Linux native flashing
Re: Linux native flashing
Running remote on Windows also introduces a few extra security "gotchas", because the default for Windows is to not allow remote users access to things like optical drives...
Post by SamuriHL »
Yea, that's the default. ;) I have powershell scripts I wrote to enable LibreDrive and create an ISO with ImgBurn that I run remote. I just didn't expect MakeMKV to ask me questions in the shell. Oops. :)
SamuriHL wrote: Sat Feb 01, 2020 7:10 pm Yea, that's the default. ;) I have powershell scripts I wrote to enable LibreDrive and create an ISO with ImgBurn that I run remote. I just didn't expect MakeMKV to ask me questions in the shell. Oops. :)
There is a yes all option look at the thing I posted in the post about the sdf tool
Post by SamuriHL »
Billycar11 wrote: Sun Feb 02, 2020 12:21 am
I'm painfully aware now, believe me. :lol:
Jobber72
Post by Jobber72 »
mike admin wrote: Mon Jan 27, 2020 10:07 am This works on all platforms via so-called "universal flash tool", also known as "sdftool". In a not so distant future this tool will be released as a standalone open-source tool, but for now it shares an executable with makemkv. Current makemkvcon has a "secret" command line argument - if the first command-line argument is "f" then istead of makemkv a sdftool is executed and the rest of command line is interpreted as a command line for sdftool. Just make a shell script named sdftool that calls "makemkvcon f $1 $2 $3 etc...", or just call "makemkvcon f arg1 arg2 arg3 etc..." directly
[/code]
Has anybody told you lately that you are absolutely awesome? :-) Great stuff. Thank you! (Linux user here ;-))
constantsc
Post by constantsc »
Ikkeetnavn wrote: Tue Jan 28, 2020 8:54 am
stigger wrote: Mon Jan 27, 2020 11:48 pm Tried, but it didn't work, unfortunately. Not sure why.
mtk:19:59:JBC6:ASUS    :BC-12D2HT       3.01:WM00900:-
# ./makemkvcon  f -d /dev/sr0 -f /tmp/sdf_0000006a.bin -v flash -i /tmp/k/mk-firmware-pack-20191206/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Loaded SDF.bin version 0x6a
Unknown command
Command produced error code 0x8fffffff
I believe you just need to a minor adjustment to the command ­— "flash" is the command part which the console output describes as unknown. Calling it with "help all" will give the available commands and one small change was enough for my case.
Hello, fantastic application! Registered and been using from a few months now - with great success. My drive has been identified as being available for the LibreDrive firmware upgrade. I've attempted to do so but am getting an error that I can't find any references or help on. If anyone has some insight or suggestions it's be greatly appreciated.
Ubuntu 19.10, amd64
MakeMKV v1.14.7 [linux(x64-release)]
Executing as non-root user.
Using sdf_0000006d.bin (presume newest, also tried other sdf_ from _private_data.tar sdf_00000069.bin sdf_0000006a.bin sdf_0000006b.bin - same results).
OS device name: /dev/sr0
Product: BD-RE BP50NB40
Revision: 1.01
Serial number: SIM01I9FA4401
Firmware date: 2117-11-23 16:15
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 1.01
makemkvcon  f -d /dev/sr0 -f ~/.MakeMKV/t/sdf_0000006d.bin --info
SDF.bin version: 0x006D
Drive Tool SDF not present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:1.01
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:5861E4013FB5
makemkvcon  f -d /dev/sr0 -f ~/.MakeMKV/t/sdf_0000006d.bin flash -i /usr/local/src/mk-firmware-pack-20200214/MK/HL-DT-ST/BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.02-NM00700-211811011016.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
[/code]
Am I missing a supporting 3rd party package, library or executable?
Thank you!
sleepyguy
Post by sleepyguy »
mike admin wrote: Sun Jan 26, 2020 8:37 pm MakeMKV has builtin (non-advertized) flashing capability. It is yet not exactly one-click user-friendly, but if you are OK with using command-line and not doing something stupid just in case, it is a lot more safer and user-friendlier than devilsclaw flasher. Please (anyone) PM me for details if you would like to use and test it.
Sorry, apparently I don't yet have access to PM. I've read this entire thread and it seems that the windows version differs from the linux. I have 1.14.7[win(x64-release)] installed.There is no sdftool. The makemkvcon tool produces this help text:
C:\Program Files (x86)\MakeMKV>makemkvcon.exe f -d E: help all
MTK19xx firmware module v1.12
Commands:
  dump [auto|full|user] dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump user      - dumps non-volatile user data
    dump auto      - dumps full image if possible, user data otherwise
  rawflash [main|full|<flags>] sends the image and flashing flags to drive
                               for flashing in self-update mode
    rawflash main  - flashes main firmware (this is the default)
    rawflash full  - flashes boot loader and main firmware (caution!!!)
    rawflash 0x..  - any flashing flags may be specified manually
What am I missing?
marukuru
Post by marukuru »
Tried updating my ASUSBC-12D2HT, but stuck with:
Unable to load sdf.bin
Internal error 0xffffffff
sudo makemkvcon f -d /dev/sr0 -flash -i ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Also tried pointing to SDF.bin by using -f.
$ sudo makemkvcon f -d /dev/sr0 --info
[sudo] password for user:
Drive Tool SDF present
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
:3.01
8100:Yes
8100:Yes
8100:Yes
8099:Using LibreDrive mode (v%1 id=%2)
:05
:0C5D2E3D15D1
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
$ sudo makemkvcon f --version
LibDriveIo/SdfTool version: 2.01
HereInPlainSight
Post by HereInPlainSight »
sleepyguy wrote: Fri Feb 28, 2020 4:04 am
Commands:
What am I missing?
That... looks like output from the sdftool, I would presume. It's telling you what it can do with that drive -- it can dump the firmware or flash the drive raw. It even specifies the firmware module. But to be sure I'd try to run makemkvcon.exe f --help', and if it starts with 'Use: sdftool', you're good.
That said, I can't PM yet, but as a Linux user, I'm very interested in this. My drive info from within makemkv itself is:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BC-12B1ST
Revision: 1.01
Serial number: <removed>
Firmware date:
Bus encryption flags: 12
But, when I try to do anything of interest with the sdftool, I'm not sure if it has anything to do with the firmware date being missing, but I keep hitting a wall, which seems best surmised with:
$ ./sdftool.sh -d /dev/sr0 help
and:
$ ./sdftool.sh -d /dev/sr0 --info
Drive Specific SDF not present
Of the two missing -- am I supposed to do anything specific to get / provide them? It looks like my drive is supported, just not on this specific firmware, which is... obviously exactly what I'm trying to fix (though I'm not entirely certain if I'm supposed to update to the latest for my system and then downgrade to the BW-16D1HT 3.02 firmware, that seems like what's being recommended but I'm a bit too new to understand the exact benefits, people just keep saying it can be done).
Any guidance on what I'm missing to be able to at least update my firmware would be great.
olupome
Post by olupome »
I am joining this conversation as I am in the same situation. I am trying to flash libredrive on my Asus BW-16D1HT in Ubuntu using makemkvcon/sdftool which returns the exact same output:
sudo makemkvcon f -f /tmp/sdf.bin -d /dev/sr0 --info
SDF.bin version: 0x003E
kahomono
Post by kahomono »
I have a BC12B1ST from Asus, and it needs the firmware upgraded from 3.00 to 3.01.
My problem is, that download is ONLY available from Asus as a Windows executable. No BIN file.
I tried inspecting said .EXE as an archive but there was nothing identifiable in there.
Suggestions?
Post by mike admin »
kahomono wrote: Thu May 28, 2020 10:05 am I have a BC12B1ST from Asus, and it needs the firmware upgraded from 3.00 to 3.01.
What makes you think that? Never upgrade the drive firmware if the drive works...
kahomono
Post by kahomono »
mike admin wrote: Sat May 30, 2020 9:12 pm What makes you think that? Never upgrade the drive firmware if the drive works...
I am getting the message the Libre Drive functionality requires a firmware upgrade, and only 3.01 is on the Supported list for this model drive.
kahomono wrote: Sun May 31, 2020 11:14 am
If you want to upgrade to 3.01 for LibreDrive compatibility, you can download the modified ASUS flasher + firmware pack from viewtopic.php?f=16&t=18933. The 3.01 firmware is located in the MK pack "old" folder.
Sorry for the delayed response. No, your drive is already supported with "beta LD v6" code, please see the sticky. And the SDF.bin with new code soon will be published for all...
