Extrodinary league of gentlemen wont rip
coldhammer
Post by coldhammer » Fri Oct 22, 2010 5:42 pm
Makemkv gets to the end of the ripping process then throws a few errors and says it cant save the title. I thought maybee it was a bad disc. returned it and got another disc same issue.
I have run into this a few times now on different movies. Not sure what the problem is. Log:
MakeMKV v1.6.2 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Doggy Meadows/MakeMKV_log.txt
File 00001.mpls was added as title #0
Title #00009.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00025.mpls is equal to title 00001.mpls and was skipped
Title #00002.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00003.m2ts was added as title #1
Title #00004.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #2
Title #00006.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #3
Title #00009.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/Blu Ray
DEBUG: Code 7 at /$kn*|_kg0?oNEv,Snd":121264050
DEBUG: Code 0 at s5bo%KjKY^8llu6e0)<S#:29397449
DEBUG: Code 0 at ]8P!K|/(]\$Wlh]G+Ip:121263751
Failed to save title 0 to file F:/Blu Ray/title00.mkv
0 titles saved, 1 failed
setarip_old
Re: Extrodinary league of gentlemen wont rip
Post by setarip_old » Fri Oct 22, 2010 7:07 pm
Hi!
Did all of these problematic results occur while using MakeMKV v.1.62 or did some/any occur while using earlier versions?
coldhammer
Post by coldhammer » Fri Oct 22, 2010 7:17 pm
All occured on older versions. ELG occured on the new version and the older version as well.
setarip_old
Post by setarip_old » Fri Oct 22, 2010 8:49 pm
Then I'd speculate that either your drive is at fault or your problematic discs are either physically damaged or dirty. I say this because I had no trouble using makeMKV, a year ago, to successfully make a movie-only .MKV...
coldhammer
Post by coldhammer » Fri Oct 22, 2010 11:09 pm
Its not my drive. I have already tried all problematic movies on different drives with the same result. And in this case it is not the disc as I highly doubt I got 2 bad brand new discs in a row. I have transferred most of my bluray collection some 30+ discs to mkv's already mostly with no problems. There are just a couple discs that all exhibit the same behavior regardless of the drive that is being used. And in this case I had the opportunity to take the brand new disc back and swap it out with another new disc and still have the same result.
setarip_old
Post by setarip_old » Sat Oct 23, 2010 12:55 am
Then I guess we'll just have to wait and see what "mike admin" may be able to discern from your Debug log...
BTW - What are the few other problematic titles - and what Region are your original, commercial Blu-ray discs?
coldhammer
Post by coldhammer » Sat Oct 23, 2010 2:21 pm
all region 1. Rambo and I think terminator 2 all the only ones i can remember off the top of my head.
Post by mike admin » Mon Oct 25, 2010 6:05 am
A blu-ray disc mastering error seen more often lately. Workaround will be added in a next version.
