Ultimate UHD Drives Flashing Guide Updated 2025
braveh
Re: Ultimate UHD Drives Guide Updated 2019
#151 Post by braveh » Sun Feb 09, 2020 10:25 pm
I read about LG WH16NS40 as being good for bluray ripping if firmware gets downgraded. But I can't seem to find that model. Instead, I can find LG BH16NS40 - is this model any good?
Or what other models are most reliable?
#152 Post by Billycar11 » Mon Feb 10, 2020 1:02 am
In my experience of 300+ drives the bu40n is the most reliable. The bh16ns40 is fine if it gets no read errors it's the same as the wh16ns40 just the boxes version
braveh
#153 Post by braveh » Mon Feb 10, 2020 9:21 pm
by bu40n you mean LG BU40N, which is a laptop blu-ray drive?
does it require to have a certain SVC code or something else very specific, like it is suggested here in the case of the BH16NS40 - https://www.myce.com/news/the-ultimate- ... ive-83254/ ?
#154 Post by Billycar11 » Mon Feb 10, 2020 9:50 pm
yes its a slim drive nope all bu40ns are compatible it natively supports UHD disks and has no sleepbug so you can rip and play UHD discs officially and unofficially
wag12wag12
#155 Post by wag12wag12 » Tue Feb 11, 2020 11:49 am
kiam001 wrote:
Thu Aug 08, 2019 6:26 am
My CH12NS40 can After Patch read 4k Blu-rays
Hi, I also have a CH12NS40 , where can I find information on how to do this patch to enable 4K read?
Sodapop74
#156 Post by Sodapop74 » Tue Feb 11, 2020 11:02 pm
I tried "CSL – USB 3.0 SSD/SATA Adaptor Converter for SSD SATA 1/2/3 2.5 Inches (6.35 cm) HDD 3.5 SATA Drive (HDD/SSD) USB Attached SCSI Protocol (UASP) including mains adaptor" from Amazon.de but it didn't work with otical disc drives. Are there any simple SATA to USB adapters under say 20 euros on Amazon.de that would work or do I need to get a more expensive enclosure?
Here is a link to the one I bought: https://www.amazon.de/dp/B01K22TZ3I
JavierAlbadalejo
#157 Post by JavierAlbadalejo » Sun Feb 16, 2020 2:03 am
Hello, I have an ASUS BW-16D1HT with firmware 3.10.
Can anyone remote control assist me or something to do this? And how to do it fixing the sleep bug?
st4evr
#158 Post by st4evr » Sun Feb 16, 2020 2:07 am
There is a subforum dedicated to these services and which is also noted in the first post. Pay attention and read the guides/instructions/subforums. For these types of services, see here:
https://www.makemkv.com/forum/viewforum.php?f=20
And use their appropriate contact information.
JavierAlbadalejo
#159 Post by JavierAlbadalejo » Sun Feb 16, 2020 2:16 am
Thank you and my apologies for the problem.
#160 Post by MartyMcNuts » Sun Feb 16, 2020 2:19 am
Read the first post of this very thread.
Sodapop74
#161 Post by Sodapop74 » Mon Feb 17, 2020 12:28 am
I did, but those aren't available in Europe. Ordering from the US means additional postage and customs charges and non-European power adapter. Does anyone have experience with Inateck's Unitek branded converter (https://www.amazon.de/dp/B00N4JLNXM)? It's advertised as being compatible with optical drives but so was the CSL one...
psycaz
#162 Post by psycaz » Tue Feb 18, 2020 2:01 am
Thank you to everyone for an easy to follow guide. Just purchased my WH16NS40 and changed the firmware no problem. Testing first disc and so far, all is great.
#163 Post by MartyMcNuts » Tue Feb 18, 2020 3:42 am
There are some bad reviews there. It appears to be a cheap copy with a dodgy power supply. We don't buy cheap junk. It's just not worth it. Better of spending a little more for a better quality one.
jonghotti
#164 Post by jonghotti » Thu Feb 20, 2020 6:32 am
Here here!
suoertrogg
#165 Post by suoertrogg » Sat Feb 22, 2020 5:21 pm
Just a quick post to say thank you to asmcom for the prompt handling of my recent order for a BU40N and case.
Delivery was very fast, communication excellent.
