arrested development Season 1 DVD's
phillip9
Post by phillip9 »
I'm trying to make a digital backup of the arrested development DVD Season 1.
The DVD menu shows 8 chapters, but MakeMKV 1.14.7 for windows only shows 5 chapters of various sizes
Debug log started at Fri Feb 21 03:38:02 2020 , written by MakeMKV v1.14.7 win(x64-release)
001005:0000 MakeMKV v1.14.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Phill/MakeMKV_log.txt
No  SDF v06b: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
SDF id v06b: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
No auto SDF v06b: hp_BDDVDRW_CH28N_ED3F_20120905123456_B2IE3P4098695
DEBUG: Code 0 at 68v8mWrXe'J1:_97.:29395540
DEBUG: Code 0 at 1XbN%/Q/UQmW:YW-z:121261773
DEBUG: Code 0 at 1XbN%/Q/UQmW:YW-z:29393792
003028:0000 Title #1 was added (8 cell(s), 0:21:54)
003028:0000 Title #2 was added (8 cell(s), 0:21:55)
003028:0000 Title #3 was added (9 cell(s), 0:21:56)
003028:0000 Title #4 was added (8 cell(s), 0:21:57)
003028:0000 Title #5 was added (8 cell(s), 0:21:56)
003028:0000 Title #6 was added (8 cell(s), 0:21:53)
003028:0000 Title #7 was added (8 cell(s), 0:21:54)
003028:0000 Title #8 was added (8 cell(s), 0:21:54)
003028:0000 Title #9 was added (8 cell(s), 0:21:54)
003025:0000 Title #10 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #10/1 was added (1 cell(s), 0:06:56)
003028:0000 Title #10/2 was added (1 cell(s), 0:04:24)
003025:0000 Title #10/3 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11/1 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #11/2 was added (1 cell(s), 0:02:04)
003025:0000 Title #11/3 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #11/4 was added (4 cell(s), 0:04:19)
003028:0000 Title #11/5 was added (1 cell(s), 0:02:00)
003025:0000 Title #12 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003027:0000 Title 2 in VTS 3 is equal to title 1 and was skipped
001003:0020 DEBUG: Code 233 at bEW7UTiLpG0f/qP0/DLizlTO:0
Application exited at Fri Feb 21 03:39:39 2020
Re: arrested development Season 1 DVD's
Looks like the 9 episodes have at least 8 chapters (third has 9). Chapters are usually cells within the VOB files.
phillip9
Post by phillip9 »
I'll do a visual comparison.
thank you
phillip9
Post by phillip9 »
Okoro4ek wrote: Fri Mar 06, 2020 11:46 pm
phillip9 wrote: Fri Feb 21, 2020 1:37 pm I'll do a visual comparison.
thank you
Do you get a solution? :roll:
I decided not to backup these discs.
