Buffalo BRXL-PT6U2VB BN12 revision, MK ready?
bioteq
Post by bioteq »
Hi everyone,
After long deliberations and looking at various options I've decided to order the Buffalo BRXL-PT6U2VB - the choices were somewhat limited where I live and the prices exorbitant, so I chose the best I could, and I found a bit of a surprise in the box.
The drive arrived with BN12 revision firmware not the expected BN11.
I was all ready and set to flash it with the MK version from here: viewtopic.php?f=19&t=19422 and now this bummer...
Can someone tell me if this will result in a softbrick or am I good to go?
Do we even know what changes have been introduced?
OS device name: /dev/rdisk7
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN12
Serial number:
Firmware date: 2119-05-14 14:15
Bus encryption flags: 1F
Highest AACS version: 23
Thank you all for the amazing efforts here, it took me a long time to sift through (some) the knowledge and I'm still not entirely clear on everything. :)
Re: Buffalo BRXL-PT6U2VB BN12 revision, MK ready?
bioteq wrote: Thu Feb 20, 2020 5:13 pm Hi everyone,
Revision: BN12
Serial number:
So you are going to flash it with BU40N_1.03-MK?
You should still be able to. Just give it a go. It will either flash successfully or you will get an error before starting the flash.
Post by mike admin »
MartyMcNuts wrote: Fri Feb 21, 2020 2:23 am So you are going to flash it with BU40N_1.03-MK?
No no no, he will be flashing it with BN12-MK :)
bioteq
Post by bioteq »
Yes yes yes, I will most certainly be flashing it with bn12-MK :)))
As soon as I’m back home on Sunday.
Thank you so much Mike :)
mike admin wrote: Fri Feb 21, 2020 7:28 pm
Awesome!! Good stuff, Mike.
On another note, any updates on the Pioneer drives??
bioteq
Post by bioteq »
A quick update.
BRXL-PT6U2VB BN12 is now a LibreDrive :D
Thank you Mike!
Here is the drive info after the MK firmware update:
Revision: BN12
Serial number:
Firmware version: 0.BN120
Bluntman
Post by Bluntman »
Reviving this thread as I recently bought this drive. I used this firmware and it flashed just fine. Makemkv showed patched and all good.
However makemkv would report no disc after scanning the disc for well over a minute.
Multiple computers tested all the same result.
Out of desperation I tried the stock LG BU40N 1.0 DE firmware as I read it’s a rebadged BU40N.
After I flashed it. It worked perfectly. Multiple 4K discs ripped.
Anyone else having this issue or is it just me? If I can help as I have a stock drive still or in any way with logs etc.
Thanks.
Sent from my iPad using Tapatalk Pro
jonghotti
Post by jonghotti »
Yes I've had good luck flashing them with the stock 1.00.
Bluntman
Post by Bluntman »
jonghotti wrote:Yes I've had good luck flashing them with the stock 1.00.
Thanks appreciate the info jonghotti!
hansolo
Post by hansolo »
If bought now and is new stock, what is the FW version in it. Is it still BN12? I'm planning to buy EU version. Precise model is BRXL-PT6U2VB-EU. Is it ready for 4K backupping if I flash it with MK BU40N-BN12 fw (HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin) ? What if it comes with BN13 firmware? Thanks.
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
hansolo wrote: Wed Sep 23, 2020 7:45 am If bought now and is new stock, what is the FW version in it. Is it still BN12? I'm planning to buy EU version. Precise model is BRXL-PT6U2VB-EU. Is it ready for 4K backupping if I flash it with MK BU40N-BN12 fw (HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin) ? What if it comes with BN13 firmware? Thanks.
the EU version is not i bu40n i believe
what does your makemkv drive info section look like
hansolo
Post by hansolo »
I haven't bought it yet. Would LG BU40N and external USB3 enclosure be better option than this Buffalo drive? I believe they are same unit, Buffalo is just rebadged. I think LG BU40N is also official UHD BD drive so it would work with Powerdvd Ultra.
hansolo wrote: Wed Sep 23, 2020 9:50 am I haven't bought it yet. Would LG BU40N and external USB3 enclosure be better option than this Buffalo drive? I believe they are same unit, Buffalo is just rebadged. I think LG BU40N is also official UHD BD drive so it would work with Powerdvd Ultra.
he says its not a BU40N and he has one that he couldn't flash
https://www.makemkv.com/forum/viewtopic ... +eu#p94510
i wont even get into the power dvd ultra thing but it wont work even with the right version of that buffalo drive trust me i would know i sell alot of them
but power dvd ultra is a joke and a scam for UHD playback half the time it does not even work with all the correct hardware
hansolo
Post by hansolo »
So, it sounds like I should avoid Buffalo drive and go with real LG BU40N slim?
Yeah, I'm aware of absurd requirements concerning official UHD BD playback in PC realm. Not really something I would venture myself. I trust my Oppo 203 and Chinoppo players.
Hyacin
Post by Hyacin »
Hi, is this still the latest version? I just picked up a BN12.
Thanks!!
