Der_unglaubliche_Hulk_UHD
kirdneh
Post by kirdneh »
anyone successfully ripped this one? Cannot open it due to "unknown disc volume key". Was my first try to rip an UHD disc.
I have an BW-16D1HT (ASUS) flashed with 3.10 successfully.
Downloaded most recent MKV version (MakeMKV v1.14.7) and downloaded the most recent hashed keys file and put it into
the data directory specified in the preferences.
In the textfile is one entry for exactly this title. However I cannot open the disc.
I am a bit irritated as I am not sure if the hashed key file is loaded, there is no log entry indicating that.
Did I do something wrong or is the key matching my disc simply missing?
st4evr
Re: Der_unglaubliche_Hulk_UHD
Post by st4evr »
Read this entire discussion:
https://www.makemkv.com/forum/viewtopic ... 389#p83389
Same process applies to you.
