Asus BC-12B1ST 3.11 Firmware Date 2119-20-27 13:21
Freshie
Post by Freshie »
I flashed my drive, and everything went fine. I just thought I should mention that the Firmware Date now reads 2119-20-27 13:21
It doesn't seem to be a problem, but I thought it might cause issues in the future.
st4evr
Re: Asus BC-12B1ST 3.11 Firmware Date 2119-20-27 13:21
Post by st4evr »
That is how some drive manufacturers (e.g LG, ASUS, PIONEER, etc) date their firmwares. It has nothing to do with MakeMKV or the modifications used/provided within the walls of this forum. As that part is not touched by the modifications that have taken place within the firmware versions used/provided here. If you would a like a change at that level or end up having some extremely rare and/or weird problem with that date format on your drive’s firmware (highly doubtful and unsure where you got such an idea that it would be a problem in the future ???) you will need to contact the drive manufacturer directly. Although, there is no guarantee anything will change as that has been the date code/format for 10+ years coming from said manufacturers.
Freshie wrote:
Tue Feb 25, 2020 2:23 am
As @st4evr said....
If you didn't notice, the date on your drive before flashing would have also been 2119-xx-xx.
you could also change it if you really wanted too it's around line 0x1ec056
it has drive model name and firmware date and all that junk
Freshie
Post by Freshie »
Thanks for the info. I'm not having any problems. I just thought I would report it in case it was within LibreDrive.
I thought that if there was a check for updates and the driver was future dated the update may not get applied.
Cheers.
st4evr
Post by st4evr »
Freshie wrote:
Tue Feb 25, 2020 2:29 pm
Cheers.
Firmware and “driver” are two very different things and that is not how this works.
