video files. With DV set to
Yes but the x700 does not support atmos in an mkv container because the AC3 core is missing. So you need the m2ts file for Atmos and if you let DV turned on, you get fake DV.
yes
I dont know the exact cmd-line or anything about ubuntu but its very easy with the EAC3to GUI
https://forum.doom9.org/showthread.php?t=125966
I tried with a profile 5 demos, Atmos and DV work on the x700 but playback is jumpy. (maybe because i used some random external atmos track)
then BIG SURPRISE, I tried to remux an original dual layer m2ts to TS without using the mp4muxer at all ... the file play properly in DV with atmos on the x700 WOW
this is a direct remux from the disc to TS using tsmuxer (no mp4muxer):
omplete name                            : D:\other\DEMOS\DL-DV-ATMOS-REMUX.ts
File size                                : 51.8 GiB
Duration                                 : 2 h 14 min
Overall bit rate                         : 55.1 Mb/s
Video #1
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL / SMPTE ST 2086, HDR10 compatible
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 134 kb/s
Stream size                              : 616 MiB (1%)
Number of dynamic objects                : 13
henkeli
Post by henkeli »
RESET_9999 wrote: Mon Feb 24, 2020 10:32 pm
That's awesome. Thanks also for listing the capabilities and limitations of the X700. Do you know if the X700 can play 3D Blu-ray backups as well in either M2TS, TS, and/or MKV format?
From your prior posts, it sounds like the X700 drops the MKV Atmos track due to the way in which the MKV is assembled?
Grencola
Post by Grencola »
RESET_9999 wrote: Mon Feb 24, 2020 10:32 pm I tried with a profile 5 demos, Atmos and DV work on the x700 but playback is jumpy. (maybe because i used some random external atmos track)
ah, the moment we've all been waiting for :) I wonder if the shield will do atmos + dv from a single layer ts file
on the Shield/PLEX:
I'm getting a black screen without audio for the dual layer TS.
I'm getting a black screen with atmos audio with the profile 5 demos with random external atmos.
on the oled:
unrecognized
on the vizio DV tv:
HDR10 only
henkeli wrote: Tue Feb 25, 2020 12:21 am Do you know if the X700 can play 3D Blu-ray backups as well in either M2TS, TS, and/or MKV format?
I don't know.
henkeli wrote: Tue Feb 25, 2020 12:21 am From your prior posts, it sounds like the X700 drops the MKV Atmos track due to the way in which the MKV is assembled?
yes
Grencola
Post by Grencola »
RESET_9999 wrote: Tue Feb 25, 2020 2:14 am on the Shield/PLEX:
the shield only supports dv profile 5. are you using the plex beta? I'm sure you are, but just in case, it's the only version that supports single layer dv.
RESET_9999 wrote: Tue Feb 25, 2020 2:14 am on the oled:
unrecognized
on the vizio DV tv:
HDR10 only
I have a Vizio PX 75, I thought for sure it would work since the dolby ts test samples play just fine. it's not earc anyway though so it doesn't matter, as nothing would be gained.
Grencola
Post by Grencola »
RESET_9999 wrote: Mon Feb 24, 2020 10:32 pm this is a direct remux from the disc to TS using tsmuxer (no mp4muxer):
Video #1
Video #2
Audio
Codec ID                                 : 131
one thing is concerning, and it could be the disc you tried, but how come the atmos track says lossy under compression mode, with a bitrate of only 640kbps / max 7134kbps and an ac3 mlp? every disc I've been checking says lossless compression with a bitrate around 5000+kbps/ max 8000+kbps and full thd mlp. it's like it's some weird atmos, that's not even eac3 dd+ atmos, but based on just ac3 instead or something. doesn't seem right to me.
what's also interesting is the main video layer says dolby vision now as well as the secondary layer. it's like it's doing a mixture of what dvdfab does to single layer mp4s but also keeping the 2nd video track. this should be fine though, since it has the el+rpu and the full second layer, just weird why it applies it like that.
yes, latest beta. I thought it would at least play the HDR10 layer but nop, black screen. the single layer mp4 works.
if I have more time tomorrow night, I'll try to remux the dvdfab single layer file to TS and play it with the shield.
it's a very cheap tv(M50-E1) that I use with my main PC. I'm not surprised that it doesn't work because most of the DV mp4 also plays in HDR10 only. it looks like it can't play the one with FEL DV.
surprising that it didn't play on the C8 though.
Grencola
Post by Grencola »
RESET_9999 wrote: Tue Feb 25, 2020 4:20 am if I have more time tomorrow night, I'll try to remux the dvdfab single layer file to TS and play it with the shield.
awesome, thx!
RESET_9999 wrote: Tue Feb 25, 2020 4:20 am surprising that it didn't play on the C8 though.
that is quite strange, yeah.
Grencola wrote: Tue Feb 25, 2020 4:12 am
yep, I noticed that too. I hope it's not just the HDR10 layer with a DV flag. I'll do some screenshot comparison when I get a chance.
one thing is concerning, how come the atmos track says lossy under compression mode, with a bitrate of 640kbps / max 7134kbps? every disc I've been checking says lossless and bitrate is around 4000kbps/ max 7000kbps... it's like it's based on ac3 instead of truehd core or something.
yep, strange.. but I watched it for about 15min and i think the audio sounded like lossless atmos(AVR showed ATMOS).. bluray player OSD showed usual atmos bitrate...
EDIT... mmm wtf? Stream size : 616 MiB (1%)
EDIT2:
so to be sure, I demuxed the audio and the size is normal so it's just mediainfo that cant read it properly.
still say lossy though:
Audio
Duration                                 : 17 h 24 min
Stream size                              : 4.67 GiB (100%)
EDIT3:
it says the same thing on the original m2ts.. so everything is normal
Complete name                            : M:\Jumanji.Welcome.to.the.Jungle.2017.DV\BDMV\STREAM\00001.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 52.4 GiB
Duration                                 : 1 h 59 min
Overall bit rate                         : 63.0 Mb/s
Maximum Overall bit rate                 : 128 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 2013 cd/m2
Maximum Frame-Average Light Level        : 393 cd/m2
Video #2
Audio #1
Codec ID                                 : 131
Maximum bit rate                         : 8 469 kb/s
Stream size                              : 545 MiB (1%)
baker99
Post by baker99 »
DL DV Atmos TS muxes seem to work great here on my X700 too, not on the C6 over dlna though. Crashes my 2019 Shield using plex after briefly showing the DV logo. I'ts a shame the wi-fi and lan speed are so rubbish on the X700 or I'd be able to finally stream DV rips of my films, resorting to usb is a pain. I'll try a single layer conversion when I get chance, but I'm put off by DVDFab not using the correct colour space etc.
Grencola
Post by Grencola »
baker99 wrote: Tue Feb 25, 2020 4:55 pm DL DV Atmos TS muxes seem to work great here on my X700 too, not on the C6 over dlna though. Crashes my 2019 Shield using plex after briefly showing the DV logo. I'ts a shame the wi-fi and lan speed are so rubbish on the X700 or I'd be able to finally stream DV rips of my films, resorting to usb is a pain. I'll try a single layer conversion when I get chance, but I'm put off by DVDFab not using the correct colour space etc.
that would be great if you could test single layer ts on shield. you might be pleasantly surprised, the color space probably isn't exact but it's looks soo close to real dv and still much much better than reg hdr10. that, and the convenience of being on a shield would outweigh the difference imho.
ragico
Post by ragico »
Grencola wrote: Tue Feb 25, 2020 6:07 pm
How you do a single layer DV in Tsmuxer? It crashes if you load a dvdfab generated mp4 file (single or double layer)
baker99
Post by baker99 »
ragico wrote: Tue Feb 25, 2020 6:12 pm
I'm using w64-nightly-2020-02-23--01-10-39 and it hasn't crashed yet, it's currently at 17% processing a single layer DV mp4 created by DVDFab. Will keep you updated.
