Freaks and Geeks Blu-Ray Collectors Set
Auss1e.mkv
Post by Auss1e.mkv » Tue Feb 25, 2020 6:22 am
I just got this but since it's region locked I can't play it in Australia to check which episode is which. Is anyone able to tell me which files are for which episodes? Would hate to watch the episodes out of order on my first run. Thanks!
Grauhaar
Re: Freaks and Geeks Blu-Ray Collectors Set
Post by Grauhaar » Tue Feb 25, 2020 8:28 am
Check this tip: https://www.makemkv.com/forum/viewtopic.php?f=6&t=20327
Very simple, but has always worked for me in the past.
Good Luck :)
Auss1e.mkv
Post by Auss1e.mkv » Tue Feb 25, 2020 10:40 am
Grauhaar wrote: Tue Feb 25, 2020 8:28 am Check this tip: https://www.makemkv.com/forum/viewtopic.php?f=6&t=20327
Yeah that's what I ended up doing. It's always worked for me in the past so I'm hoping Shout Factory hasn't done anything weird with this set. Since I've never seen the show before I can't be sure so fingers crossed!
kidney_thief1988
Post by kidney_thief1988 » Tue Feb 25, 2020 4:27 pm
While this generally works, it's not always surefire. The thing I find is more accurate than anything is going to the Wikipedia page for the show and matching the writer and director for each episode. Bones, for example, will also include extended versions of various episodes listed after the versions that aired on television, regardless of the order in which they aired. Downton Abbey and Game of Thrones had a few discs where the episodes are out of order as well.
